Surfacing equipment for slabs
Started by Blackhawk1, December 27, 2017, 11:10:29 AM
Blackhawk1
After reading through all the information I am now leaning to a CNC router table for the 20K I will be spending, versatile and I can produce other product with a CNC table
Now for another question what CNC table manufacture for the 20K price range?
Quote from: TKehl on December 30, 2017, 07:58:38 PM
I'm with you guys.  If I was going to drop $17k, it would be on a large CNC router instead of a single function machine.
  To clarify since so many people have answered me.
We have 10 slabs 18 feet long over 40 inches wide, these are all live edge Cypress
There is an additional 8 Pecan slabs 9 feet long and 48 inches wide
We need to true fireplace mantels on a regular basis that range from 4 feet long to 12 feet long and range from 12 to 16 inches wide
In our log pile we have potential slabs to be milled from 12 feet long to 50 inches wide.
Making our own surfacing table is something we do not have time to do, we need to purchase a unit ready to go.
I currently have a Peterson ASM that I use to mill and surface large slabs. I would like to have independent equipment to do these steps. After searching the internet and this forum I have come up with several options and I would like some input from  members.
Baker makes a surfacing table, has anyone ever used one of theses?
I am thinking of selling my ASM and purchasing a wide slabber or wide band saw mill. Who has used one of the wide band saw mills on the market?
Can anyone recommend a surfacing table? I would use this for wide slabs, truing fireplace mantels and so on.
Thanks for the time and answers
Doug Caroselli
512-738-1770
Brad_S.
Of late, I have become a huge fan of perusing Pinterest, of all things! I bookmarked several tutorials on how to construct slab and/or cookie straightening/leveling tables using a router mounted in an overhead sled system. If you have the $$, a CNC router does the same thing automatically vs manually. Short of fitting the mill head with a planer blade, the router method is the most effective cost vs time method I have seen.
Edit: I just looked at the Baker table on their site. Looks to be like a type of dedicated CNC table. Looks great but for $17K, one would need to keep it pretty busy to justify it!
woodworker9
How wide are the slabs you are working with?  Cost effective options vary with width, so I would need to know what your parameters are.
B@kerJB
The Baker Slab Surfacing machine, Wood Wizz, is a neat machine. This machine is unique in its own way. This machine is different from a CNC machine as it offers the ability to plane and sand on the same table, not transferring any material. You have the ability to plane a wider cut of 5" than you would find on a CNC machine.
Brad_bb
I have a Woodmizer MP100 Beam Planer.  Besides beams, I use it on slabs up to 20 inches wide, sometimes a little wider if they are curved and I can rotate them on the bed.  The Planer itself has a 16" wide planer knives, but the planer can slide another 4" in it's frame giving you 20" wide.
The planer often gives a smooth finish, requiring relatively little sanding afterwards.   It also acts like a jointer giving you a flat side.  Some woods will tear out like Osage, and sometimes Ash.  In those cases it will require more aggressive finish sanding.
So i think an ideal surfacer would be akin to a wide 2 rail mill bed with a wide head frame for the planer.  Use the same sliding concept that woodmizer does, only on a longer head frame to give you the surfacing width you need.  Lastly I would change the cutter head from 4 straight knives, to a Byrd Shelix type helical segmented type.  One of the pains with the stock straight knives is that if you get one nick, it's likely in all 4 knives, and you have to replace the set to get rid of it.  (actually you can offset 2 of the knives and get a little more life, but not the ideal solution.).
https://youtu.be/vqrN4dzH8uI
Kbeitz
This coming summer I will be building a machine like in the video above
that will fit on my mill bed. I already bought all the stuff I need but this
cold weather not agreeing with me. Come on summer time....
Love machine shop work
and Wood work shop work
And now a saw mill work
flatrock58
The Wood Wizz is built in Australia and distributed by Baker.  I saw it operate at the IWF in Atlanta and talked to Les Owen, the guy who designed it.  Baker is selling the bigger model and i think it is in the $15K range. It does a really good job.
I have thought about looking to see what it would cost to buy the smaller hobby model and have it shipped from Australia.   I have also thought about buying a used Lucas mill.  Les sells a 8' surfacing blade and sander to go on them.
