Need help
Started by Delmer, May 29, 2024, 05:04:58 PM
Delmer
Hi.Delmer here,I am new to this forum and new at milling.
Was wondering if there was anyone that could help me set my blade on the saw (LT50 Super), I am doing something  wrong and don't know what to do. I live in the Hawkins,TX area.
Thanks Delmer
Digger Don
Hi Delmer. Welcome to the Forum. I can't help you with the blade, but I'm sure someone will before too long. I'm sure that one thing that will be suggested is to put your location in your profile. It's easier to find it there than in the message.
I'm thinking some of the more knowledgeable folks will want to know what symptoms you are struggling with. How do you know it the blade? Give them some more details. There is a lot of knowledge here.  Good luck taking it all in. And, with the blade problem. Don
Timberking B20, Magnatrac 5000, Case 36B mini excavator
SawyerTed
Welcome!
Yes more details would allow everyone enough info to help.
YouTube has many videos.
Here's one from @customsawyer
https://youtu.be/nnftLVwGqaI?si=8j-mUugOJ5DhMqlN
If for an LT 70 and the hardware on a 50 is a little different now.  The idea is the same.
Quote from: Delmer on May 29, 2024, 05:04:58 PMWas wondering if there was anyone that could help me
FF Member E-Tex has an LT50 and lives in Jacksonville and owns a Farmers Insurance Agency.  You may be able to reach out to him.
doc henderson
hello Delmar.  Are you putting a blade on the mill, or sharpening and setting the tooth on the blade?  Or setting an adjustment on the blade tracking?
SawyerTed
If you are sharpening and setting the Woodmizer Blade Handbook is a really good resource.
An internet search will find it.
Southside
Did you put the band on backwards?  I have heard that they will make a really strange noise when that happens. Like I said, I have heard that, from a friend, yea that's what happened.  ffcheesy
White Oak Meadows
terrifictimbersllc
What do you mean by set the blade on the sawmill? "Set" usually means the distance a tooth is bent out to the side or to bend a tooth out to the slide of the band.
doc henderson
he was last active when he made his first post.  had registered days before that.
