Sawmill Engine Upgrade
Started by harmons_ranch, July 02, 2019, 07:06:52 PM
harmons_ranch
I'm running a 10 HP tecumseh engine on my bandsaw mill and have been looking for an engine to upgrade with.  I found this 2 cylinder International diesel (DU-66-D) that was used to power a generator.
It produces 16 HP at 2000 RPM with 45 ft/lbs of torque at 1200 RPM.  It is larger than I was looking for, but it runs well and should do the job.  My setup is a  two post design, but  I will likely have to go with four posts due to the extra weight.  It is also liquid cooled which is not ideal since the radiator takes up a lot of space.  Thoughts and suggestions welcome.
Bruno of NH
harmons_ranch
Quote from: Bruno of NH on July 02, 2019, 07:15:07 PM
What is your lift system ?
I'm using a boat winch, but I have the components to upgrade to acme rod powered by a wheelchair motor.
hamish
Wayyyyy to big for your mill, well over 10X the weight of your Tecumseh
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
sawguy21
X2 By the time you do the conversion you will have been further ahead to use an air cooled
Southside
That must be old technology, I am not exaggerating when I say it is about the same size as my 55HP Yanmar.
White Oak Meadows
Quebecnewf
That looks like a sweet old motor . Would love to have it to drive one of my old planers .
Way to heavy for a sawmill I'm thinking. Maybe do a trade
Quebecnewf
harmons_ranch
Quote from: Quebecnewf on July 03, 2019, 06:08:46 AM
Quebecnewf
It is a nice engine and rune great.  A trade can work; let me know what you have.
