Author Topic: Chestnut oak  (Read 1248 times)
Offline Patrick NC
  • I'm not new anymore, but still pretty green
Chestnut oak
« on: March 03, 2020, 08:15:45 PM »
I finally got my mill to cut fairly straight in oak. Not perfect, but its much better than the first oak log I tried to mill. I got some pretty nice 5/4 x 6 inch boards for my step daughter's deck.
Norwood HD36, Husky 372xp xtorq, 550xp mk2 , 460 rancher, Kubota l2501, Case 1845 skid steer,
Offline GullyBog
  • It's not business, It's personal
Re: Chestnut oak
« Reply #1 on: March 03, 2020, 08:26:17 PM »
Nice!  1x6 is such a useful dimension for oak.  I'm sure it will look good and last a while.
There might be a little dust on the butt log, but don't let if fool ya bout what's inside
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Chestnut oak
« Reply #2 on: March 03, 2020, 08:45:48 PM »
   And it finishes well. These benches are chestnut oak with a tung oil finish.
WM LT35HDG25(2015) , 2009 4wd Dodge PU, Kawasaki 650 ATV, Stihl 440 Chainsaw, homemade logging arch (w/custom built rear log dolly), JD 750 w/4' wide Bushhog brand FEL
Offline scsmith42
    • Whispering Pines Farm
Re: Chestnut oak
« Reply #3 on: March 04, 2020, 04:23:42 PM »
Chestnut white oak is open pored, so it's not the best white oak option for exterior projects.  You're going to want to finish it well with a good stain or other type of preservative if it's exposed to the weather.
Tom's 3638D Baker band mill
Offline Patrick NC
Re: Chestnut oak
« Reply #4 on: March 04, 2020, 06:03:13 PM »
Thanks for the heade up about chestnut oak not being great for exterior construction. I'll be sure to use stain and probably a sealer too.
Offline CCCLLC
  • It's not to big, load it!
    • Carolina Custom Cut
Re: Chestnut oak
« Reply #5 on: March 04, 2020, 06:13:56 PM »
That is looking good. Looks like great progress in the learning curve of milling. Good job!
Offline Patrick NC
Re: Chestnut oak
« Reply #6 on: March 04, 2020, 06:35:35 PM »
Thanks. It's a lot more fun when they actually look like boards instead of wooden snakes!😁
Offline Nebraska
  • Lurked for quite a while, learning !
Re: Chestnut oak
« Reply #7 on: March 04, 2020, 10:36:19 PM »
Wooden snakes, never.... those are rustic milled boards :D
Offline CCCLLC
Re: Chestnut oak
« Reply #8 on: March 05, 2020, 02:52:30 PM »
I see the price going up when you mentioned rustic. Good job.
Offline Ron Wenrich
Re: Chestnut oak
« Reply #9 on: March 07, 2020, 09:38:10 AM »
In my area, chestnut oak seems to be prone to shake.  Sometimes it doesn't come up until it starts to dry.  Those dark mineral streaks are areas most likely for it to form.  Things are different from region to region within the same species.  So, your experience may be different.
Offline Patrick NC
Re: Chestnut oak
« Reply #10 on: March 07, 2020, 02:45:36 PM »
Thanks for the info. I've not heard of that being a problem around here, but then again I'm pretty new to milling.  I hope that's not the case around here as I have about 11 acres of chestnut oak.  I'd hate to have 11 acres of firewood.
Offline Patrick NC
Re: Chestnut oak
« Reply #11 on: March 12, 2020, 01:28:18 PM »
Looks like you were right.  A lot of the boards I cut are starting to show ring shake( I think. When I googled it that's what it looked like.) I wonder what the percentage of trees will have that?
Offline Ron Wenrich
Re: Chestnut oak
« Reply #12 on: March 13, 2020, 08:44:19 PM »
I think its caused by a bacteria.  Pin oak gets it, and it stinks when you cut it.  It has those dark streaks and they also are prone to ring shake.  Black oak gets what we call mineral streaks.  Its usually a black streak.  I had a lumber grader tell me that often turns to shake when it dries.  It isn't mineral, its bacteria.
I've cut some really nice chestnut oak.  It usually grows on the lower sides of the mountains on fairly decent soil.  Chestnut oak is also called rock oak, because it will grow in rocky areas.  Those trees are slow growing, and the quality isn't very good.
