Tension
Started by Klicker, May 15, 2021, 04:59:46 PM
Klicker
Do you think maybe there might be a little tension in this cant. 2X8X10ft.
2006 LT 40 HD
doc henderson
Yes.  unless you are sawing so slow that the top is drying faster than the bottom!   :)
Klicker
doc henderson I might be slow but not that slow. Where the dive is it made a crack that could be heard over the mill.
2006 LT 40 HD
doc henderson
I sawed some tree of heaven that did something like that.  good lessons!
Don P
I sawed a tree of heaven that the whole core hopped out of partway through the cut, that stuff is amazing  :D.
Klicker
That cut let all the tension out. When I flipped it over there was no movement in the rest of the cuts.
2006 LT 40 HD
Resonator
Looks like a Poplar I was sawing a couple weeks ago. I cut a flat slab, and no sooner that I stacked it off the mill BANG it cracked lengthwise nearly in two. :o
Klicker
Resenator it is Poplar. I was mainly cutting spruce but buddy wanted some poplar for in the barn for his draft horses.
2006 LT 40 HD
