Author Topic: Mini-Split heat pump for room in pole building?  (Read 1881 times)
Offline aigheadish
  • Tiiiiimmbeeerrr!
Re: Mini-Split heat pump for room in pole building?
« Reply #20 on: August 16, 2021, 10:15:14 AM »
My shop is about 14'x23' or so and is a drag to heat. I'd love to cool it also but I have a giant set of doors to open that give a nice view. This winter I expect it to be a bit more insulated but last winter it was common to fire up both a propane heater and a kerosene heater. Both got expensive and the room, when it was legitimately cold, never got warm. The room does high a cathedral style ceiling, probably 16-18' high that is uninsulated and the big doors aren't insulated either, so lots of spots for leaking...
New Holland LB75b, Husqvarna 455 Rancher, Husqvarna GTH52XLS, Hammerhead 250, Honda VTX1300 for now and probably for sale (let me know if you are interested!)
Offline Al_Smith
« Reply #21 on: August 16, 2021, 10:20:40 AM »
On unvented infrareds I have an old "Ember Glow " propane mounted on a cart that holds a 20 pound propane tank in the bottom .It works just fine in a 24 by 24 garage and will burn about 4 days on a tank full .It's seldom I use it in winter which BTW is not my favorite season of the year but it will crank it up to about 50 degrees after a few hours of run time .It's certainly a better option than trying to work in temps from 10 above to 10 below .Work ten minutes and take 20 minutes to warm back up again, no thank you . I have no desire to live in North Dakota or Alaska  in the winter time .Ohio is cold enough .
Offline doc henderson
« Reply #22 on: August 16, 2021, 10:25:26 AM »
My shop has floor heat with a boiler, and after about 4 (not cheap) Lowes widow AC units, I acquired a home unit to install in the shop.  I like the mini splits for a small room.  quiet, efficient, and all in one.  I keep the heat at 55 to 60 in the winter, and start the wood stove when I am working.  I like the idea of tilting the thermostat to get a lower temp (mercury switch).  my shop has a basement and is full insulated.  the shop including the basement is 4500 sq. ft.   many folks I know get the Mitsubishi brand.  the size depends on the room size and insulation.  can be sized by the company selling the unit.  heat pumps do not tend to works at the extremes of temp.  If only we could find things to heat in the summer and freeze in the winter.  :)
Offline Texas Ranger
  • Texan, by God and by choice.
« Reply #23 on: August 16, 2021, 11:06:14 AM »
Offline Tom King
    • HistoricHousePreservation
« Reply #24 on: August 16, 2021, 07:12:20 PM »
The difference between a mini-split, and a window AC is like riding in a new Cadillac, or a 65 Chevy that's gotten low on Freon.
« Reply #25 on: August 24, 2021, 03:37:46 PM »
Addendum:  Put a serge suppressor in the line .  I found out the hard way.
Offline gspren
« Reply #26 on: August 24, 2021, 05:22:00 PM »
While surge suppressors can save a problem they can only handle so much, when the neighborhood had a major surge a few years ago those that had whole house protection got to add the cost of burnt out surge protectors to everything else, still blew out the modern appliances, tvs etc. only the old pre computer refrigerators that some of us had in our garages survived.
Offline Tacotodd
  • To learn and help
« Reply #27 on: August 24, 2021, 07:24:54 PM »
The “surge” suppressors that I was thinking of were for a different kind of surge ;) NOW you know where I’m at, at least in my mind ;D
Trying harder everyday.
Offline Larry
    • Copas Sawmill
« Reply #28 on: August 24, 2021, 09:58:36 PM »
I got a bid on a Samsung 18k btu Single Zone Mini Split for the shop last week.  $3,800 seems high to me.
Right now I AC with a 18,500 btu window unit in 1,500 square foot well insulated tight shop.  Heat is 24/7 from a Vermont Castings wood stove.  First window unit lasted 7 years and I'm about that far along on the one I'm using now.  They work well and not much cost.
Still I would like to explore a mini split.  Have to contact a few more HVAC guys.  I'm also not afraid of a DIY unit.
Offline peakbagger
« Reply #29 on: August 25, 2021, 09:13:44 AM »
I installed my own Mitsubishi cold climate mini split but paid a tech to pump out the lines and charge the unit. It took them about 2 hours and charged me $250. It they had installed it complete it would have been about $2000. The Mr Cool units they sell at Costco reportedly come with precharged lines so its just plug and play (but the efficiency is lower than the name brands).
Offline SwampDonkey
  • Large Tooth
« Reply #30 on: August 25, 2021, 02:32:52 PM »
Up here you won't get one for less than $6500 installed. That puts the brakes on the deal pronto. :D
“No amount of belief makes something a fact.” James Randi
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #31 on: August 25, 2021, 02:56:22 PM »
3 zone unit for my house installed to replace the failed one is 15k. that is a 3.5 ton Gree unit. After this year, its worth every penny!
