Mikron computer setworks for Woodmizer sawmill (discount coupon inside)
Started by rliuts, August 05, 2024, 10:57:17 AM
rliuts
The SW-350-PRO-WM computer setworks is an innovative upgrade crafted to boost the precision and efficiency of your Woodmizer sawmill. This user-friendly and easy-to-install system is suitable for sawmills of all ages and models (including those produced before 1997). Many forum members have been seeking a reliable solution compatible with these older sawmills, and the SW-350-PRO-WM fits the bill perfectly. It's a dependable choice that increases productivity, reduces waste, and maximizes lumber yield, offering a range of features designed to streamline your operations.
Our customers love the SW-350-PRO-WM for the boost in productivity and the ease it brings to their operations. It's a proven choice for those looking to modernize their sawmills without hassle.
Best of all, the SW-350-PRO-WM computer setworks installation does not require any modifications to your sawmill's electrical or mechanical components. There's no need to change the lifting mechanism, gearbox, or sprocket. The system integrates smoothly, maintaining the integrity of your original equipment while adding advanced functionality.
The set includes:
  • SPRT-500 SMART Sensor: This high-tech sensor includes a convenient bracket, bolts, and nuts for easy installation. It's designed to plug and play, so you can get started without a hitch.
  • Computer Setworks Control Panel: Built tough with IP65 protection, this control panel can handle the rigors of a sawmill environment. Whether you're working in extreme cold or heat, it performs reliably from -30°C to 55°C (-22°F to 131°F).
  • Accessories: Bracket, bolts, and nuts for the SPRT-500 sensor installation, plus other necessary accessories.
  • Preconnected wires: Setting up your new system is a breeze with preconnected wires that make the process as straightforward as possible.
Special Offer for Forestry Forums Members and Guests!
We're excited to offer an exclusive $120 discount on the SW-350-PRO-WM! Simply use the coupon code FFWM8PERC at checkout.
This offer is valid until August 24, 2024. Don't miss this opportunity to enhance your sawmill at a fantastic price!
If you have any questions, feel free to write them below this post or contact us via email at info@mikronglobal.eu.
You can also give us a call at 678 399 1995.
Our call hours are 6 AM - 3 PM EST/EDT.
We're here to help!
rliuts
We received some questions via email regarding the installation of the SW-350-PRO-WM computer setworks on Woodmizer sawmills.
To help out, I've put together a quick guide to assist with the installation process.
The SW-350-PRO-WM is designed to be a straightforward installation on almost any Woodmizer bandsaw mill, including popular models like the LT15, LT35, LT40, LT70, and others. One of the key advantages is that you don't need to modify the existing electrical schematics or mechanical setup of your Wood-mizer sawmill. The setworks comes pre-connected, so the installation steps are minimal:
  • Install the Control Panel: Mount the control panel in a convenient location on your bandsaw mill.
  • Install the SPRT-500 Sensor: Secure the sensor in the appropriate position for accurate readings.
  • Make the Necessary Connections: Connect the setworks to your bandsaw mill's existing system.
The setworks will interface with the drum switch and the device controlling the lifting and lowering of the sawing head. Depending on your mill's setup, this could involve:
  • An H-bridge,
  • Solenoids,
  • A PWM driver (for those who have opted for this instead of solenoids),
  • Or a winch relay.
  • etc.
Below are the general connection schematics:
For those with an LT40 produced before 1997, we recommend using a winch relay for the installation. Connection schematics for the LT40 (pre-1997) are shown below:
By following these steps and schematics, you should have your SW-350-PRO-WM setworks installed and operational without much hassle.
Limited-Time Offer: Use code FFWM8PERC at checkout before August 24, 2024, to claim your discount of $120.
Link to SW-350-PRO-WM
Our contact information:
Email: info@mikronglobal.eu
Website: www.lyuts-tech.com
Phone: 678-399-1995
Call Hours: 6 AM - 3 PM EST/EDT, Mon-Fri
rliuts
Time is running out! There are only 2 days left to take advantage of our exclusive offer on the SW-350-PRO-WM computer setworks for your Woodmizer bandsaw mill.
Use code FFWM8PERC at checkout before August 24, 2024, and save $120 on your purchase!
Don't miss out—upgrade your mill today and boost your efficiency.
