What is this tool?
Started by Dangerous_Dan, November 12, 2006, 10:39:53 PM
Dangerous_Dan
These things keep showing up at the scrap yard so I grabbed 2 of them.
It has a blade and some adjustment screws for holding whatever it's cutting?
What is it?
First you make it work, then you trick it out!
pigman
The first two look like  a DURO 731. ::)  Sorry I just couldn't resist. I have no idea what they are used for.
Bob
Hmmmm.  Looks more like a 791 ta me.  The 731 had smaller thumbscrews, and was painted green.
Sprucegum
If'n ya put yer thumb in there an' turn thet screw a bit ya could get a answer real quick  ???
They look kinda like a thing-o-majig I seen for makin' leather shoelaces.
woodbowl
Big Nell® makes a tenon cutter, sorta' reminds me of the big bell shaped pencil sharpener configuration used to make them.
There is an antique tool also that makes tenons for cowhide bottem chairs. It's used in a brace & bit.
Full time custom sawing at the customers site since 1995.  WoodMizer LT40 Super Hyd.
Ironwood
Woodbowl,
I have several of each that you had mentioned (both the Bignell, and the antique tenon cutters) These are neither. I have a drawer in my storage area marked "funky holders" these would fit in there for sure. I had something similar which I later used to hold the handles of the saws on my homemade Alaskan mill. It was like they were made exactly for the application. These are very close to those although yours look to have a more specific (deticated) use than mine, Dan.
             Reid
rebocardo
You being "north east", whatever it is, it probably comes from this company
http://durodyne.com/opening.php
(kicking tunes  :D  )
http://www.durodynecanada.ca/canada/
rebocardo
Had another idea, how about a tool to cut off the top of a barrel or something and that is the cutter head that attaches to another tool?
Phorester
I don't know, BOB......, it could also be an upside down 137  ORUD
woodbowl
Quote from: Dangerous_Dan on November 12, 2006, 10:39:53 PM
It has a blade and some adjustment screws for .....
Is it a blade sharp enough to cut wood or is it like a piece of carbide for cutting metal?
Tim L
Looks like a wire stripper to me !
Do the best you can and don't look back
Dana
Hay bailers use a knife setup to cut the twine. This could be a twine or rope cutter for a manufacturing/packaging operation.
Dangerous_Dan
The blade looks like High speed steel and is somewhat sharp.
I was thinking you could put a cork in it and cut the taper spinning the cork by hand. Probably not right but what else could this be for?
customsawyer
That there is a lathe you turn by hand just watch out for the lathe cramps. ;D
www.thecustomsawyer.com
Ironwood
I have seen large machines that cut wooden dowels in unlimited length. IT could be part of one of those machines. They typically adjust to cut differing diameters. Reid
http://www.owwm.com/MfgIndex/Detail.asp?ID=270   Try this link. Reid
Murf
Duro is the name of a very old pump company, they make every kind of pump imaginable, and have for a *very* long time.
Maybe this is some accessory for a large commercial pump, leather gasket cutter for the leathers of a big municiple water pump(s) ???
scgargoyle
Are you sure that isn't the gadget a rabbi uses for... well, you know?
I hope my ship comes in before the dock rots!
Slabs
That looks a lot like my valve rafacing tool for small engines.  If a valve were installed in the screw-clamp instead of the bolt and the missing crank/handle were affixed onto the valve stem, the valve could be reafaced by turning it against the cutting tool.  The thumbscrew would control the pressure of the valve face onto the cutter.
Slabs  : Offloader, slab and sawdust Mexican, mill mechanic and electrician, general flunky.  Woodshop, metal woorking shop and electronics shop.
