-What real engines look like-
Started by BargeMonkey, May 03, 2014, 10:35:18 PM
BargeMonkey
I know its a bit off the "logging-forestry" topic but anyone who loves big bore engines might like this. Theres a pair of 8-710G7 Emd's. Baby engines but still not bad. 2k-hp each at 900RPM.  9-1/16th bore by 11" of stroke. My new home away from home.
sawguy21
That would run one heck of a mill. :o
SliverPicker
11671 lb/ft of torque from each engine.  Not bad..... :D
Yooper by trade.
Maine logger88
That's sweet! Are they 2 stroke?
BargeMonkey
Quote from: Maine logger88 on May 03, 2014, 11:15:11 PM
Yup. 4 valves per hole. 1 large unit injector. About 10k per hole for a head-and piston-rod assembly. The emd design close to this came out around 1936. The boats landing on the beach on D-day where emd powered. Most people have never seen 1, alot of them still used in locomotives. If your a detroit guy, you sit in awe just watching one of these run. These are baby's, im used to the 16 and 20cyl versions making 6-7-10k hp combined.
LeeB
Those are good size engines, but they are baby ones. EMD makes much bigger than that.
sprucebunny
Nice !!
I got a tour of a ship years ago that the engine was taller than my house  :o
Bore was around 36" .
timberlinetree
Must take a lot of oil in the crankcase. :o. Neat to see thanks for posting.
I've met Vets who have lived but still lost their lives... Thank a Vet
Family man and loving it :)
ozarkgem
So you work on a Tow Boat to support your logging habit?  I was on a ship in Texas in the 90's and they had a Fairbanks Morse engine. Huge. I was a 2 cycle and ran 180 RPM . They had a lever that changed the timing  and that would reverse the engine and since it was direct drive,the ship. Ran on bunker C. It was an old ship then. Nice pics. I dream vacation would be going through ships and factories.
HiTech
Ken
Thanks for posting the pics.  How much fuel do they burn and what are you carrying on the barge?
snowstorm
it must have been a big landing craft to use that motor. the smaller ones had 2v 671's. also had a battle setting on the governor that let the motor over turn by quite a lot.  dose that tug your on have pod drive?
LeeB
A 16 cylinder version of the same kind of EMD. Not nearly as clean though. Power end for one of three generators on an old drilling rig I used to work on.
LeeB
Deafening. May have something to do with why I wear hearing aids now. You think? ::)
petefrom bearswamp
I think EMD stands for Electro Motive  (or Motor) Division of GM.
They were a main competitor of the outfit I worked for in the mid 50s, Alco Products Inc formerly the American Locomotive Co. in Schenectady NY.
Alco diesels were 4 stroke so quieter.
EMD did make diesel Electric Locomotives as well as engines maybe still do..
They were instrumental in the demise of Alco as my uncle said why buy a Cadillac locomotive when a Chevy will do.
Bargemonkey where do you run this thing?
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
BargeMonkey
Quote from: LeeB on May 04, 2014, 08:17:44 AM
Thats a 16-645 -E6 or could even be a 567BC block. Ive been on alot of blown boats. A 16 blown boat is a Cadillac compared to a turbo boat. Fuel use depends, the big boat I was on in the gulf would blow thru 4800 a day at 850rpm, in no weather. Ive seen what they call the "triple 20's" line haul boats in the Mississippi, they use 10-12k a day making 15k hp. I presently work for a company moving stone down in the city, closer to home and no oil barge headaches. These hold 280 gallons of mobil 409 per side, emd's tend to use about .60-.75 gallons of oil per run hour, depending on how tight and maintained they are. A turbo boat will get 25-35k hours to a repower, blown boats can get 60k hours at most. Yeah this supports my logging equipment addiction, worse ways to make a living.
BargeMonkey
Quote from: petefrom bearswamp on May 04, 2014, 08:41:34 AM
I was chief on a twin 12 cyl Alco boat, the Valentine Moran years ago. I will take an Emd everyday of the week over an Alco. A turbo on an Alco is a nightmare, dont hold up and can be 75k+ every time you do one. They are abojt gone out here. You wanna see something awesome, look up a fairbanks morse 8-1/8 OP engine. The guys who designed this stuff had their acts together.
LeeB
Dave Shepard
The ski area where I used to work had two FB gensets. 1, 200kw. I think the model was FD38. They were 10 cylinder, 20 piston engines making 1,600 hp. I never got to see them run. A friend of mine ran the engines on the Mauna Loa during Vietnam. It had a pair 9 cylinder Nordbergs making 3100. He has a bunch of good stories about the engines on the different ships he was on.
petefrom bearswamp
My uncle told me that quality suffered when Alco was bought by Studebaker Worthington in the 70's.
Sounds a little like the Harley Davidson to AMF debacle.
He spent his entire career with Alco, first in Schenectady, then Auburn NY. Dunkirk NY and in Ohio somewhere.
He retired a disillusioned man as regards the company.
BargeMonkey, regarding a job to support your logging addiction, If I win the lottery I will just keep sawing until the money is spent.
Kubota 900 RTV
clww
You should see the engines we had on the aircraft carriers, both conventional or nuclear.
Many Stihl Saws-16"-60"
18-Wheeler Driver
BargeMonkey
 When you get into the big bore, slow speed, heavy fuel stuff im kinda lost. I took the bare minimum steam for my license. Theres quite a few OP FM ex navy YTB boats still running around, changes your way of thinking.
Dave Shepard
I'm sure you must know about the Wartsila-Sulzer RTA96-C? 108,000 HP, 5,800,000 ft/lbs torque at 102 rpm. ;D
Corley5
