Author Topic: Best planer (planer/molder) for the money non commercial operation  (Read 1329 times)
Offline VB-Milling
  • Always learning
Re: Best planer (planer/molder) for the money non commercial operation
« Reply #20 on: September 15, 2021, 10:01:19 AM »
I like them.  Old iron is good in my opinion;  I have a lot of old iron.
Sometimes too old can be bad though.  The drive gears tend to wear out on heavily used machines.  (like if you were buying it from a cabinet shop or the like)
If you're looking at older machines, the price difference between a 12in and a 15in machine can be negligible and you'll never feel bad about having that extra 3inches.
HM126
Offline muggs
    • Hardins industries
« Reply #21 on: September 16, 2021, 03:02:15 PM »
I have had a Powermatic 16 inch planer for about 30 years, It has been fine.
Offline dougtrr2
« Reply #22 on: September 17, 2021, 09:44:01 AM »
Is a powermatic 100 any good?
Yes, Powermatic 100's are a sought after small planer.  There are a lot of references and threads regarding that planer on OWWM.org
Doug in SW IA
Offline Sedgehammer
  • Old enough to know better, but ya only live once!
« Reply #23 on: September 17, 2021, 08:38:54 PM »
Couldn't find anything in my price range close enough. Most of the woodmasters were 12". Bought a grizzly 15" G1021 on  wheeled cart. The guys dad did some hobby wood working with it. Paid $400
Going to order a helical head for it me thinks I can. Any brand preferred ?
Offline VB-Milling
  • Always learning
« Reply #24 on: September 17, 2021, 11:28:03 PM »
Check if grizzly has the option to order a helical head.  Sometimes they offer the upgrade.
No sense in spending shelix money on a grizzly machine for what you're doing.
Just my 2 cents.
HM126
Offline Sedgehammer
« Reply #25 on: September 18, 2021, 07:53:34 AM »
Just my 2 cents.
Shelix and grizzly are both $748. Can buy a Elephas for $572 thru amazonian
Offline firefighter ontheside
  • I like trees.
« Reply #26 on: September 18, 2021, 03:16:10 PM »
I would say helical heads are worth it in any machine.  Shelix are made in USA and grizzly heads are not if that matters.  I believe the shelix heads will be the same diameter as original and the grizzly will be smaller diameter.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
Offline farmfromkansas
« Reply #27 on: September 19, 2021, 04:56:35 PM »
The point of getting a helical head for me is that all I have to do is either clean or turn the cutters, and do not have to remove the blades, sharpen and re-install.  Putting blades in a cutterhead and getting them set correctly and even are not easy when you are young, but when you are old and need reading glasses to read your tape measure, makes helical the only way to go for me.
Offline Sedgehammer
« Reply #28 on: September 20, 2021, 10:51:15 PM »
This is my thoughts pretty much summed up
Need Help with Planer/Molder
Started by paul91344 on General Board
Last post August 16, 2018, 06:34:16 PM
by low_48
norwood planer molder
Started by bigjohn1895 on Sawmills and Milling
Last post April 30, 2018, 10:58:19 AM
by esteadle
Planer Molder question
Started by nrp0450 on Drying and Processing
Last post September 07, 2012, 06:33:19 PM
by Larry
Belsaw Molder Planer
Started by logboy on General Woodworking
Last post January 03, 2012, 07:15:47 AM
by Larry
