Sawing and Selling softwood
Started by Downhill Cutter, April 29, 2021, 07:17:37 AM
Downhill Cutter
A couple of weeks back, I needed a piece of 1x8 for a small project, so I went to my local lumber store.  When the nice man behind the counter gave me the price, the blood ran out of my face . . . then I remembered I have TWO sawmills, and a stack of pine logs, access to MORE pine logs . . . and a Nyle kiln.  HMMM.
The nice man said that if I just cut 2x4's for the next year, I could be wealthy.  Double Hmmm.
SO I have a MDS, a Lucas Mill, a stack of pine logs, and a kiln . . .  What's the hold up?
I'm pretty green in the business side of the sawmill business.  I've cut a bunch of material, but I haven't sold much . . . and some of Y'all have, so . . . .
I don't know what dimensions to saw my 2x4s.  REAL 2x4?  I also have a planer, but does it make $$$ sense to saw, KD, and mill 2x4's to current standard measurements, OR should I just mill everything at full dimension 2x4 and let customers deal with it, AND what do I charge for my product? OR . . . . should I just let the big guys have the 2x4 market?
Thanks in advance for the wisdom of all of Y'all.
DownHill Cutter
If you do what you SHOULD do, WHEN you should do it, for Long enough . . . Pretty soon you'll be able to do what you WANT to do, WHEN you what to do it, For the rest of your life (within limits).
firefighter ontheside
I think if you want to compete with the big box stores you should mill to get a dried 2x4 that measures
1 1/2 x 3 1/2.  I don't think I would mess with planing.  A person can build a shed or whatever it may be with rough lumber just as well as with planed lumber.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
moodnacreek
I stay away from framing lumber especially 2x4. They are made, stacked and dried on automatic machinery by a mill that sells sawdust, bark and chips. And they are sawn from the proper logs that I don't often have. If I have to make 2x4 I saw them from a big fat log with less stress and get less $ than I could have if 1" boards. Right now things are different but I expect it won't last.
You can saw and sell a lot of green 2x4s for outdoor use like sheds, barns etc. right now. I'm selling them at $1/bf, usually sawn finished dimension (1.5x3.5) for $3.50 each. During normal times, I don't mess with them much either. I'm not going to try to compete with Home Depot selling a KD dressed 2x4 at $2.35.
TimW
I saw my 2 bys a 1/16" thick and a 1/8" wide.  I cut the length 3 inches over whatever length you want.  So a 12 foot 2x6 would be 1&9/16" x 5&5/8" x 147 inches.
I sell them for half the price the local Lowes sells them for.  I have been so busy, I had to take my ad off of Craigslist.
hugs,  Brandi
Of course Brandi intended to write:  1 9/16" X 5 5/8".   ;D
Bruno of NH
I cut all my framing lumber full dimention as that's what most folks want in NH.
Right now it sells as fast as its cut.
Downhill Cutter
Thanks to all of Y'all for educating me quickly and succinctly.  Like MagicMan, I found Brandi's advice compelling, and started figuring-up how many 2x4's I could get out of a log if I cut 'em 1/8 x 1/16 8).  Then  I ran into a kerf problem.  :D
Cheers,
TimW
Quote from: Magicman on April 29, 2021, 02:30:38 PM
Thank MM.  I just edited it.
         hugs,  Brandi
TimW
Quote from: Downhill Cutter on April 29, 2021, 04:30:11 PM
Cheers,
DH Cutter,
Sounds like you need more experience. smiley_reading_book  I could show you how, but then I could be cut out of the toothpick market. splitwood_smiley
 hugs,  Brandi
TimW
Quote from: Bruno of NH on April 29, 2021, 03:22:29 PM
Bruno,
Sssshhhhh..........  Don't let these guys down here know that. no_no   I like cutting them on the lighter side. whiteflag_smiley  Way easier to stack and sticker. food6
Brandi
You are correct Brandi, the dimensions seem to be a regional thing.  I am in my 20th year of sawing and have sawn more than 1.75MMbf of framing lumber and I can remember only 3 customers that requested full dimension.
Walnut Beast
What dimensions are you sawing framing lumber
TimW
1/16" over thickness and 1/8" over width.
hugs,   Brandi
I saw it right at finished dimension unless someone wants something different. Right now, for instance, I'm sawing some rafters for a customer. He wanted to use 2x6, we decided to go 1.5x6".
  When someone wants full 2x4, it just throws a wrench in all of my processes because I sell a lot of 1.5x3.5" for pallets. When I saw 2x4, the material that I typically recover (like a 4' 1.5x3.5) is the wrong dimension, but not worth messing with any further.
Downhill Cutter
Wow . . . another graduate course in sawmilling overnight :P.
Thanks again to All of Y'all.
DHC
UncleMoustache
I've asked a similar question and received similar replies.
However, I wouldn't say that any of us would be 'competing' with the box stores.
Rather, some of us have extra logs and time, and don't know what else to do with the lumber, so why not make a few bucks selling some 2-bys?
My problem is that I find it difficult (so far) to get decent logs for lumber, so I am (per the advice of others here) looking for my niche in how to make a bit of money with my mill.  Sheds are currently full of drying slabs....
Josh
-Echo CS-670, CS-620, CS-370, CS-355T, CSS-266
-Stihl MS661, MS200T
-Dolmar 550
-SuperSplit
-Woodmizer LT15 Wide
