Author Topic: Forestry mulcher help  (Read 10459 times)
Offline davidn3
« on: May 01, 2019, 06:24:17 PM »
Just purchased a bobcat 60" forestry mulcher.  Was excited to try it out and wasn't impressed.   Running it on a bobcat 2013 s750 (85hp)  with grouser tracks.  It seemed to bog and stop spinning way more than expected.   Espesualy with stumps (pine).  I was running at 1700 rpm, which is more than I normally run it.  The carbide teeth seem to be pretty dull but none broken.  Do I need new teeth?  $80 a tooth kind of sucks right off the get go.  Run more rpm?  Nowhere does bobcat state what rpm I get that 85hp at.  Also the pressure gauge on the front isn't working.  Is it worth my time fixing it?  For the most part it runs.  Just want more optimal use out of the 18k I just spent.
Offline nativewolf
Re: Forestry mulcher help
« Reply #1 on: May 01, 2019, 09:32:10 PM »
Sorry but not surprised to hear.  85 HP is just not enough power and that s750 hydraulic flow rate and pressure is not super high.  To be effective you'll need to do some research to see what RPM keeps hydraulic flow highest, keep hydraulics cool, stop and clean that radiator with a blower, watch temps because a mulcher is a good way to burn up a skidsteer.
Carbide teeth getting dull already?  was this a new mulcher head?  You shouldn't be getting dull teeth right away if they are carbides unless you've been playing in dirt.  Might be easier to start with good old knives that you can sharpen.
In the future I'd suggest getting an FAE head on a purpose built carrier, like a CMI 175 or a Fecon 150.  These machines will have 50-70GPM and 5000psi, more weight and better ergonomics for mulching.
Liking Walnut
Offline ohiowoodchuck
« Reply #2 on: May 01, 2019, 09:37:32 PM »
My buddy brought a new cat 299 and a mulcher out to my place back last fall. Definitely not impressed. The skidsteer had the hp and the flow but the head couldn't hold up to the mulching. It kept breaking the bolts on the hub that held the bearing and drum shaft in. After 3 sets of bolts in four hours we quit.
Education is the best defense against the media.
Offline davidn3
« Reply #3 on: May 02, 2019, 12:32:31 AM »
The hp and flow are in the specified range for the mulcher.  The mulcher is used. A 2013 model I believe.   Fecon type head sold by bobcat.  The planer type teeth look like they would do better but there are a lot of rocks in the area.  Wasn't having any issues with broken teeth,  or temp.  But it was only 40 degrees out. Just the drum would stop with less force than I thought.  Had to let it spin back up to speed quite often.
Offline barbender
« Reply #4 on: May 02, 2019, 12:49:44 AM »
You should be running full throttle with that mulcher attachment.
Offline AnvilRW
« Reply #5 on: May 02, 2019, 12:58:17 AM »
Do you have high flow hydraulics?  You have to have high flow.  I run a Fecon 74SD HDT style with the double carbide teeth on my 2015 Bobcat T770 (92-hp).  I run it through mixed gambel oaks from 2" to 8" diameter and pines bigger than that.  I run my engine at full rpm, which is about 2,400.  I have lots of rocks, too.  I'm on my third set of tracks and third set of teeth.  The machine hydraulics will get hot in summer months when running it hard so I end up with about 45-minutes out of an hour of productivity.  If I'm working flat ground, it never gets too hot.  Most of the work I do is steep terrain at around 7K altitude.  I run my machine in crawl/snail mode, normally about 55-57% speed.  I run the cutter a few inches off the ground going in, and then mulch going back.  If you're not mulching on flat ground, mulch when you're backing downhill.  If what you're mulching is big/tall, top them first.  It's like anything else, you learn by doing and you have to listen to how the machine is handling the load and adjust your travel speed accordingly.  I've never had my head stop spinning unless I jammed a log/stump in it.  There's pics in my gallery so you can judge the terrain and what I'm mulching.
"A man with any character at all must have enemies and places he is not welcomein the end we are not only defined by our friends, but also those aligned against us."
Offline davidn3
« Reply #6 on: May 02, 2019, 01:00:39 AM »
Thanks.   I saw kubota has rpm ratings on there machines.   2200-2400 rpm.  Bobcat doesn't state anywhere in the owners manual,  1000+ page service manual,  or website about recommended rpm.
Offline davidn3
« Reply #7 on: May 02, 2019, 01:01:54 AM »
Yes I have high flow.  I think its 36gpm on Bobcats.
Offline davidn3
« Reply #8 on: May 02, 2019, 01:08:46 AM »
Anvilrw,  could you post a picture of what dull carbides look like?  I'm running double carbides.  None are broken, but they are rounded.   It was chipping.   Just not as smooth as hoped.  What do you look at for you hydraulic temp?  Engine temp go up with it?  I'm on pretty flat terrain.
Offline davidn3
« Reply #9 on: May 02, 2019, 01:21:09 AM »
Also....where do you buy teeth? Bobcat sells them for $150 per carbide tooth.  Extreme wear products sells them for around $85 per double carbide.  Any other suggestions?
Offline AnvilRW
« Reply #10 on: May 02, 2019, 01:25:33 AM »
I'll see if I have a pic, but I don't really go by how they look, but rather how they cut.  The teeth will start rounding over as soon as you start using them, but once the carbide rolls back into the steel cutter body, they're toast on hardwoods.  My machine alarms when the hydraulic temps get above 220F or so, IIRC.  The engine itself never gets hot, only the hydro fluid temps.  IME, mulching with a skid steer isn't like mowing a lawn, you have to pick at it.  More like mowing an overgrown field with your push lawn mower.  Here's a pic of what new teeth look like:
Offline AnvilRW
« Reply #11 on: May 02, 2019, 01:28:52 AM »
$85 a tooth is cheaper than I've ever seen them.  I think my last set was more like $120 each with the bolt and nut.  Changing those teeth is a job if you're doing it in the field.  Best to have someone help you.
