What is This Tool?
Started by tcsmpsi, June 13, 2011, 12:35:07 PM
tcsmpsi
I was looking for some particular, small hinges yesterday, which were hanging in the same area as this tool (has nothing to do with hinges, though).  I suppose it has been about 20 yrs since I made it.  Thought it might be interesting to see if anyone could determine its use.    ;D
\\\"In the end, it is a moral question as to whether man applies what he has learned or not.\\\" - C. Jung
D Hagens
Do you have any closer pics? Also pics of the underside?
Brad_bb
Hard to see the details of what's in that block in the middle.  A home made spoke shave?
tcsmpsi
The underside, is the same as the topside.  It is a slot, and that is a brass sheet wrapped around one side.  In the top of the photo, are  the corners of two 1/4 sheets of sandpaper, which should help for size determination.
Warbird
Looks like the business end of a large handmade jointer.
The carriage bolts on each end threw me, but my first thought was a burnishing tool, when I found that it had a brass sheet wrapped around one side.
We used to burnish oars and baseball bats to make them tougher to break and to make the contact area of the bat harder.
tcsmpsi
The carriage bolts are used to tighten what goes in the slot.     :)
The slot?  Oh!   Oh yeah, the slot! :-\
tcsmpsi
I know, it could have been a better picture of representation.  It was just a whim of the moment at the end of a long day, and I'm not there to take another, presently.
Well, I'm baffled and look forward to the explanation.  :)
Ernie
Whatever it is, we all obviously need one or maybe even two so we'd have a matched pair.
sprucebunny
A scraper holder ??? You set the 3"x4" blade (approx) between the 2 bolts ?
tcsmpsi
Not quite...but, you are on the right track, in that it is a holder....for multiples.   ;D
tcsmpsi
Ok....it is a holder to keep steel stamps corraled.      ;D
Though my photographic effort on the close up is less than desireable (doubt it has much to do with my old camera), that states, "THE FORUM".   I originally made it for firearms stamping.
The brass wrapping bulges out just a little inside to keep pressure against the stamps from that direction.
That's a might fine idea, but I'd never have guessed it.  :D
Anytime that I put a metal stamp on a letter, the post office sends it back.  Maybe things are done different in Texas.
Wait, let me re-phrase that...."Things are always done different in Texas".  There, now I feel better.
tcsmpsi
Quote from: WDH on June 15, 2011, 09:31:44 PM
Well, you're kinda half-right...the rest of the world does things different than we do.  For some cockamamie reason or 'nother.   :D
You just probably weren't using priority mail.    ;D
caveman
A friend of mine has brought this by twice now asking me if I know what this tool is or what it was made to do.  I figured with all of the knowledgeable people here, someone would know.
Caveman
jrsloan1
Caveman, good talking to you yesterday evening. Can't say for sure but it kinda looks similar to a valve spring compressor.
Never trust nobody cause you can't fix stupid!!!
Don P
What is printed on the castings?
Jack S
maybe a hand held tire bead breaker
caveman
All that I can make out in the pictures is made in usa, and pat pending.
Caveman
rusticretreater
I believe it is a clamp to hold and screw threaded end pipes together.  Possibly used to drill water wells or build irrigation systems.
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
sharp edge
Maybe... ues to hand tie shocked oats.
SE
The stroke of a pen is mighter than the stroke of a sword, but we like pictures.
91' escort powered A-14 belsaw, JD 350-c cat with jamer and dray, 12" powermatic planer
Quote from: sharp edge on April 23, 2024, 08:10:41 AMMaybe... ues to hand tie shocked oats.
Actually this would be the tool for that:
DSCN0323
DSCN0320
DSCN0324
DSCN0325
DSCN0329
It has been in my family for well over 100 years.
