Storing logs under water?
Started by mjeselskis, May 17, 2012, 07:36:08 PM
mjeselskis
I did a quick search and didnt find anything on the topic.
If I have some white pine, hemlock, and red oak that I won't be able to cut this year, could I drop them in my pond and store them until next summer? The pine is my primary concern, I don't want the pineborers to get into the logs and bore holes all through them. The oak may be able to sit out, but I got thinking about it the other day and didnt know if storing them under water would be an option.
2006 WM LT28  1993 John Deere 5300
Husqvarna 562XP & 365 X-Torq
Texas Ranger
In the old days mill ponds were the thing, now they use sprinklers to keep the logs wet.  No harm in trying.
Chuck White
If you're just concerned with the Pine you could peel the bark off of them and then the Pine Beetles won't bother it!
laffs
Im sure it would help with the bugs, and it will definitely will help keep the bluestain down. They used to do it all the time.Now they use sprinklers. Some mills have heated ponds or pools for thawing frozen logs in the winter tho it mostly just thaws the outside. But if I wanted to store pine for some time Id toss them in a pond.
timber harvester,tinberjack230,34hp kubota,job ace excavator carpenter tools up the yingyang,
Your own pond? Nice! How big? Any fish in it? I'm sawing hemlock now and the bark is coming off good now.
The hemlock will do fine with bugs. My Father wanted some planks and we cut down a hemlock. We got busy and did not get back to it for 2 years and it was fine. But we put some limbs under each log to keep it off the ground. This was in the woods too not out in the direct sun. No idea about the oak,but the pine bores will find the pine.
Bogue Chitto
I store logs in my pond.  Some have been under water for over 7 years( pine and oak).  The smell is bad when you mill them but that will go away in a few weeks.
Bogue Chitto
I live in Louisiana and the temperature of the water in the summer time is high.  Your water temp. might be a lot cooler than ours and you might not get the stink. :-\
I sawed a job last year that, according to the customer, had been in a pond for over 20 years.
barbender
I wish I had a pond to store logs in, if that answers your question ;)
chevytaHOE5674
Quote from: barbender on May 18, 2012, 09:56:27 AM
Get a Backhoe or excavator and start digging.  :D
wdtik
 Theres an operation up north raising old growth logs from
a lake and milling them, said to be over 100 yrs old..
I'd like to get some of those logs to mill .... CBD
wdtik
Where "up north" is the lake?
Bogue Chitto
The bark will come off but the wood will be perfectly preserved.
wdtik
wdtik
shelbycharger400
wdtik..  i was wonderin as we drove through montana if their was big logs still on the bottom of the lakes.  those mountains still have the drag shutes and carved in roads in them.
as to peelin the bark...   Dont.  i have noticed the logs around here that i peeled dried too fast and cracked, whereas the ones that i didnt, have sat for 2 years and havent.
two tired
i pulled 2 logs out of my pond just to see what would happen when i sawed them, did smell sour when i cut them, the logs were swamp pine, they cut like butter. stacked them outside, 2x4s, to see if they would split or warp. been 2 months or so and they look as good as the ones that were sawn green, also the sour smell is gone, i live in southwest louisiana. by the way they have been in the pond about 2 years compleatly under the water.
when wondering about weather conditions call the dog in and see if he is wet
mjeselskis
Quote from: thecfarm on May 18, 2012, 06:44:28 AM
It is my pond, it's about 50x100 and about 6ft deep at the deepest point. Nothing in there but shiners, it gets too warm for any game fish. It makes a great ice skating rink in the winter too. It may be more work to move the logs to the pond, than to just saw them, but its good to know it's an option. I'm hoping to just take a day and get it done, but we'll see how it goes.
What is the plan to keep them under water? Or are you just going to let them float?
mjeselskis
Quote from: beenthere on May 18, 2012, 05:47:14 PM
That's what my wife asked me. I actually hadn't considered that. I guess they could float, only a small part of them would be above the waterline. I dont know how long it would take them to sink.
I do like this option though. I could yard out logs in the winter onto the ice, and then just pull them out of the pond in the summer when I am ready to mill. That way they stay clean because I can yard them out in the snow, and no more worrying about the logs going bad and rushing to saw them.
Satamax
Hi everybody.
If i may, in French Britany, they used to leave oak beams in the estuaries of rivers which had tidal movement, being covered by saltwater only part time, and siting in silt. It's nearly impossible to cut when dry, very hard to burn. They were sunken in the silt green, and when drying, or exchanging fluids via osmosis, and minerals would get in the wood. This dulls the blades quickly. If this can be of any interest for someone.
Bogue Chitto
The logs that I put in the pond eventually sink.  The bad part about that is getting the logs out in winter. Its hard to get a chain around a sunken log.  I end up getting in the freezing water. :o
Bogue Chitto
Quote from: Bogue Chitto on May 18, 2012, 09:24:01 PM
Tie a length of rope around each log and keep one end within reach. Then just "fish" them out. 1/4" nylon rope will last for years and is not expensive.
