From the log to furniture
Started by just_sawing, September 03, 2012, 10:15:27 AM
just_sawing
Some times there is too much worry about green lumber. People built fine furniture from the log to the peice.
Here is a small project that my Daughter and Son in-law needed for a booth.
The joints were either glued with Poly or Elmers. The joints were stapled to have the glue held the screwed with everything together. It will season with all parts together and I expect no problems
You can follow me at
www.http://haneyfamilysawmill.com
Looks good.
By the way,What does that say on your mill? All I can read,Is not in my wallet.
Warbird
Nice.  Is that made to hang from a ceiling or stand on the floor as pictured?
Looks good.
As a friendly suggestion, remove the gloves when passing lumber through the table saw (likely the router too, but at least working around a saw blade). Ugly damage can happen to the 10 digits if (or when) the saw teeth catch a glove (or other loose clothing). ;)
As well (being on the subject), never joint and allow any fingers to be over the jointer head. Most injuries using a jointer come when a piece will catch and scoot out from under those fingers, leaving them fighting with the rotating knive blades. A push stick or push block if pressure is needed over the head, otherwise keep hands on one side or the other.
This may help others also, and hope you don't take it as a put-down.
Appreciate the picture story of the project.
tyb525
Yeah, I nearly cut my thumb off on my table saw, my gloves weren't skin tight therefore the blade caught the gloves and pulled my thumb into the blade.
Wouldn't have happened without gloves.
jueston
Quote from: thecfarm on September 03, 2012, 10:41:47 AM
Looks good.
i think its ID not in my wallet, but i still have no idea what it says above that...
but the piece looks good, i too wonder if it hangs or stands on the ground...
just_sawing
Your Fair Share is not in my Wallet
grweldon
Quote from: beenthere on September 03, 2012, 12:33:16 PM
First thing I noticed about the pics and it made me cringe.  I have an injury on my left byrd finger due to a jointer.  Can't even tell now, 20 years later, but at the time I thought I had lost the whole tip of the finger.  Had push blocks handy, but wasn't using them.  I don't do that anymore...
My three favorite documents: The Holy Bible, The Declaration of Independence and The Constitution of the United States.
