Dozer track
Started by mologger93, December 30, 2019, 08:45:12 PM
mologger93
Would any one know if 450 JD track will work on a 350 JD. THANK YOU!!
BargeMonkey
@coxy  would probably be the one to answer that one.
Mapleman
No, the 450 track system is larger than the 350 - wider links, longer between pins, larger bushings.
"The older I get, the better I used to be."
mologger93
Thanks for the info. I appreciate it. Thanks.