Offline Riwaka
« Reply #12 on: May 02, 2019, 02:02:50 AM »
Do the Fecon parts fit the Bobcat mulcher?
Fecon have slip-teeth for rocky ground.
Bull Hog for Skid Steers | FECON    (50 inch)
Supertrak run 140 horsepower for the fae 72 inch mulcher. (Similar power/ width to running a 44 inch wide mulcher on the bobcat 85hp)
FAE have a 53inch mulcher.
Yes fix the pressure gauge.
Offline davidn3
« Reply #13 on: May 02, 2019, 02:09:48 AM »
Fecon teeth wont fit a bobcat.  I believe that's one of the only differences between the 2.  Along with the hydraulic pump.
Offline nativewolf
« Reply #14 on: May 02, 2019, 06:42:22 AM »
Well, fix pressure gauge, get pressure as high as possible, take a small slice and it will bog down, immediately back out/lift up let it get back to speed, then lower head again and take another slice.  As others said you just can bury that head.
Lastly, what they say works as far as GPM and Pressure is not nearly what is required for any continuous use.
I had a massive 200+hp tractor and pto powered mulcher and could easily stop the whole head on a stump if I left it buried.
Why did you buy it?
My feeling is that the heads are just too abusive for skidsteers, they will cause so much stress/wear on the machine that you'll be lucky to break even doing any work.  I mean lucky.  99% of people that have tried mulching with a skid steer have gone out of business.  However, you can easily rent a Fecon or similar machine if you have 5-10 acres to do and have a month of evenings.
Liking Walnut
Offline davidn3
« Reply #15 on: May 04, 2019, 03:02:26 AM »
Purchased for brush cleanup mostly from trees being cut down.  Pine stumps on my trails.  Not trying to clear land.  It will probably get 50-100hrs of use a year.  But will need it here and there so it doesn't make sense to rent a machine or purchase something that is 100k+
Offline nativewolf
« Reply #16 on: May 04, 2019, 07:06:50 AM »
Gotcha.  Well good luck with the project.  In your shoes I would sell the mulching head and once a year hire someone with a really powerful mulcher, pay them $3000 for a day and see what gets accomplished.  I am selling my own and getting a purpose built carrier.  I've hired 3 companies to do mulching in the last year and spent many thousands but it was still cheaper than doing myself.
The thing that I have to caution you on is that mulching heads ..are extremely demanding and will damage a non purpose built carrier.  Secondly, your skidsteer is just not powerful enough.  They are meant to be run on something like a T870 bobcat or the like.  Machines with lexan windows, more cooling, better sealing, etc.
Liking Walnut
Offline davidn3
« Reply #17 on: May 04, 2019, 09:26:32 AM »
I believe a 770 Bobcat is 92hp and a 870 is 98hp.  My 750 is 85hp.  This isn't very far from 92.  The 7hp is probably negligible.   I will probably trade it in some day for an S870. But a mulcher this size should have no problem using 85hp. 3k per year seems excessive.
Offline Southside
    • White Oak Meadows
« Reply #18 on: May 04, 2019, 09:55:14 AM »
I know nothing about mulchers, but I know plenty about making and using hay.  We used to sell around 30K square bales and probably another 2K round bales in addition to our own use each year.  It was a part time gig - decent size, but still part time.  I always "knew" we were saving money doing it that way, but I never really crunched the numbers.  Capitalization, land, seed, depreciation, maintenance, fuel, repairs, wages - including my own.  Well, eventually I was forced to crunch the numbers and you know what I came to realize - I was actually loosing money on each and every bale.  So now our hay shows up via tractor trailer, in the quality and quantity that I want, I spend 45 minutes each load getting it off and under cover, then I go back to making money.
My point is that with any equipment intensive endeavor you just can't go by "seems", you need to dive deep into the weeds to know if you are getting the best value for your dollars.  Just curious, what does a hydraulic pump cost for your skid steer if you cook it due to the mulcher head being too much for it?  Oh - and be sure to calculate in the cost of getting any metal out of the entire hydraulic system should the pump die and FOD the whole thing.  Those are the kinds of moments you have to look at when deciding if you are betting against the house.
White Oak Meadows
Online mike_belben
  • Pulp Friction
« Reply #19 on: May 04, 2019, 12:39:17 PM »
This.  Hydrostatic machines use low pressure charge pumps to feed the high pressure drive pump.  Theyre built to run at rated rpm, all of it.
Rpm will make more gpm [more power flowing into the head to work really] which will shorten your recovery times from bogging.  Cut quality is gonna be a function of cutter tooth condition,  cutter speed and mass of the head.
Isaiah 63:10
Forestry Mulcher: HP of track loader vs Type of Mulcher head teeth?
Started by anthonyz on Forestry and Logging
Last post September 08, 2019, 09:50:11 PM
by anthonyz
Pre- Forestry Mulcher Trek
Last post July 04, 2021, 06:41:51 AM
by SwampDonkey
Forestry Mulcher at work
Last post September 16, 2021, 08:35:33 PM
by Jeff
Best forestry Mulcher set up for versatile small operation?
Started by MaineStumpGrind on Forestry and Logging
Last post August 23, 2020, 11:07:46 PM
by Walnut Beast
