End sealer
Started by Mesquite cutter, August 25, 2020, 11:02:35 AM
Mesquite cutter
What type of sealer would y'all recommend for sealing the ends of the logs?  I have used paint but I was thinking of  something more practical.   It would be mostly Mesquite, Texas Ebony, Oak and Pecan.
Backyard woodworker.
DIY sawmill
Youtube:  Retired DIY Guy
doc henderson
anything is better than nothing.  anchorseal is very good, but more expensive than free left over house paint.  I have used both.  I am a hobby guy so the cost saving of the wood vs cost of product and application does not really matter to me.  I got my first 5 gallons from the company.  my second 5 gallons from a hardwood store that buys it in 55 gallon barrels and will sell it in smaller quantities.  this shipping on a 5 gallon amount from uc coatings is not free.  you can have it colored from the manufacturer.  the original vs the anchorseal 2 has to do with plant additives to make the # 2 cheaper.  any of them work best if applied soon after cutting.  If I have a friend who has a log for me, I have them put on paint if they are a ways away.  several coats is better than one.
doc henderson
you can get it on amazon  for 125 dollars for 5 gallons and free shipping for anchorseal 2.  you can buy direct from uc coatings and have color added as well as antifreeze for additional cost.  I bought 5 gallons of the anchorseal 2 for 70 bucks, but had to take my container to the store and have it pumped in.  The blue colored is the original formula with antifreeze and color.  I have had it for over a year and still have some left.  I use an airless sprayer.  it can be rolled on.  you want a thick layer, and I tended to get as much on the ground as the log.   :D
firefighter ontheside
I've bought anchorseal by the gallon from amazon and at Woodcraft.  About same price.  I definitely think its better than paint, but as Doc said, paint is better than nothing.  I've even used some water based poly that I had laying around.  That worked ok too.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
Stephen1
I use anchorseal with antifreeze in it.
farmfromkansas
Thanks to Doc for getting me a bucket of anchorseal, have heard that the white roof coating  Koolseal will work also. Menards has it occasionally 5 gallons for 50$.
scsmith42
Quote from: farmfromkansas on August 25, 2020, 09:07:15 PM
Koolseal is a very bad idea, in my humble opinion.
The problem is that you either have to end trim the stuff off of every board after drying, or you risk tarring up your planer and jointers from the ends of the boards.
Perhaps it's no big deal to a hobbiest that doesn't mind the extra work and waste, but for most of us the cost of end trim and yield loss is much greater than the cost of Anchorseal.
Tom's 3638D Baker band mill
doc henderson
it was my pleasure FFK.  yes anything is better than nothing, but anchorseal works well and burns off in the kiln.
Walnut Beast
Quote from: Stephen1 on August 25, 2020, 04:43:26 PM
Is the antifreeze used for cold weather ?
doc henderson
yes. it is a water based wax emulsion.  so it will separate if it freezes.  I was told the antifreeze did not change the working characteristics.  If you do not have a heated shop ect.  it will protect your "not so cheap" but effective product.
Al_Smith
You can use roof coating/asphalt sealer but you need to cut a cookie off the end before it's  sawn else it will streak the lumber .Other than that I use anchor seal .
That Kool Seal is some really nasty stuff.  If you get any on your clothes or skin, it is basically permanent :D.
GeneWengert-WoodDoc
How important is it to have lumber free of end checks?  If you do have checks or splits caused by drying, is it a financial loss?  The cost of using Anchorseal is about $5 per MBF. The shorter the lumber, or logs, the higher the cost per BF on lumber or logs.
Asa reminder, certain species, like oak, have a higher tendency to develop large end checks, compared to basswood or pine.  Thicker lumber is more prone, and the cost of damage is higher, so always cost thicker lumber.
Finally, the coating must be thick enough to stop drying.  In fact on expensive species like walnut, use two coats.
YellowHammer
I've been using a lot of Klingspors Green Wood Sealer, at $17 per gallon, flat rate and fast shipping.  I have seen no difference in performance.
I didn't realize Anchorseal had dropped their shipping costs on their Anchorseal 2.
I have stopped end sealing logs, I leave some end trim on the logs, mill them, sticker them and then pack saw them to length on the pallet.  It saves all of the time I used to waste pre bucking logs, and 50% of the sealer used.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
TroyC
Is it necessary to seal pine? I've read it isn't necessary so I'm wondering if I am wasting money.
KenMac
Quote from: TroyC on August 27, 2020, 03:42:02 PM
From what I've been told, you do not need to end coat pine or other soft woods. I'm sure someone more knowledgable will chime in soon.
No. there is no meed to end seal pine.  That sure makes it nice.
Mesquite cutter
Thank you for all the information.   I will look into using anchor seal.  I would not need to use antifreeze around here.  We only have two season.  Summer and fall.  :D :D
DIY sawmill
TmbrWlkr
I saw a YouTube video where a woodworker was using Titebond 2 glue - he switched from Anchorseal - advantages are : costs, availability, and volume choices.  He claimed similar performance.
RussMaGuss
I bought a gallon of rockler's green wood sealer for like $22. Seemed similar to polycrylic. I agree with Gene where if the wood isn't highly valuable, don't even  waste your time, but at the same time I'd guess I used up maybe $3-4 for 1500 bdft of white oak. I did put 2 coats on the single walnut log I happened upon though lol
Got another 5 gallon pail of anchorseal today.  I am sticking with the anchorseal.  In the long run, it is worth it to me.  I found paint to not be useless, but it is close  :).
Walnut Beast
Doesn't seem Anchorseal make the smaller buckets anymore? Wonder why ?
doc henderson
I still see a quart or gallon size for anchorseal.  on amazon
Walnut Beast
Good deal. I bought from the company sometime ago then noticed they didn't seem to offer the smaller pail I had got.
Walnut Beast
Just looked on there site. It's the colored one I wanted to get that's only in 5 gallon buckets now. They used to offer in smaller buckets in different colors
