What to Look For in a Forklift ****Picture Added****
Started by Ga_Boy, April 18, 2006, 07:46:02 AM
Ga_Boy
I'm getting ready to buy a forklift in the 8,000 to 10,000 pound range.
What should I look for in a used unit?
My yard is compacted gravel.
10 Acers in the Blue Ridge Mountains
Quartlow
big tires!!!
small tires and gravel don't get along. Personally I would be looking for a telescoping boom forklift, Isn't it Bibby who has one? A terex if i remember right. Be nice to be able to reach out over and grab a log from the back without moving stuff in front.
From my rental industry days we had Skytaks, Lull's, Gradall and Gehl's All of them where good. My favorite was the Lull though. They where easy to work on and had great tech support.
Breezewood 24 inch mill
Have a wooderful day!!
sawguy21
Along with making sure it starts and does not smoke excessively, give it a good inspection. Are the tires in good condition with no cuts in the sidewalls? Do the service and parking brakes work? This is really important. There should be no hydraulic leaks or frayed hoses and the mast should move up and down smoothly without bumping or twisting. Is there any play in the pins indicating excessive wear? Make sure the forks are not bent indicating it was overloaded or used as a hoist. Will it lift and hold a load without creeping? Abuse and lack of maintenance leading to mishaps are all too common.
One of those telescoping jobs would be nice for sure, but might be a bit pricey.  On a conventional lift, look for one with big wheels.  They aren't noted for handling rough terrain well, so the bigger the wheels, the better.  Also, long forks are nice.  The Hootiemobile's forks are only 42", so I can't reach the middle of most trailers.  Side shift would be a really neat thing to have, too.  Long logs are pretty much a balancing act, and side shift would make it easier to get centered right.
Gilman
1) How far will the forks tip down.  Forklift like the Hyster H200 (20,000k) lean really far forward, making dumping slabs off the forks really handy.
2) My forklift repairman told me to stay away from hydrostatic drives, if the transmission goes out the forklift has 0 value.
3) Make sure it isn't a gray market.
WM LT70, WM 40 Super, WM  '89 40HD
Cat throwing champion 1996, 1997, 1999. (retired)
Ga_Boy
Captain
I like my IR BL375 with forks just fine......lifts over 4000 lbs.   Grapple is next...
Captain
Dan_Shade
gray market is "made in china" or whatnot.  works OK, but replacement/repair parts are very difficult, if not impossible, to find.
lots of dull bands and chains
sawguy21
Dan is right, grey market products are cheap copies of brand names. The Chinese are promising to respect international patent and trademark agreements and crack down on bootleggers but we shall see.
scsmith42
Before you buy it, run it long enough to get the motor and hydraulics good and warm.  Make sure that it will pick up the rated capacity when it is HOT (and the fluid is thin).  Also make sure that the power steering will turn ok, hot and with a full load.  Often when the hydraulics get weak the first sign is weak steering.
Big tires a must, in addition to the side shift having the ability to hydraulically change the fork width is very nice.  Any "offroad" forklift will have large tires.
Very important - can you see the ends of your forks in your typical operating positions?  Believe it or not I've seen forklifts where the back plane was so large you couldn't see the forks!  This made operation a real pain.
Drive it at full speed.  Is the steering tight and does it track well?
Re Gray Market - this also refers to forklifts that are from other countries but were not manufactured for export to the USA.  Getting parts, repair manuels, etc can be difficult if not impossible.
I would stay away from Caterpillar forklifts - not their core competancy and not a good machine
Tom's 3638D Baker band mill
ScottAR
My experience comes from warehouse lifts but some of it applies.
Controls must be comfortable to use.  Spring ride seats are ***NICE***.
Stay away from lifts that have had hydraulic attachments on them such as clamps or slip sheet toters...  I guarantee the engine was wide open while the attachment was used as lift drivers are in a constant hurry. I always was and I was one of the slower drivers.
Try to get a machine with independant brakes/clutch pedals.  Way easier to use on inclines.  Combo pedals will have you rolling into trucks and merchandise.
Cat's warehouse lifts are made by Mitsubishi.
Scott
"There is much that I need to do, even more that I want to do, and even less that I can do."
[Magicman]
Ga_Boy
I have found a Hyster 8,000 pound truck.  Standard mast, I do not need to lift any higher than my trailer or kiln cart; at least for now.
This one does not have side shift, I do not think I can afford a side shift unit now, those are in the 15-18K range.
The motor in this unit was just replaced by Hyster with a rebuilt engine and converted to propane, so the propane system is new.
The dealer will let me use it for 3 days before I buy it.  It has dual tires on the lift end.  It has 42" forks so I will have them put langer forks on it, I want to be able to reach the middle of my trailer.  It will be nice to load/unload my trailer much faster than before.  The last load of logs I brought in were from a customers where the tree service loaded me.  It took an hour to get that thing unloaded by hand.  I let the tree guys put a nasty crotch log on top.  That thing did not want to come off the top.  With a lift unloading will be a snap.
I just wish I had the room for a 20,000 pound lift.  It sure would be nice to move those 60" diameter logs.  oh well maybe in a few more years.
sawguy21
Be careful of the weight with longer forks or extensions. The steering gets reeeeeal light in a hurry.
ScottAR
Yessir,  Lifts will pick up more if your going forward than if you need to back up.   Trouble is, you usually can't see where your going...  :D :D
Start easy when backing up...