2001 LT40 Super Kubota 42
6' extension
resaw attachment
CBN Sharpener
Cooks Dual Tooth Setter
Solar Kiln
tule peak timber
I looked at the Wood Wizz this summer in Las Vegas and very nearly bought one. The main selling point as explained to me is that only one man needs to run it, thereby freeing up labor. I have several guys that run powered hand planers that will flatten any  slab in short order , but the Wizz machine did look good ! So I came home and did a poor mans version with a router sled registered to my finishing table with the same results- one man flattening slabs reasonably fast. My next version will have a bigger motor  and a larger tool head. Another great tool to surface with is the slabber by Lucas. Just running the chain saw carefully , slaking the surface produces good results. Another tool is a large jointer with a power feeder that with some finesse will tackle slabs several feet wide. This option is expensive though. I have massive tables inside and outside the shop to reference slabs on, using different methods of flattening. Trained guys with power planers works pretty darn well.....Rob
redbeard
https://youtu.be/PuYwRs819C0
Been studying the idea of using a shaper mounted upside down, the wheels will work good or maybe linier bearing set up
Also like this one
https://youtu.be/kkp_d3C0UVI
One of the locals runs a sled with 3 PC routers running on his Lucas slabber rails.  The routers are staggered behind each other.  I'm not sure what bits he runs, but with 2" ones that would give 6" minus every pass.
Another guy had a Komo cnc with a table about the size of a tennis court.  He could level a slab while we drank a cup of coffee for a reasonable price.  He could also cut a recess for counter bolts if slabs had to be joined.  Went out of business, guess he was a bit too reasonable on price.
YellowHammer
Slab size dictates how hard they are to flatten.  I've tried several things, but I recently bought this 20 inch jointer with nearly 6 foot infeed table to flatten slabs as well as other jobs.  Most our slabs are 8 feet long, less than 2 feet wide, as that's about all our customers can handle and about all we can get out of our walnut logs.
I worked this walnut slab this morning.  It wasn't too bad out of flat, somewhere around 3/8" inch, but would have been impossible to flatten with my planer.  The nice thing about a jointer is that the slab never has to be lifted to make successive passes, simply drop the cutter head and slide it backward on the table, then raise the cutter and take another pass, back and forth.  Very easy, fast and puts a finished glass surface on it.
Heres the slab laying on the bed, lots of gap between the wood and the table.
This is after only one pass, pretty good, but still a little to clean up on the edges and left side, where it pulled because of a knot.  You can see the depth of cut by the gap between the infeed fence and table, about 3/16".
Here's after the second pass.  Flat as a piece of cast iron.  Then a pass into the planer, flat side down and done.  No sweat.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Brad_bb
tule peak timber, So my idea was similar to the baker surfacing table, only bigger, and a planer taking 16" swaths at a time.  So it would be fast.   QUESTION:  if you were building it, how wide would you go - 60"? to cover say 80-90 percent of the slabs or table tops you'd do.
longtime lurker
Sooooooooooo. Heres where I finally get to outdo Mr KBeitz... cause I got one and he aint. :D :D :D
(I didnt build it though but... its mine. I bought it off the guy who bought it off the guy who built it. He was an old time mortician and used it to flatten and polish headstones when he wasnt p[laying with big chunks o' wood)
Y'all going to loooove this one.
Please forgive that bad photos, I took these when we got it and ive been kinda busy the last few years and havent got it installed at home yet to take better ones.
Soooooo, theres a rotary table underneath that holds the workpiece, and its got some up/down movement and some side to side movement thats achieved by way of a couple hydraulic bottle jacks.
The main body is hooked onto a post and the winch setup controls height of the arm/ working assembly. It looks pretty rough but it actually drops in about 1/16" increments
Power is ex KleenMaid industrial washing machine motor, gearbox out of a Ford Cortina, final reduction courtesy of a Ford 9" automotive diff.
Theres a big flat head hooks on the bottom (not pictured). It takes either 3 of those 7" velcro sanding pads, or can be changed out to one thats got a big planer knife set to work similar to a hand plane
The articulating arm setup means it can work on anything within about a 8' radius of the center.
