Willow log
Started by GAB, March 01, 2016, 04:31:32 PM
GAB
I suspect there are numerous types of willow and I have no clue as to what type this individual has. The question is what would be a use for willow wood.
The log this individual has is quite large.
Gerald
Chuck White
Sounds like a Black Willow!
They're the only ones that I know that get really big!
I saw several Mbf each year for wall paneling.  Willow was my mystery board at last year's Pig Roast.
bkaimwood
Interesting enough, I've seen some nice tops out of Willow...I've declined many free willow logs before seeing them, and since, haven't seen a one...but its coming, I could feel it!!!
bk
GAB
Quote from: Magicman on March 01, 2016, 05:26:14 PM
Lynn:
When you saw willow for paneling what thickness do you saw, and what thickness is it planed to?
Gerald
fishfighter
Never sawed it, but it's a bigger trash tree the hackberry around my parts. They do get about 20" around here and they are very fast growing trees. A 20" is only about a 15-18 year old tree around here and spread like wild flowers.
WV Sawmiller
   Isn't willow commonly used in the process of making stringed musical instruments?
Quote from: GAB on March 01, 2016, 07:14:45 PMLynn: When you saw willow for paneling what thickness do you saw, and what thickness is it planed to? Gerald
A full 1" which leaves plenty for shrinkage and the planer.
A few remaining Black Willow logs and one of the three trailer loads of Willow in the background.
Willow can be some purdy stuff.
cbla
Very nice looking wood! First time I have seen Willow milled
fishfighter
Same here. Does it split? To me, the willows around here are a very soft, wet wood. I would think that when drying, it would split all up.
Guess it will be another log to try on my list of logs to saw. Thanks for the pictures MM.
Yes it is very wet to saw and it is subject to end splitting.  Coat the ends before sawing.
This was all used for wall paneling.
GAB
Quote from: Magicman on March 01, 2016, 10:19:45 PM
Gerald
isawlogs
 Nice whack of logs, my mill is still hip deep in snow!!!   We got another ten inches last night.  :snowball:   Spring is coming .......................  Sometime soon!    :)
   Marcel
See what we are trying to tell you.  :o  Grits keeps the snow away.  :D
isawlogs
  You have this "grits" thing all wrong about it and snow,  grit is what one needs for traction on snow.... ;)  Eat your corn whole, on the cob, as bread or biscuits all of them are good. Use the grit for traction.  :)
   Marcel
Oh my,  :P you may never learn.   :D
fishfighter
Ate a nice mess of them this morning. 8)
I was learned once.   ::)   Nothing that I want to be taught again.
plowboyswr
Quote from: Magicman on March 02, 2016, 01:52:51 PM
:D seems like I heard a discussion Saturday about all this   say_what   :D  ;)
Just an ole farm boy takin one day at a time.
Steve
drobertson
So then,, willow is good for paneling, Grits are good for traction, I'm a thinking the paneling thing makes good sense,
and the grits for traction might be considered baiting the wildlife ;D
LeeB
Willow has a tendency to never stop moving. HArd to get a straight board for more than just a little while. Very light wood that at one time in the past was used in making artificial limbs. Sometimes known as poor mans walnut. I think I might have a piece or two of it left from when I first started sawing. Milled it free hand with a chainsaw before I even knew there was such a thing as chainsaw mills or band mills.
mesquite buckeye
fishfighter
Well, as soon as the Mississippi river gets back in it's banks, I will be going to get a few logs and give them a try for some paneling. ;D
tmbrcruiser
I don't know the different types of willow but 40 some years ago in high school shop class I built a book case from willow. Was very much like yellow poplar, light weight and light color. My sister still has the book case.
Once you get sap in your veins, you will always have sawdust in your pockets.
Quote from: fishfighter on March 08, 2016, 05:59:00 PM
One of my larger Willow customers corrals them up with his boat and ropes during high water.  He tows them to his property and ties them to trees.
These were strung out along the road going to his place.  I would saw one, move up, and saw the next.
And then I moved the sawmill down to the lake and sawed some more.
The neighbor brought his loader to handle the logs.
We sawed several stacks.
Purdy stuff.  It was all for wall paneling in the customer's new home.
