Saturday's project
Started by scsmith42, July 15, 2011, 12:00:52 AM
scsmith42
Earlier this week I received an e-mail from a hay customer referring me to a large red oak tree that recently fell at a local equestrian farm.   I drove out today to look at it before incurring the cost to transport my equipment.
Whoa..... 208" circumference at breast height!  Looks like I can get two 8' long, 5'6" diameter logs out of it / 24,000 lbs total.  That ought to produce some nice quartersawn red oak!  Hopefully it won't have much metal or rot, but I'll know more Saturday when I go up to retrieve it.
Looks like Saturday morning is going to be busy...
Tom's 3638D Baker band mill
Wow!
That will make for some nice pics....hopefully. :)
Will enjoy seeing how you approach that one. Top on down to the stump?
duke
I bet there is some nice crock wood there too, and a branch or two that will produce a good bit of lumber!! NICE LOG!! ;D :P 8) 8) 8)
Husband
You sure know how to make a guy jealous!  ;D
Post us some more pics!!
Don't care where you are, that's a decent log   :)
Here I am cutting up 12" cedar logs with my swingmill, and you have that thing  to play with  :D
It should be interesting, so you will just have to open it up and see what is inside.  I would suspect that the butt will have interior rot at least a couple of feet up.
WOW!! that is huge. I would like to see some pictures of that being turned into lumber.
scsmith42
Quote from: beenthere on July 15, 2011, 12:22:43 AM
That's my thought too.
scsmith42
Quote from: Magicman on July 15, 2011, 07:01:46 AM
Yeah, that's what I'm thinking.  I'll say this, it looks solid from the bottom.  We'll know more tomorrow.
scsmith42
Quote from: thecfarm on July 15, 2011, 07:09:51 AM
I'll end seal the logs on site and bring them back to the farm tomorrow.  After that, I'll probably wait until fall to mill, so that I have some cooler weather for initial air drying before going into the kiln next summer.
scsmith42
Quote from: Husband on July 15, 2011, 05:04:58 AM
Will do, although it will probably be a few months before I mill them.
Brad_bb
Please post pics of what you find when you buck them.
terrifictimbersllc
Like to see a closeup of your tires after it's loaded. :o
scsmith42
Quote from: terrifictimbersllc on July 15, 2011, 04:08:44 PM
I'm not sure that I want to look at them.... :D
scsmith42
Quote from: Ianab on July 15, 2011, 05:44:22 AM
Yeah, yeah, Ian, you can't fool me; I've seen photos of some of those mongo logs that you have in New Zealand!  Some of them make this one look like a toothpick! :D
scsmith42
Quote from: Brad_bb on July 15, 2011, 01:16:15 PM
Brad, will do.  Probably will post them this Sunday.
customsawyer
www.thecustomsawyer.com
millwright
What do you have to load that with?
cutterboy
Yes, I was thinking the same thing as Millwright. How are you going to load it and what do you have to transport it?
To underestimate old men and old machines is the folly of youth. Frank C.
scsmith42
Quote from: cutterboy on July 15, 2011, 08:03:33 PM
My current plan is to cut it into two 8' long logs, estimate 6 tons each.  I'm taking a Cat 420Dit backhoe, and there will be a farm tractor on site with a FEL that is supposed to be good for 5000 lbs, or so.  Hopefully between both FEL's we can pick the logs up to place them on the trailer.  Plan B will be to roll the log onto the end of the trailer with the backhoe, and then either winch or roll it up the ramp onto the deck.  I don't really want to try parbuckling a log that heavy.
The trailer is a 37' deck, dual tandem gooseneck with a hydraulic dovetail.  I'll have to go back for the backhoe, as there is neither room nor weight capacity for the logs and the backhoe.
I designed the trailer for 10 tons on deck, with an additional safety margin.  I've actually had 15 tons on it and towed it for 100 miles w/o a problem, so I'm not concerned re the weight.  The tires are new, and the brakes are good (electric over hydraulic disc).
It's not my first time to this rodeo....
customsawyer
redbeard
The center looks to be in real good shape, your going to have some fine looking lumber from those mamouths! I bet those were over 5000 lbs. each.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
Quebecnewf
Pleasepost the pics as you saw this monster and give us the BF tally
Quebecnewf
isawlogs
 Nice logs, there is gonna be some really nice boards in your futur  8) :)
   Marcel
duke
I'd love to be there ,just for the truoble shooting, idea's needed to get it done!!! 8) 8) :P Always a learning curve with these types of projects. It's what keeps the mind active.
  Marcel
