Tongs For Log Skidding
Started by plaindriver, September 27, 2012, 12:02:29 PM
plaindriver
Im a neophyte. Just retired to the Cumberland Plateau region of Tn, leaving Kalivornia far behind.
Got a place on 5 ac, mostly timber, all hardwoods. I already had a small John Deere 750 tractor. Have a bucket and a boom in back. Looking for advice on tongs to drag logs around. Probably nothing bigger than 20-24" dia.
Need advice re brands, size, and especially where to buy. Not in any super rush, an internet order is fine.
thanks in advance
Kubota L4600 DT w/FEL, John Deere 750 4WD w/FEL, PH Digger,RotoTiller,Box Scraper,Disc;16, 18, 20" chainsaws;Troy Built 27T splitter; table saw, radial arm saw,turning lathe, chipper, small backhoe, Isuzu NPR 14' stakeside diesel truck; a wife that still likes me.
I'd be sure to stear clear of anything from the bulk tool catalog places, as most of that stuff are knockoffs. I'd recommend Dixie. Logrite Tools get their tongs from Dixie for the arches so I could not have a better reference than that. Id also recommend you purchase the dixie tongs from Baileys, that way you know that you are getting the real deal.
Per usual, good advice from Jeff.
And I use the tongs to lift the logs, and if moving them far I toss a chain around them for insurance as the tongs can let loose if the log gets to rolling. They are great for getting the log off the ground to get the chain around.
Enjoy the TN life. :)
Another remark on tongs.  Lifting tongs are different from skidding tongs. Lifting tongs are metallurgicaly different than skidding tongs. They are proof tested and certified for overhead lifting and more expensive.
mad murdock
Quote from: Jeff on September 27, 2012, 01:49:04 PM
I would just add a strong AMEN to that statement.  Lifting tongs are a different animal, though they operate and look similar, as with any rigging used and CERTIFIED for lifting overhead loads.
I meant lifting one end of the log. And mine are likely skidding tongs, about 60 years old.
You need a swivel too on the tongs,if there is not one on it.
levans
Plaindriver,
Where are you on the Cumberland Plateau, I'm in Jamestown.
Never Mind, I see where you are.
Slab Slicer
Got a good deal from these folks.  http://www.redhillgeneralstore.com/farm/Dixie-Skidding-Tongs.htm   I picked up the 24" swivel type. Can't go wrong with Dixie's.
2016 LT35HDG25, Kubota L2501 w/ FEL, Kubota BX1500 w/FEL and custom skidding rig, Stihl MS 500i, Stihl MS362-25", Stihl MS250-20", Stihl MS192-18",  2001 F250 SD 7.3, GMC Sierra Dually 6.0 gasser, Peaqua 16" 10K trailer, Sur-Trac 12' Dump Trailer 10K
Chuck
plaindriver
I am a total neophyte to this, but I will try to add pics to this story. I very recently retired and moved from Kalifornia to the Cumberland Plateau region of Tn. (Crossville) Bought a log on a 5 ac parcel, mostly uncut,untamed hardwoods. Some Maples are/were growing too close to house, made it too dark, dropped lots of twigs/branches/leaves and were growing/leaning the wrong way. So, I decided to cut em down. Getting them down wasnt too diff. But there is sure a lot of stuff at the tops to dispo. I have a 14HP Earthquake chipper/shredder and it is an MVP for the process. Rather than cut up all the trunks, I am trying to save the straight stuff for when I pull the trigger on a small mill. So, after I reduce the trunks to 10-12' sections, I need to move them. Havent bought tongs yet, but I do have a boom on the back of my tractor, so I was gonna drag them with a chain. In the process, I accidentally learned a better way to transport them. With this method, I am able to load them into my flatbed truck, which I then park in the barn so they can start to dry out. (We have no animals).
Woodhauler
Looking at some of the contraptions you guys come up with , i wonder why your still alive! ::)
2013 westernstar tri-axle with 2015 rotobec elite 80 loader!Sold 2000 westernstar tractor with stairs air ride trailer and a 1985 huskybrute 175 T/L loader!
Slab Slicer
I see what you mean Woodhauler. That log does have a chance to slip between the bars on that rig, and put a hurtin' on the tractor operator.   OUCH!!!
Chuck
clww
Or that weight so high in the back picking the front of the tractor up on a bump or hill. Just an observation.
Many Stihl Saws-16"-60"
18-Wheeler Driver
Slab Slicer
Hope there is sufficient counterweight in the loader bucket. I built my own rig for the back of my little kubota BX1500. I can skid the logs, or pick them up in the center with tongs. The log is only a few inches off the ground though. No wheelies for me. The 3 point can lift twice as much if not more, than the loader, so it was needed. I know the BX1500 isn't exactly a heavy duty tractor, but for now, it's doing the job. If not, the neighbor is willing to trade lumber for the use of his big ole Dynahoe ;D
Chuck
thenorthman
just a word of advice... Its by far safer to just lift the one end of the log if you plan on skidding it.  logs get heavy and do some strange things when they are only supported on one end.  So for skidding its just better business to lift the end close to the tractor a foot or so and leave the other on the ground, if you need to load that log onto say a trailer etc, then turn it perpendicular to the tractor that way the log can't slip out and take your noggin off,  a guy can move allot of wood just by getting the weight off of one end...
well that didn't work
Tree Feller
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
drobertson
good log tongs are much like good cooking tongs,  most all of them work, just not like you like. You might look at some farm sales where there has been a trac of timber in the family and they did some logging, the old ones are proven, not saying the new ones arent'  Most farm stores sell them and have not seen one yet that wont drag a log. Lifting can be a different story, but most, if they drag, can lift, I just don't make a habit of getting under anything in the air,
