Author Topic: Chimney question  (Read 1561 times)
Offline Raider Bill
  • Who will pull the wagon when everyone rides?
Chimney question
« on: September 13, 2008, 06:35:19 PM »
How high does my pipe need to be from the roof?
the side the metal chimnney is going on is 24' wide with 6-12 pitch.
Pipe is in the center at 12' from peak and eaves.
No trees or obstructions around it.
I'm thinking 36"-48"?
Is there a spell checker here?
The First 60 some years of childhood is always the hardest.
Offline sawmilllawyer
  • Ride hard, die free.
Re: Chimney question
« Reply #1 on: September 13, 2008, 07:24:19 PM »
Don't know about spell checker on here but the top cap of my chimmey is approximately 4 feet above the roof. Hope this helps.
Stihl MS-361, MS-460 mag, Poulan 2150, 2375 Wildthing.
« Reply #2 on: September 13, 2008, 07:29:53 PM »
Most of us are using the spell checker on the Google tool bar.  It checks any open post creation window.   The only other alternative is to build the post in your email program and paste it here.
Offline mike_van
« Reply #3 on: September 13, 2008, 08:00:20 PM »
Bill, the code here is 4 ft higher than anything within 10 ft of it - But, it could vary by state or local codes.
I was the smartest 16 year old I ever knew.
Offline Toolman
  • "DONT TREAD ON ME"
« Reply #4 on: September 13, 2008, 08:02:49 PM »
Might want to check your local zoning laws. Our Twp. requires 24" above highest point of roof(peak). Mine is 28" above my peak. My neighbor has his about 36" above peak due to surrounding trees and a hillside that was causing downdraft on windy days.
"A government big enough to give you everything you want, is strong enough to take everything you have" (Thomas Jefferson)
Offline Ron Wenrich
  • Forester
« Reply #5 on: September 13, 2008, 08:03:52 PM »
My Firefox has spell checker built in.  IE doesn't have it.
Can't help you on the chimney.
Online beenthere
« Reply #6 on: September 13, 2008, 08:32:46 PM »
Google on chimney height code, came up with several hits...one refers to a national code.
http://www.usinspect.com/car/0104TechJargChimneyHeight.asp
Offline PineNut
« Reply #7 on: September 13, 2008, 08:55:51 PM »
At one time I had a chimney that was 4 ft higher than any structure within 10 ft. It met the code but did not work. At about 11 or 12 ft, the builder had another story and that went several feet above the chimney. That installation was a disaster unless you wanted a smokehouse. Other houses were built the same way and they all had the same problem. Extended the chimney up by 2 feet and the problem went away even though it was still below the roof line.
Offline Don P
    • Calculator Index
« Reply #8 on: September 13, 2008, 11:21:37 PM »
2' above the highest point within 10'. I like to be above the ridge if at all possible though. Unfortunately the ridge is about 600' above us here  ;D.
Owb chimney question
Started by Dairyman on Firewood and Wood Heating
Last post January 23, 2021, 08:12:51 PM
by E Yoder
OWB Chimney question
Started by Arctiva on Firewood and Wood Heating
Last post December 27, 2019, 11:00:56 PM
by E Yoder
Chimney/woodstove question
Started by tyb525 on Firewood and Wood Heating
Last post December 22, 2010, 08:34:36 AM
by Handy Andy
insulation around chimney question
Started by yukon cornelius on Firewood and Wood Heating
Last post December 24, 2013, 11:22:12 PM
by sparky23