Of course install is scheduled for october sometime.
Offline Downstream
« Reply #32 on: August 25, 2021, 10:26:35 PM »
I just started researching these for my 24x24 detached workshop.  The MrCool units seem pretty easy to install and do not need ac tech to charge lines.  Has anybody installed these or another brand that was pre-charged?  Also the 12k btu ones say up to 500 sqft for heating and cooling so once again has anyone used that size for their 24x24x8 ceiling building?  I will be insulating the walls, ceiling, and garage door.
EZ Boardwalk Jr,  Split Second Kinetic logsplitter, Granberg Alaskan Chainsaw Mill, Stihl 660 and 211, Logrite 60" cant hook, Dixie 32 Tongs
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #33 on: August 25, 2021, 10:28:45 PM »
Be careful with the self install ones if you care about a warranty. There is fine print saying no warranty if you install it yourself on some of the units.
Offline petefrom bearswamp
  • 70-13 still feel OK and am retired
« Reply #34 on: August 26, 2021, 07:29:28 AM »
Mini split in the house, kind of a brand x I went with cause the company is in the US.
The system is of course imported from china.
Self installed, professionally charged.
Use it for AC only.
Have had 2 issues with it, the first mice got on the main board and built a nest causing it to fail.
$300 bucks later it ran OK for 2 seasons.
I took all the sheet metal off and mouse proofed it.
It now has been down about a month, the other board fried.
Part on order until late Aug, early Sept.
Probably wont have it operational until AC season nearly over.
Warrantee long gone with no issues.
My well insulated shop 32x56x 10' ceiling 4" concrete floor with no AC would stay cool but very high humidity.
Put a room dehum in and it now stays from 68 to 72 degrees with humidity around 40.
The unit runs continuously and I have no idea how long it will last.
cost about 275 bucks and I can buy a bunch of these as needed before it reaches the cost of a mini split system.
At my age the mini split is not cost effective.
I had thought about another self installed Mitsubishi system from AC direct costing about $3500 or so, but the dehum is working just fine with no great rise in elec cost.
My heat comes from a 55 gallon drum stove.
Kubota 900 RTV
Polaris 570 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
Offline Larry
    • Copas Sawmill
« Reply #35 on: August 26, 2021, 11:14:53 AM »
Along about 1980 I walked into the local Sears Roebuck store.  Remember them?  I gave them the size of my house, window location, and insulation.  They figured out the size central air conditioner I would need.  Gave them some money and walked out with a central air conditioner, A-coil for my furnace, thermostat, and pre-charged lines.  A week later I was cool doing all the work myself with no experience.  Sears sent out a HVAC guy about a month later to check out my work.  Think he added a little Freon and that was it.
So, the DIY technology is not new, and I suspect its improved.  I would think a mini-split might take half a day to install.
Offline hedgerow
« Reply #36 on: August 26, 2021, 04:41:52 PM »
 Over the years I have repaired a ton of these type of units. Those screw together connections start leaking on the high side and leak the charge out. We just cut the screw type connections out and solder in new connections add a filter, pump the system down and charge back up and your back cooling again. A lot of mobile and modular homes around hear had this type of units installed in them.
« Reply #37 on: August 27, 2021, 11:28:46 AM »
Larry, took my friend and I a half day as you stated above
That was just putting the units in place and connecting the lines.Had an electrician friend hook up the electric end, took him an hr and a half.
Kubota 900 RTV
Offline scsmith42
    • Whispering Pines Farm
« Reply #38 on: August 29, 2021, 01:29:42 PM »
To my knowledge all of the mini-split units come pre charged with Freon. With respect to DIY installation, The issue is not so much charging them as it is the need to remove all of the air and purge any moisture out of the line set.
Charging them is a simple matter of opening both valves on the compressor / condenser unit to let the Freon into the rest of the system.
All things being equal, a system that has been properly evacuated (draw a vacuum) after installation will cool better than one that was not.
Tom's 3638D Baker band mill
Offline Tacotodd
  • To learn and help
« Reply #39 on: August 29, 2021, 10:58:22 PM »
29.5” of mercury for a minimum of 30min is supposed to be the shiznit, at least that’s what “I” was taught in our automotive ac classes that I was “allowed” to attend :D
need to heat a warming room that will heat 2 drums of product
Started by adamant on Firewood and Wood Heating
Last post November 29, 2015, 07:52:05 AM
by doctorb
HVAC Mini split system and Trombe wall
Started by OneWithWood on Alternative methods and solutions
Last post November 01, 2012, 01:30:02 AM
by John25mm
whats your heat pump kwh usage?
Started by semologger on General Board
Last post February 10, 2013, 11:19:23 AM
by Al_Smith
Electrical question - heat pump/airconditioner
Started by warren46 on General Board
Last post October 22, 2016, 03:54:35 PM
by Larry