Despite appearances, this thing actually does a really good job. I never saw it working with the planer blade but she was chewing her way through some really hard timbers that fast with 16 grit paper when I played with it that I dont think id ever bother changing it out anyway.
I'd like to say Im going to set it up again one day but I havent cut anything in 3 years over the limit of the big Klein planer so theres not a lot of urgency involved. My current ideal is to find someone local who wants to set it up and give it to them on proviso that i can use it on an as required basis.
Blackhawk1
The largest I have now are 18 foot long and 48-inches wide. The smallest are 24-inches wide by 10 feet long
Doug Caroselli
512-738-1770
longtime lurker
Theres a piece of equipment thats -well its what that thing I posted above is a homebuilt version of.
Not common but... if you look long enough sooner or later you find and the other thing is that as with most now esoteric equipment... limited demand tends to translate to low prices. Hell most of them probably go to scrap because people dont know what they are.
its called a "Pattern Milling Machine", which is basicly the predecessor to the modern axial router. On steroids. With the ability to not just flatten slabs but carve complex curves in them as well.
Just sayin' ... one of those keep your eyes peeled for and you get lucky things.
Blackhawk1
I agree at the price point it needs to stay busy and we have the work load to do this.
Quote from: Brad_S. on December 27, 2017, 11:42:30 AM
Doug Caroselli
512-738-1770
Blackhawk1
Quote from: woodworker9 on December 27, 2017, 12:27:16 PM
I have revised my post, it was not clear I can see now with all the people helping with information
Doug Caroselli
512-738-1770
YellowHammer
Quote from: Blackhawk1 on December 27, 2017, 11:10:29 AM
Surfacing wide slabs removes a lot of meat so we prefer to cut or rip to approximate selling customer length and width before we flatten.  Crosscutting or ripping a wide board in half or to usable length increases the flatness and removes tremendous warp.  We rip and crosscut on our sawmill or Tracksaw, depending.  It keeps the wood on the slab instead of the chip pile.  Everything gets easier and lighter.  Most customers can't handle big and wide, anyway,  and most mantels and tops are relatively short and narrow, less than 20 inches wide, and as you say less than 12 foot long.  It's been our experience most mantles are less than 8 foot.  If I had to get something besides my jointer to flatten, I'm almost certain it would be a MP100 which mounts to an LT15.
YellowHammerisms:
scsmith42
Doug, there is a guy right down the road from you in Bastrop named Brandon Berdoll.  He has a milling and planing operation that specializes in oversized logs and slabs.
His planer leaves an outstanding surface and it may be worth your while to reach out to him to see if you can work a deal for him to plane your stuff.  Tell him you were referred by Scott Smith.  Send me a PM if you'd like his number.
If you get into it on your own, as others have recommended a CNC router would be a great choice.  You can usually find them used at Industrial Recovery Services for a good price.
I have a 25" Oliver jointer/planer that does great, and also have the planer blade for my Peterson WPF.  The automatic operation of a CNC router sure would be nice though.
Tom's 3638D Baker band mill
Blackhawk1
Doug Caroselli
512-738-1770
Blackhawk1
Doug Caroselli
512-738-1770
B@kerJB
There are several guys out there using the Wood Wizz both for recreational/hobby reasons and Comercial/Business Related. Work load typically is dictated by how much product you have or how busy you want to be. There are guys out there that have bought one Wood Wizz already and are looking to purchase 1-2 more. I believe that speaks magnitudes to what this machine is capable of doing and how well it helps a business.
B@kerJB
In my experiences, with Bakers being the sole distributors, if you call Les with Wood Wizz, he will refer you back to the guys at Baker Products.
Quote from: flatrock58 on December 27, 2017, 07:32:07 PM
tule peak timber
Quote from: Brad_bb on December 27, 2017, 11:50:28 PM
Brad I would build as wide as you can cut , and then some. 60 inches is awfully wide for a table so your estimate of 80 - 90 % is a pretty good number. We do wider stuff but break it down into pieces if we cant handle it physically.Business wise , setting up for that one in a million monster slab makes no sense to me when the gross majority of tables are 38-42 inches wide finished. Rob
Blackhawk1
Thanks for all the information. I have made my decision to go with the Baker/Wood Wizz.
