My $40 Jonsered 2171
Started by celliott, June 30, 2015, 04:18:43 PM
celliott
Few months back, saw (hehe :D ) a Jonsered 2171 listed on craigslist for $40, didn't run. I jumped on that FAST!
Met the guy, saw was locked up tight. Said he thought it was straight gassed early in it's life, then ran some more on mix. I bought it.  8)
Expected to probably replace the cylinder. Opened it up and found a piston that certainly wasn't straight gassed, a cylinder in fine condition, and this-  :o
Big end bearing in the crank disintegrated! A piece of the bearing was preventing the saw from turning over once it reached TDC, and it couldn't go back against the starter, so it was "locked up". With the condition of the piston and cylinder being so good, I'd guess that it was a factory defective crank maybe? Thoughts?
The general condition of the saw (minus the crank) led me to believe this was a very low hour saw. I don't think it's had more than 10 tanks of fuel ran through it. Still had the stickers on the bottom of the tank. This is a 2003 model saw, too.
Well, I got a used crank for cheap, got some nachi bearings, a seal\gasket set, and threw it together. Used an OEM 371 piston with a new caber ring. It got the works- gaskets, seals, carb kit, fuel line, filter. Once I got it all together I used a husky 266 exhaust deflector and made up a dual port muffler.
Here's the end product. I'm pleased   :)
It's in pretty darn good shape. The black paint they use on Jonsered handlebars seems like the new Husqvarna silver- it flakes off if you look at it wrong. But hey, paint doesn't cut wood  ;D And this saw will cut wood, not live out life on a shelf  :D
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
celliott
And a short video to prove that yes, it really does work  :D
Red spruce, semi skip oregon chisel chain with about 1\4 life left, and an 8 tooth sprocket.
http://www.youtube.com/watch?v=uW-Z9nxJ5FM
Chris Elliott
265rx clearing saw
sawguy21
You made out like a bandit with that one.  ;D
celliott
Quote from: sawguy21 on June 30, 2015, 05:51:36 PM
Indeed  ;D
Briefly thought about flipping it. Around here, a 2171 in that condition could probably bring $500-600 local sale without much trouble. Get a return of more than 4x my investment? Nah, keeping it  8)
Chris Elliott
265rx clearing saw
AdkStihl
 Looks more like the affects of 50:1 or leaner to me
J.Miller Photography
celliott
Quote from: AdkStihl on June 30, 2015, 10:38:44 PM
I don't know. Think 50:1 would do that in just a few tanks? Bearings were fine too. Maybe dino oil at amsoil ratio? Everything else looked good. As good as it could after being run with that crank anyway.
Chris Elliott
265rx clearing saw
kellysguy
I got my '03 365 in a similar state, perfect piston and cylinder, burnt rod big end. In my case it was a well used saw that seems to have been over rev'ed with a dull chain. Mine was free with extra bars, chains and tools but I'm still jealous.  :D
dougand3
Super deal and good job on rebuild!
sawguy21
I would not expect a lean mix to take out the bottom end yet leave the p&c unmarked. Possibly a quality control issue or over revving. Either way, it's good for you.
celliott
Quote from: sawguy21 on July 01, 2015, 11:43:43 AM
Yeah, I didn't think it was fuel related. Over rev sounds possible too.
It is good, otherwise it would be another 2171 that was half beat to death, and I probably wouldn't have got it.
Chris Elliott
265rx clearing saw
kellysguy
Quote from: celliott on July 01, 2015, 03:44:08 PM
Wouldn't have gotten it otherwise at $40?!?!?
You're obviously a man with a profound sense of value.   ;D
clww
Great find and rebuild. 8)
Many Stihl Saws-16"-60"
18-Wheeler Driver
celliott
Quote from: kellysguy on July 01, 2015, 07:26:27 PM
Still woulda bought it for $40 if it was missing half the plastic and the crank was poking through the bottom of the case  :D
But I meant that if it never grenaded, it would probably either still be running somewhere or trashed, and I wouldn't have had the chance to buy it.
And thanks for the compliments everyone, I am happy with the saw.
Chris Elliott
265rx clearing saw
SawTroll
Quote from: celliott on June 30, 2015, 08:30:43 PM
Indeed  ;D
Surely you are keeping it - very nice saw!  8) 8)
Information collector.
