Author Topic: How do you change a bar tip  (Read 2201 times)
Offline parrisw
« on: March 03, 2006, 10:16:34 AM »
I ve never changed a bar tip, how do you do it, just drill out the rivit, if so how big a bit to use??
Offline Reddog
  • Forest & Urban woody plant management
Re: How do you change a bar tip
« Reply #1 on: March 03, 2006, 12:15:06 PM »
Get the new tip and use the replacement rivits as a drill bit size guide.
Offline Kevin
« Reply #2 on: March 03, 2006, 01:53:36 PM »
Offline parrisw
« Reply #3 on: March 04, 2006, 02:34:46 PM »
Thanks allot guys.
Will
Offline Alta
« Reply #4 on: March 07, 2006, 11:21:16 PM »
with Stihl bars you just punch out the old rivets and pound in the new ones - not much to it, but a new tip is over $20 so unless the bar is still in really good shape and/or a really expensive bar, it might not make sense to do the job.
Offline parrisw
« Reply #5 on: March 08, 2006, 11:33:44 PM »
Hey, thanks, I found a good used tip, I am gona try, its an Oregon Pro bar 28" that is in really good shape, a new bar like that locally cost me $150, this bar I have came with the saw, but the tip is for a 404 chain, and I need 3/8, so I found a good 3/8 tip and gona put that on.
Offline oldsaw
  • It's a tree, it's a board, it's a....
« Reply #6 on: March 11, 2006, 02:34:27 PM »
I did the same with the 36" Stihl bar that came with my saw.  The saw was set up for .404 and I run 3/8".  I paid $25 or so for the tip, took the 4" angle grinder to the rivets, ground them flush, center punched, drilled out, then put the bar on my bench over a piece of scrap wood with a hole drilled in it, got a punch, two "pops" each, and it was all over...I was careful.  Put the rivets in, got my little 8" long piece of rail, hammered them down, and cut wood.
I consider $25 into a real nice 36" bar wasn't a bad deal at all.  It will probably end up being my short milling bar.  I've got a new one for crosscuts.
So many trees, so little money, even less time.
Stihl 066, Husky 262, Husky 350 (warmed over), Homelite Super XL, Homelite 150A
Offline parrisw
« Reply #7 on: March 13, 2006, 01:40:45 AM »
Yes thanks for the reply, thats what I was excatly thinking, I got it all done now, it cuts great, and the 28" bar is much easier to handle than the 37" bar, only need the 37" for real big stuff, which I don't cut very often.
Will
Change band brands...change tracking?
Started by kelLOGg on Sawmills and Milling
Last post July 21, 2014, 05:56:28 PM
by ladylake
thumbup
A change for the better
Started by John Fish on Chainsaws
Last post May 16, 2013, 10:24:57 PM
by AdkStihl
change name
Started by donny hochstetler on Technical Support Topics
Last post July 07, 2008, 04:31:39 PM
by Riles
New car oil change
Started by moodnacreek on General Board
Last post September 20, 2021, 08:16:11 PM
by moodnacreek
