Chainsaw Milling "Coins" 1.5-2.0 Wide
Started by aaaice, October 20, 2014, 06:53:35 PM
aaaice
I need help with how i can successfully cut slices of logs (bark on) that are uniform in width. I am going to attach them to a wall 27 feet long and 7 feet tall using random diameters from 3"-12" I can cut up to 6" with my chop saw, but need a way to cut them accurately with my chainsaw 59cc 20". Any thoughts are much appreciated !
We can still save this country, by converting one sheep at a time . . .
backwoods sawyer
Make a jig with a stop and a cut line kinda like you would use with the chop saw.
Backwoods Custom Milling Inc.
aaaice
I was hoping there was something out there that would turn a chainsaw into a chop saw?
Joe Hillmann
If you search youtube for homemade firewood processor there are at least two videos of people who basically turned chainsaws into large chopsaws by mounting the bars to a hinge and a workbench.
Quote from: aaaice on October 20, 2014, 07:37:51 PM
There used to be a product like that that a former sponsor used to sell. I need one myself. I do know that the former sponsor didn't carry them any longer and I've never found them anywhere else.
blade69001
https://www.youtube.com/watch?v=y_1Jh4ETLCM
For some reason I can't insert the video but this may be of interest.
Just being me, But it is ok you do not have to like me.
aaaice
Wow, Thanks, That video sparked some ideas for me. I was hoping there was something I could just buy, but that led to other videos that were very helpful !
MortalWombat
Why couldn't you use a standard Alaskan chainsaw mill -with a regular crosscut chain- vertically instead of horizontally? Granted your arms might get tired holding the saw up, but if you use a lighter saw and a Granberg small mill, it wouldn't be too bad .
LittleJohn
scsmith42
Tom's 3638D Baker band mill
Jim_Rogers
I cut cookies by standing up a log in my bandsaw sawmill and cutting through them in that position.
But if you don't have a bandsaw sawmill, and only a chain saw. then the challenge is getting the two sides parallel.
If you're going to try and do it free hand, no jig then draw a good line to follow. I used a piece of strap to go around the log to use as a straight edge in a circle, then trace the line with something like a red lumber crayon.
There are frames you can buy to attach to your chain saw bar and it has a pivot on it to hinge the bar back and forth. I had one for many years. Don't know where it is now.
I'm sure there are some on YouTube.
Jim Rogers
aaaice
Treid it on a huge bandsaw, and the result wasnt very good, due to weight of logs, and the surface finish wasnt flat enough. I am sketching up a fixture to make a chainsaw into a chop saw, but will also look into the Granberg . . .
Joe Hillmann
Over in the firewood section someone just posted pictures of a chainsaw chopsaw they built.
https://forestryforum.com/board/index.php/topic,78705.msg1194602.html#new
PaAnkerbalken
Try northern toolhttps://forestryforum.com/board/index.php?action=position"> Note:Please read the Forestry Forum's postion on this company. They have a sawhorse table with chainsaw holder. Used like a mitre table. 40$ smiley_thumbsup
logosol M7
aaaice
Joe, That chopsaw you sent is awesome ! I dont know if I will go that elaborate, as once I get through 250-300 sq. ft. of coins for wall, I may not need it. Paankerbalken, I will go check out northern toolhttps://forestryforum.com/board/index.php?action=position"> Note:Please read the Forestry Forum's postion on this company now, and report back. Thanks, and keep em coming please !
aaaice
OK, I wont mention the company that sells the cheap junk anymore. It did look like something I could modify to do what is needed, but I understand the position, and will go another direction. It looks like the fixture idea / chopsaw will work, but after seeing the post from Joe, I want to have it counterweighted.
low_48
You can loosen the bolt in a Haddon Lumber Maker and it then makes a fine pivot. It would take some rigging, but you just clamp the chainsaw bar into the fixture. Gives you the mount, clamp, pivot, and a way to clamp that to a 2x4 or 2x6.
http://www.haddontools.com/lumbermaker.html
