Backyard Wild Cherry Vanity
Started by 21incher, March 12, 2020, 11:34:18 AM
21incher
Here is a project that I just finished. It grew in my backyard. Love the smell of working with cherry
 It's a little taller then the old one so I hid a step for my granddaughter under it
 Also made the Mirror and LED light fixture
It has been a fun winter project.
stavebuyer
DPatton
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
D & S Sawmill Services
trimguy
samandothers
Great job and nice added details.  What finish?
Good idea on the step for the littles ones. Like the light too.
DWyatt
That is a beautiful vanity! I just with cherry would stay how it looks when fresh cut like that, I am not a big fan when it starts to darken.
That vanity top is especially nice!
21incher
Thanks everyone
Quote from: samandothers on March 12, 2020, 09:45:39 PM
I use Polycrylic on everything. It's the only finish that my wife can stand the out gassing from with her chemical sensitivity syndrome.  I used it on our butcher block island years ago that takes quite a beating and it has stood up well. The only thing I don't like about it is the uv blocking that keeps cherry from turning the deep red color.
Quote from: thecfarm on March 13, 2020, 06:56:34 AM
My grandkids always needed a stool  so I figured might as well built in a hidden one they could just pull out. Those new LED strips are fun to play with and extremely bright.
Quote from: DWyatt on March 13, 2020, 07:45:34 AM
With Polycrylic it doesn't darken much. The uv protection in it holds the color.
Quote from: WDH on March 13, 2020, 07:47:03 AM
That was one of those short less then perfect slabs I had to cut up and piece back together.  luckily it was thick enough to resaw the side t&g panels off so I could match that to the top.
Old Greenhorn
21incher, I have never used polycrylic, I use verathane on everything. Is there a difference? I guess i'll find out soon enough, I just picked up a pint to try it. I am hoping it may be clearer than the verathane. Just wondering if you know the difference, if any. You do some powerfully beautiful work!
21incher
Quote from: Old Greenhorn on March 13, 2020, 12:54:42 PM
I have no idea if there is a difference.  I use the gloss version because it seems the clearest.  Polycrylic is just basically a plastic coat that I don't think is a polyurethane at all. There is no chemical bond between the coats so a good 320 sanding is required for a mechanical bond  between coats. After 3 coats I let it dry then sand it  with 320 and apply 2 coats of Johnson's paste wax with 0000 steel wool initially. Then it takes about 90 days to cure to the point that it can be properly sanded up to about 2000 grit and rubbed out. It's definitely not like working with solvent base poly or epoxy that cures and can be polished out quickly. Thanks  it's amazing what grows in the back yard.
Bruno of NH
Superior work as you always do
Sir
21incher
Quote from: Bruno of NH on March 13, 2020, 09:20:56 PM
Sir
Thanks Bruno. It's all about having the time to complete projects like this and learning from past mistakes.