Doug Caroselli
512-738-1770
tule peak timber
From my chair , moving forward in the slab market is done with a little caution. Rob
scsmith42
Quote from: tule peak timber on December 30, 2017, 09:08:25 AM
Agreed.  With everybody getting into it the prices are bound to drop, along with demand.
tule peak timber
I've been seeing several indicators here for the last year giving rise to caution. Look at a lot of the threads here on FF. Luckily I have years of dried slabs laid up and they are selling well but also a large number of buyers simply calling for pricing-not buying. The price and competition for large logs is insane. Several visitors a month come here wanting to know how to slice off " $20,000 slabs", dry them quickly, and will I do " it " for them. YIKES !!!!
longtime lurker
yeah, same here. I will still contract saw you slabs but no way will I cut and hold stock on my own account anymore with them. The market is oversaturated with the smaller bartop size pieces to the point where people are selling slabs cheaper then the value of the boards I could rip out of them.
Bigger stuff isnt moving much. General domestic economic conditions more then anything I think - people arent spending much.
The premium/ export market is steady but as we all know thats only a small fraction of the market and it can be a long way between sales.
I wish I had $1 for every tree that was going to cut $20k slabs people have tried to sell me.
tule peak timber
nativewolf
I'd agree on the cautionary tales.  It may be a good time to be a furniture maker rather than a slab wood seller.  Or, like TulePeak develop extraordinary expertise in finishing and presenting the slabs.  Lots of folks slab and don't know how to finish and the end product is pretty ho hum to poor.
Liking Walnut
redbeard
I will keep slicing the big logs thick and wide leaving the live edge on while this market lasts. Because you can always make boards, beams, cants and the big plus is finding the figured wood too cut out of the slabs. 3"-5"-6-1/2" are safe thickness too still recover sellable product. Hot seller right now is live edge shelving 1-1/2" thick . Able to resaw some of the plain Jane slabs that don't sell well and make shelving.
There are several big league slab sellers in NW Washington that have wharehouse full of wide slabs and they air dry for two years then dry either DH or vacuum. Some species work well Vacuum kiln straight from mill others don't. Color is a big factor.
Recently visited urbanhardwoods.com
Some beautiful tables they sell
POSTON WIDEHEAD
Red Beard....what are their prices on these tables?
TKehl
The CNC may be slower (lower HP), but would run unattended and have additional potential revenue streams to ride out market fluctuations.
redbeard
 Poston  You could buy a nice LT 40 or TK 2000 with bells n whistles.
YellowHammer
smiley_thumbsup
Versatility in a machine is importatnt.
Redbeard, I'm seeing the same thing as the live edge shelving is hot, and being used for the cast iron pipe "steampunk" style shelves and furniture.  Classes are even being taught at the Big Box Stores locally.  They sell the pipe, fittings, and paint but don't have nice looking wood for the shelves.  What a shame because we have a rack of ready made shelves, 4 foot long, 8/4 live edge one side, jointed edge the other, faced and planed.  Employees who work there tell people to come see us if they want something "different".  Nice thing is, people never only buy one shelf.
YellowHammerisms:
Blackhawk1
Doug Caroselli
512-738-1770
Andries
Quote from: YellowHammer on December 30, 2017, 08:44:30 PM
.. . The CNC may be slower (lower HP), but would run unattended and have additional potential revenue streams to ride out market fluctuations.
smiley_thumbsup
Redbeard, I'm seeing the same thing as the live edge shelving is hot, and being used for the cast iron pipe "steampunk" style shelves and furniture.  Classes are even being taught at the Big Box Stores locally.  They sell the pipe, fittings, and paint but don't have nice looking wood for the shelves.  .....
I was surprised at my local big box store while Christmas shopping.
Vacuum dried, live edge slabs - in plastic wrappers!
They're produced in Quebec, and sold waaaay out West, here in Manitoba.
