Author Topic: Power meter  (Read 184 times)
Offline bannerd
  • Madman
Power meter
« on: October 14, 2021, 07:27:00 AM »
He all, trying to gauge what size generator I need and wondering if there is a meter I can run before our power company meter?  I want to get some metrics for a generator and also some supplemental options(solar).  Our power company runs an average so it's far from exact(More profit).
I found some hub kits on amazon... but the look pretty cheap (sense energy).  Open to ideas, Thanks!
Offline firefighter ontheside
  • I like trees.
Re: Power meter
« Reply #1 on: October 14, 2021, 07:42:10 AM »
What do you have that's electric?  Furnace, oven, dryer, water heater?  If you don't have those, your generator needs will be much smaller.  I have a 17.5 kw generator and it will run everything but my electric furnace.  With all gas appliances, you probably don't need more than about 7 kw.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Power meter
« Reply #2 on: October 14, 2021, 08:00:13 AM »
What do you estimate you need as far as current and voltage?
The best way is to get a clamp on ammeter, rated for your input voltage.  Probably, you'd need one sized for HVAC use, because they can measure high currents.  Clamp it on one of your line service lines going into your breaker. panel, downstream of the power meter, and start up your equipment one by one and read the current going through the service line.
Power (Watts) = Current (amps) x Voltage.
Then take the actual measured maximum power requirement, multiply by 1.2 (generators have an 80% service factor)  and that is the minimum power your generator needs to provide.
These meters are invaluable, they will help you diagnose all kinds of electrical motor related problems.  Get a good one, you'll use it the rest of your life.
You can then directly measure your requirements for each machine, all you machines combined, average needs, and most importantly the start up "inrush" or startup current, which spikes much higher than steady state and must be covered by your generator.
You can also estimate your requirements form reading the faceplates from each machine you use, it will have the current requirements.  However, the best way is to just measure it.
YellowHammerisms:
Take steps to save steps.
If it wont roll, its not a log; its still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, theyre burned, and you cant fix them.  Dont burn the cookies.
Offline bannerd
  • Madman
Re: Power meter
« Reply #3 on: October 14, 2021, 08:33:31 AM »
Looking to power LED lights, Well pump (220v @ 30amp/1hp) and a small propane boiler (radiant heat @ 230watt)
Offline Texas Ranger
  • Texan, by God and by choice.
Re: Power meter
« Reply #4 on: October 14, 2021, 09:44:22 AM »
Get as big as you can afford, demand will grow.
Small Saw & Fence Line Work, Gas Power? Or Battery Power
Started by weimedog on Chainsaws
Last post July 04, 2019, 06:37:19 PM
by weimedog
Lower power pro saw or a Higher power pro-sumer saw (Stihl MS 241 vs. MS 271)
Started by grandgourmand on Chainsaws
Last post September 14, 2015, 10:49:19 AM
by HolmenTree
question
keyed power switches for shop power tools
Started by JimBuis on General Board
Last post June 18, 2006, 06:10:25 AM
by iain
Power feed wheels and power requirements?
Started by Satamax on Sawmills and Milling
Last post February 13, 2013, 03:47:24 PM
by Satamax
