Author Topic: Woodland Mill HM130 Max  (Read 3368 times)
Offline CedarRidge
  • Cedar Ridge Sawmill
« on: December 19, 2019, 03:27:59 PM »
So I have been doing my research for months now on which mill to purchase. Based on information that I read here, mills that I was able to see and operate I had chosen the Woodland Mill HM130. I called and found out that they have an upgrade for HM130, its now the HM130 MAX. Thought I would share the info here.
Still have the option of 9hp or 14hp
Still 30" log, but can it can now cut a 30" wide board
comes with auto lube, hour meter, two auto locks instead of the one
Auto lock crank for racing and lowering the head
Blades are now 157 1/2"
Looking forward to placing my order in January.
Woodland Mills HM 130Max, John Deere 4044m with Grapple, 2001 Ford F350
Offline thecfarm
Re: Woodland Mill HM130 Max
« Reply #1 on: December 19, 2019, 05:00:40 PM »
You will like sawing!!
Get a Logrite peavey or a cantdog. Sponsor on the left,nice people. Check out the Annual Christmas Contest and you will see why.
Offline frazman
« Reply #2 on: December 19, 2019, 05:32:28 PM »
The HM 130 only had the 14 hp engine from what I've seen in the past. The HM 126 offered the 9.5 or 14 hp engine. A few more options have been offered with the new HM 130 Max as listed below with a new price from what I've been told
- 37" wide track
- 30" dia. between blade guides
- auto locking blade guides
- 2 log clamps
- auto lube
- 13L aluminum lube tank with level indicator
- crank handle is auto locking
- blade 157.5"
- engine hour meter
Offline CedarRidge
« Reply #3 on: December 19, 2019, 09:38:55 PM »
Im looking forward to it!! Been wanting to do this for awhile. I think I spent 3-4 hours looking for elf's today. In the end I found all of them but 1 and 3  :)
I have a peavey that was my grandfathers that I will be using but definitely keep Logrite in the bookmarks for future purchases.
Offline Touchngo
  • Member*
« Reply #4 on: March 04, 2020, 08:01:13 PM »
Where u at in the process Cedar.?    Im getting ready to pull trigger.
Thanks.    Sean
Offline CedarRidge
« Reply #5 on: March 26, 2020, 01:53:53 PM »
Have the mill all set up. Will be making my first cuts today. Ordered it on a Monday, showed up that Wednesday, fast! Took a day to make sure the tracks were level and plumb, another day to put the head together. Today make some final adjustments and fire it up. Looking forward to this during the COVID lock down
Offline thecfarm
« Reply #6 on: March 26, 2020, 03:14:12 PM »
 8)
New mill, my first - Woodland Mills HM130
Started by ChugiakTinkerer on Sawmills and Milling
Last post November 26, 2017, 03:25:00 PM
by PC-Urban-Sawyer
Opinions on new mill, Woodland HM130 or Norwood MN26
Started by brombones on Sawmills and Milling
Last post February 24, 2018, 10:29:22 AM
by staker
Woodland mills hm130 tracking resolved!
Started by Novascotiamill on Sawmills and Milling
Last post October 25, 2017, 08:40:53 PM
by Novascotiamill
Woodland Mills HM130 vs Woodmizer LT15
Started by randy_atx on Sawmills and Milling
Last post December 05, 2017, 11:06:05 PM
by Jas24