They're probably noticing the attendance at the "steam punk"  :D seminars and decided that there's money to be made.
Good advice in this thread re: market conditions will re-direct equipment purchases - 'cause this market seems to have shifted.
Anyone else notice these products in their area?
LT40G25
Ford 545D loader
Stihl chainsaws
Andries
The famous Poston slab for $300.00 is now mebbeee worth $140.00?
:D  ;)
LT40G25
Ford 545D loader
Stihl chainsaws
YellowHammer
Well, I'll be! :).   They must have been reading this thread.
Just checked the Home Depot website, approximatly $6.70 per bdft for Canadian White Pine, single side live edge.  I've been selling my pine live edge for $6, but up to 20 inches wide.  I still beat their price point.  They would not have introduced a new product stream in a saturated market, so I'm thinking the demand for 8' x 2.5" x 8"-12" is about to go up.  I'm glad I have my 20" SCMi facer/jointer.  Tule Peak, I may need to go ahead and get one of those CoMatic Jointer Feeders you helped develop.
YellowHammerisms:
Crusarius
if looking at cnc routers you have 2 different type.
you have flat table router style that has a sacrificial MDF table that vacuums that suck the part to the table through the MDF. These work very well for large items. The only time I have had issues with them is when I start with a 4x8 of white melamine and start cutting drawer parts out of it. The more cuts you make through the stock the less vacuum there is to hold it in place. These can be had relatively cheap and have a bunch of tool holders. the last one I used had 8 positions. The biggest cutter we used was a 6" flycutter for smoothing the MDF when it got to rough from cutting cabinet parts.
The other style is point to point. this uses a series of vacuum pods that hold your piece in place. These work very well you just have to be much more careful if you are penetrating the board so you don't hit the rails or pods.
The flat table is quite a bit more versatile especially with what we would all be thinking of using it for. you can get lots of different configurations. 1 table 2 tables this gives you the ability to load one table while the other is running. The sizes have gotten pretty large to.
Another great feature of the flat table is sign making. throw a slab on the table, surface it, then cut whatever the customer wants. That is where the 8 head toolholder comes in very handy.
I was exposed to all these fancy tools when I used to work for a bunch of cabinet shops. The general construction was adjustable shelf holes with dowels and then clamped together. Just basic casework. but the flat table router really excelled being able to throw a 4x8 on the table cut all the parts to size and then drill all the adjustable shelf holes in one step. The guy we had running the cnc also did our plastic laminate layups. he could layup 2-3 sheets in the time it took to cut 1 sheet of cabinet parts. Worked out very well for use. the guys building never had to wait for parts.
21incher
About 2 years ago I sketched up a router sled I will be making to fit on my mill someday when I get the time and extra money. It will be a cnc setup controled by GRBL using steepers that will be a belt drive and use an Infinity planer bit in a big PC router. Just drop it on the mill, tension the x drive belt to the mill tracks, set 0,0 on the slab corner, choose the proper  lenght x width code and watch it run. Self contained and runs on 120 volts and will be between 300 to 400 pounds. It will also be useable to make large signs just like a 12 foot x 24 inch cnc router :)
Crusarius
Quote from: 21incher on January 02, 2018, 08:23:47 AM
I am really interested in following the progress on that. I have thought about something very similar. Now that I have a 50" mill bed that would make life quite a bit easier.
TKehl
I can't say much on CNC in that price point.  Much more $ than I could budget and haven't investigated.  (My current CNC router is a homebuilt 2'x4' model for about $1k.  I use clamps and T slots instead of vacuum hold down.  My dream setup is either 4x8' or 5x10' from CNC Router Parts would be about $6-8k all told.)
For commercial models though, I hear good things about Thermwood and Laguna.  Thermwood also has a program where people can use their FREE design software and send the file to participating Thermwood owners to cut on contract.  Like hitting the print button, but for cabinets.   ;)
Shopbot Tools is middle of the road for price, has a great reputation, and is US built.  If the weight capacity of their table matches what you have planned, it could be a great option.
redbeard
http://yasengineering.com/
Here is a Australia product slab master looks to be well built.
