Husqvarna 66???
Started by derailedbus, February 21, 2004, 07:26:16 AM
derailedbus
Any info on a Husky 66?  I've been searching for days online and can't find info!  A friend gave it to me recently.  It runs strong but needs a new sprocket, and I'm wondering how long a bar I can put on it.  Any help would be greatly appreciated.
Welcome there derailedbus. You dont happen to be a bus driver do ya?
You came to the right place I'll bet. These guys know der stuff.
Kevin
The 66 is 66.7cc.
It will handle up to a 34"bar.
Hawkin50
 ::)Yo Kevin.On the lengh of bar for that husky 266,think maybe 34" bar is a little long.I d suggest a 24" but even better a 20".Just add my thoughts from my expertise.My be He should spin the clutch off and see whats on her for a sprocket.7 tooth  work best in hard wood .If cutting soft wood then stay with the 8 tooth check t6he air filtre and discard the screen in the muffler. Good reliable saw. .Just my opion.Have a good day Hawkin..
derailedbus
Thanks for the help so far, guys!  Just to clear it up, it is a 66 and not a 266.  It looks like it could be from the early 80's as the chain stop handle it metal and looks like one of the first ones used.  I'm definately no expert, but it takes a few good STRONG pulls and it seems to have some power.  I'd be ecstatic with a 24" bar along with my 20" Echo.  I just can't figure out why I can't find anything about it on the internet.  Keep 'em coming!
oldsaw-addict
arent the 66 and 266 models generally the same thing engine wise?  They seem to look quite similar in external apearance. If I'm wrong here then oh well, if not  8) I finally learned something.
Let there be saws for all mankind!
Stan
 Model: 66
MANUFACTURED BY:  HUSQVARNA VAPENFABRIKS AB
  HUSKVARNA, SWEDEN
SERIES OR ASSEMBLY NUMBER:
YEAR INTRODUCED:  1980
YEAR DISCONTINUED:
ENGINE DISPLACEMENT:  66.7cc (4.1 cu. in.)
NUMBER OF CYLINDERS:  1
CYLINDER BORE:  50mm (1.97 in.)
PISTON STROKE:  34mm (1.34 in.)
CYLINDER TYPE:  aluminum with chrome plated bore
INTAKE METHOD:  Piston ported
MANUFACTURER ADVERTISED H.P.:  4.2 (3.1 kW)
WEIGHT :  13.5 lbs., powerhead only
OPERATOR CONFIGURATION:  One Man operation
HANDLEBAR SYSTEM:  Anti-vibration
CHAIN BRAKE:  Inertia activated
CLUTCH:  Centrifugal
DRIVE TYPE:  Direct
CONSTRUCTION:  Die cast magnesium
MAGNETO TYPE:  Electronic
CARBURETOR:  Tillotson HS-224A, B series
MAJOR REPAIR KIT:  RK-23HS
MINOR REPAIR KIT:  DG-5HS/T
AIR FILTER SYSTEM:  Nylon mesh cartridge
STARTER TYPE:  Husqvarna automatic rewind
OIL PUMP:  Automatic, adjustable
OPERATING RPM:
IGNITION TIMING:  fixed
BREAKER POINT SETTING:  none
FLYWHEEL/COIL AIR GAP:  0.3 mm (0.012 in.)
SPARK PLUG TYPE:  Bosch WS7F
SPARK PLUG GAP:  0.5mm (0.020 in.)
CRANKSHAFT MAIN BEARINGS:  Ball
FUEL TANK CAPACITY:  25.4 fl. oz.
FUEL OIL RATIO:  40:1
RECOMMENDED FUEL OCTANE:  Regular
MIX OIL SPECIFICATION:  Two-stroke chain saw mix oil
50:1 with Husqvarna mix oil
CHAIN PITCH:  3/8 in.
CHAIN TYPE:
BAR MOUNT PATTERN:  17 link
SHORTEST GUIDE BAR SUPPLIED:  40cm (16 in.)
LONGEST GUIDE BAR SUPPLIED:  71cm (28 in.)
COLOUR SCHEME:  Husqvarna Orange
PAINT CODES:
Thanks to chainsaw collectors web site.
I may have been born on a turnip truck, but I didn't just fall off.
