Board feet spread sheets
Started by Tony, March 15, 2005, 08:24:08 PM
Percy, to attach a document is different then pictures. Start a post, (you must have text in your post,  you cant just attach) then, just under where you type is a link that says >Additional Options...
Click that and it will reveal the attachment facility. Browse to your file and then select "open" the file address will then be in the input area. Then simply click the "post" button. the file will upload and be attached to your post.
This does not work on photo files. Only documents with extensions that I allow.  txt,doc,pdf,xls
PhilD
Here's 2 that I use... (if I can get this to work)
First is a log scale/bdft estimate.  One column is one of the standards (International, I think?), the other is closer to what I get out of a bandmill.
Second is a bdft calculator setup with $0.30/bdft calculator which can easily be changed.
Junior437t
Here is a good sheet that I use.
Gilman
Here's one we use for beam quotes, you could also use it for dimension lumber.
The only thing different about this spread sheet is how I formatted the cells to include "/" and "bf" in the cells.
It makes it a little easier to read when cutting a beam order.
WM LT70, WM 40 Super, WM  '89 40HD
Cat throwing champion 1996, 1997, 1999. (retired)
sawyerkirk
Best thing I ever found was a little slide rule put out by woodmizer, I always keep a stack of them handy, call em, I'm sure they'd send you one
Percy
Says I cant upload that type of file (wks).  Ill try again later Jeff.
Is that MS Works file extension? I went ahead and added it. You should be able to upload now.
Percy
Here Goes.(Thx Jeff)
Just enter the amount of a particular board into the appropriate space and the board footage appears just below woth a grand total of all board feet at the bottom. I built this seveal years ago and it still works real good...for me anyways ;D
FeltzE
Try this one, well forget it, it's a 1 mb file scanned in from the original.
I can't win, Just have to email it to anyone interested.
Eric
Tony
THANKS EVERYBODY... I APPRECIATE ALL THE INFO ,IT WILL HELP ME TREMENDOUSLY.
                                      THANKS AGAIN, TONY smiley_clapping smiley_clapping
TK1600, John Deere 4600 W\frontendloader, Woodmaster718 planer\moulder, Stihl MS461 Stihl 036 & 021 & Echo CS-370
"You cannot invade the mainland United States.  There would be a rifle behind each blade of grass."  Adm. Isoroku Yamamotto ( Japanese
KiwiCharlie
Hi Tony,
Dont you mean tree-mendously ??  :D  ::)  Sorry about that!  ;)
Now, for all us upsidedowners, is there any formula for estimating how many cubic metres of wood in a given log?
Or for that matter, the metric equivelent of what this thread has been about?
Cheers
Charlie.
Walk tall and carry a big Stihl.
GF
   I sent the one to you in the past you had posted, I have now on my website http://www.twistedoaksawmill.com select the link called "Log Scale" its has all of them in one sheet.  You are welcome to take it and put in back on the forestry forum website.
GF
Forgot to mention that its an HTM page.
Jeff you may need to clean some of the code out of it.
Russ
I use a chart like this to total my board feet for the day. Let me know if this is useful.
http://equinox.shaysnet.com/~logger/chart.htm
smwwoody
I got these  ones a while back from somewone on here I made A few changes to suit me better It would be fine for a part time mill but too much for a full timer to input
Woody
Full time Mill Manager
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
Pendu slab recovery system
KJ4WXC
smwwoody
here is the soft wood one
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
KJ4WXC