Mental excercise when moving tall things...  get a empty paper towel roll and place it end ways on your palm.  Now, walk around the room.
If you drop it, you have to pick up 10,000 little plastic bowls....
For the record, takes about an hour...   :-\
Scott
[Magicman]
maple flats
Mark, What size are the tires? You will find that on gravel you need big diameter for an OK ride, bumps will dump the load. Double tires may give you floatation but do not help on smothening the ride. If needed can you add more weight easily on the steer end? If you will be lifting HEAVY this might be a consideration. Good luck, If you buy it we need pictures.
Ga_Boy
The Hyster Dealer delovered my forklift this morning.
As soon as the rain stops I'll post some pictures.
This thing can pick up those big White Oak logs I got last week. 8) 8)
You're gonna like it, Mark!  All that side-shift and stuff like that is just niceties.  Bottom line is, you can pick up whatever you can haul in.  You'll drop a few logs from time to time, but the trick is to be careful where you drop'em.  If I'm loading a biggun onto the mill, I'll throw a chain around it, just to make sure. ;)
oakiemac
I don't know...but before you buy a straight forklift you might want to look at other options that might be more versitile. A small wheeled loader with bucket and forks would be real handy although price might be steep.
I bought a skidsteer which is large enough to pick up 95% of the logs I come across and I get some big uns. Ask Jeff about the size of the logs in my yard. With the skidsteer I can move sawdust, load logs, load trucks, move slabs. I can take it in the woods to skid ( I know there is better machines for skidding but it works). I can move snow, manure and do light excavating with it. It is all terrian and almost never gets stuck. Unless my 16 year old drives it through the muck after a heavy rain.
Don't know if this is right for you but you might want to look at all options.
Mobile Demension sawmill, Bobcat 873 loader, 3 dry kilns and a long "to do" list.
Ironwood
NEVER MET A FORKLIFT I DIDN'T LIKE!!!!
                  14,000-8,000-5,000. Couldn't do with out them. Reid
Ga_Boy
Well I got pictures of my forklift but my high speed connection got cut by the paving contractor.  Even after I uncoverd the line on each end where it crossed the drive way.
Oh well Comcast will be out in a day or so to fix it.
Pictures are coming.
Captain
It would kill me not to be able to dump slabs off the forks....
Captain
ScottAR
Ya just hit a couple bumps in the yard and they fly right off.   :D :D
Scott
[Magicman]
Ga_Boy
Here is my new to me forklift with one of those big White Oaks we gota few weeks ago.
The unit is a Hyster rated for 8,000 pounds with 5' forks.
Lookin' good, Mark!  You're gonna wonder how, and why, you ever got along without it. ;D 8) 8)
scsmith42
Sweet!  Nothing like a new toy.. uh, I mean tool!!!
maple flats
Carry the load low. That lift will sure make the difficult easy.
Congratulations,
Maple
oakiemac
Nice looking lift. Just don't take it in the mud ;)
Ironwood
Captain,
 Some forklifts tilt forward an amazing angle. My 8000# Clark IT-80 rough terrain really tilts forward, another Clark CY500 (old glass plant truck which I traded off for the IT-80) I had also tilted way out. I think it was a concident that they were both Clarks.
Ga Boy,
Lift looks great. Hyster is a top shelf unit, you'll love it! No comparison to most other equipment for lifting #####'s.
                  Reid
Ironwood
AS FOR MUD, YOU'DE BE AMAZED WHAT TIRE CHAINS CAN DO!!! i WISH i HAD SOME PHOTOS OF THE MUCK MINE HAVE BEEN IN.  The key is good ground clearence which your Hyster has. Usually the trucks are twice their rated weight, so yours should weigh 14-16,000lbs. It also looks like you have wide front drive tires which helps with the off road stuff especially with chains. Get the ones with MONSTER cross links. I usually find mine at the scrap yard and cut them dowm to fit.
               Reid
sawguy21
Gotta be careful running chains on those puppies. They can make for a rough ride and unstable load. It is also easy to tear out the final drive with a heavy foot.
DoubleD
Ga boy congratulation for your forklift  8) 8) 8)
Wannabe a sawmiller
Ga_Boy
Thanks to all for the comments on the forklift.  What I am looking forward to the most is stickering right off the saw then sitting this pack on the kiln cart then pushing it into the kiln.  No more handling material 2-3 times to get it in to the kiln.   8) 8) 8)
Reid,
Do you run chains all the time?  My existing yard is compacted with gravel, no problems on this surface.  I am looking to expand my storage area for stacking as material comes off the saw.  I am not sure I can afford to properly prep this area, right now it is wooded so I will have to clear it, no problems there, I have  a Kubota with FEL.  My question is for using chains, Can I run chains all the time?  I will end up with two diffrent surfaces, compacted gravel and dirt.  What is your experience?
Dan_Shade
you'll be fine with the chains, Mark, but don't run them on your new pavement.  it will leave dents in asphalt, and may make a "shaky" ride if the gravel is really compacted.
I used to like it when the school bus had chains, rattle your teeth and everything else!
Ironwood
Ga. Boy,
I run them mostly in winter. Although if you have gravel they would be fine year around. Mostly I don't want to wear them out by running them all the time and contrary to what MOST people believe forklifts go fine off road. Trust me I know, been doing it for years.
                                          Reid
