Author Topic: Bar for a ms461?  (Read 1573 times)
Offline Maine logger88
  • Don't force it get a bigger hammer
Bar for a ms461?
« on: October 16, 2017, 08:08:40 PM »
It has come time to replace the saw that the guy that works for me runs and he really wanted to try a 461 so I bought one the only trouble is I have about 15 bars for my husky and jonsered saws that all use the .058 chain and itís a pain to buy 0.50 chain for one saw as I buy all my chain on bulk. My question is can I get a bar that fits the stihl in .058? The .058 is also much more common in this area which I know is odd but thatís how it is
Offline sweetjetskier
Re: Bar for a ms461?
« Reply #1 on: October 16, 2017, 08:46:33 PM »
Most Stihl mount bars in 3/8 are going to be .050 or .063, however there are some bar adapters out there that may work for your needs, someone may have more info on adapters. 461 is a great saw, good luck.
Arborist, Horticulturist, Nursery and Turfgrass Professional with 27 years experience.
Offline HolmenTree
« Reply #2 on: October 16, 2017, 10:37:10 PM »
Stihl did make .058 sawchain for the competition but I can't remember ever seeing a Stihl bar whether made in VB USA or Germany in .058.
Here's  a pic of my Stihl bar adapters for a Stihl 3003 mount to Husqvarna bar mount. Have a bunch of these for almost 30 years. Part # is rubbed off the bag.
How about the 28 year old Stihl Gas and Oil Mix tag to put on the handle of your gas can.
No confusion for straight gassing with these.
« Reply #3 on: October 16, 2017, 10:44:12 PM »
Thatís pretty cool holmen! Those adaptor clips are for mounting stihl bar on a Husky right? So I assume that you canít go the other way and put a Husky bar on a stihl? That gas tag is cool too!
Offline HolmenTree
« Reply #4 on: October 16, 2017, 10:49:45 PM »
Yup for a Husqvarna bar stud. But a Husky bar won't fit a Stihl.
They made good stuff back in the day :)
Offline HolmenTree
« Reply #5 on: October 16, 2017, 10:52:32 PM »
Even if you turned the Stihl bar studs down to fit the Husky bar slot, the offset Stihl tensioner worm gear screw will not clear the narrow Husky slot.
« Reply #6 on: October 16, 2017, 11:29:39 PM »
Ok thanks for the info! Looks like Iíll either have to find someone who makes a bar for the stihl Mount in .058 or just buy both in bulk which is probably what Iíll end up doing...
Offline HolmenTree
« Reply #7 on: October 17, 2017, 03:14:40 PM »
All you have to do is lay a Stihl 3003 mount bar on top of your Husqvarna  .058 bar.
Use a fine point permanent marker and mark the Stihl slot on to the bottom Husqvarna bar.
Stick the Husqvarna bar in a bench vise then with a 4.5 inch side grinder grind out the slot to the marks.
If needed you may have to drill a new adjuster pin hole which is easy enough as the bar is not hardened near the slot.
 I'm talking about a good quality solid body bar not consumer laminated. But laminated will still drill ok.
« Reply #8 on: October 17, 2017, 06:02:15 PM »
Ok thanks i will try that on a couple bars! It's probably silly to be that worried about it but I just like all my stuff the same for simplicity of it. That was why I would never buy a husky or jonsered with the small mount because I never wanted to stock more than one type bar. Which that is out either way with the stihl but at least if I modify a couple bars I can run the same chain. If I didn't have so many bars already I would just switch my huskys over to .050
Offline teakwood
  • Switzerland
« Reply #9 on: October 17, 2017, 10:03:59 PM »
Maybe in some months we will hear from you that you changed all bars and chains to .050 or .063 because you liked the 461 so much that your changing all your saws to stihl :D :D
« Reply #10 on: October 18, 2017, 12:32:40 AM »
lol lol lol possible but unlikely I have a real love for the 2166/2172 saws I have! But that 461 does seem to be a nice saw!
Offline ehp
  • logger/chainsaw hack
« Reply #11 on: October 19, 2017, 07:13:02 PM »
461 is a good saw , I got lots of them LOL , I am waiting to try the new 462 thou , oh ya I seem to have a lot of 365/372 to and like them as well but in the cold of winter the 461 arctic wins hands down , them hot handlebars are sure nice to run
New MS461
Started by JJinAK on Chainsaws
Last post May 22, 2017, 12:51:13 PM
by khntr85
ms461 stihl
Started by doghunter on Chainsaws
Last post July 02, 2013, 10:08:02 PM
by saxon0364
Ms461 muffler mod
Started by Parmstrong191 on Chainsaws
Last post March 29, 2021, 11:24:05 PM
by Parmstrong191
MS461 & .404 CHAIN
Started by joe_indi on Chainsaws
Last post February 05, 2014, 08:18:56 PM
by woodstoveheat
