Drying wood in my green house
Started by campy, June 20, 2010, 01:54:07 PM
campy
We have a small bandsaw operation on the farm along with a green house.
Would it be helpful to dry small amounts of lumber in the green house.
This would be for personal projects.
The temps get to 150F degrees inside at the solar peak.
There is also a fan built in to circulate the air if needed.
What would be a good process, if any, for Black Walnut boards 1" thick?
https://forestryforum.com/gallery/displayimage.php?album=2890&pos=0
How do I get the photos to appear in the thread rather than linking to it?
Appreciated....
PC-Urban-Sawyer
You use the img tags around the url of the photo file in the gallery. If you go to the gallery and click on a photo, there's code in the bottom half of the gallery window that can be copied and pasted into your post:
Hope that helps and good luck with the walnut.
Herb
