How to use a range of wood species in same project
Started by MillbrookMills, May 17, 2023, 05:06:06 PM
MillbrookMills
I have access to good sized timber for milling in my area.
The issue I have is there is not one species with any volume so I would cut Balsam Fir, White Spruce, Austrian Pine, White Pine and Colorado Blue Spruce.
If I make cabin logs can you have different varieties of log used?
Perhaps I can stagger them for interior walls.
Just not a big wood worker so trying to find one big project for all the species at the same time.
(first post and have read this forum for years and you guys are the best for information!)
Use one species on the lower ~30" as a wainscotting and then another species above.  Use one species on one wall or opposing walls and then another species on the opposite walls.  There are many options to mix it up in a pleasing way.
MillbrookMills
Thanks Magicman. I have read your posts for some time and appreciate the great advice!
You are very welcome.  I failed to mention to orient some horizontal and some vertical to further mix it up.
jpassardi
One positive you have going for you is that those species are somewhat similar looking. Some of them you could likely mix and no one but you would know.
Brad_bb
I don't know where you're building it, but one thing I think about is weather exposure and rot.  In the midwest and south log cabins that are exposed don't seem to last long term.  There are a lot of log structures that were originally covered and that protected the logs/outside.  When people repurpose log structures today and build and leave them exposed especially hardwood in the midwest and south, you see water and bug damage over time.
I love the big old hewn logs, but if it were me, I'd cover them structure on the outside and you can expose them on the inside.  Maybe in an arid or semi-arid region they live a lot longer exposed...Just my perceptions.
MillbrookMills
Building up in Ontario Canada. woke up to frost today. ugg.
Good points on the weathering issues.
