Moisture meter
Started by Kombucha20, June 22, 2022, 08:18:51 PM
Kombucha20
Looking for recommendations on a good moister meter for lumber grading that won't break the bank.
Kombucha20
I'd like to get one under 150$ there's tons of them on Amazon in the 40$ range, but I don't know how good they are. The one I get won't be used very heavily but I'd like to get a good accurate one.
Southside
You can get a good, fast, and cheap moisture meter, the trick is you can only pick two of those qualities.
White Oak Meadows
Crossroads
Quote from: Southside on June 22, 2022, 10:59:09 PM
I have all 3 covered, unfortunately they are covered by 2 meters and they are both telling separate lies 🙈
There is no instant pudding when it comes to moisture meters.  It really a function of how important it is to know the right answer.  I operate a kiln and the right answer is critical.  It the right answer is also very important to you day in and day out, you will need to increase your budget.
K-Guy
There is no way around it, a good meter mean spending some money but if you take care of it, it will last for years.
Nyle Service Dept.
- D. Adams
Tom King
Quote from: K-Guy on June 23, 2022, 08:28:00 AM
That's a fact.  Mine is a Delmhorst that I bought new in the 1970's.  It's analog and uses a 9V battery.  I never leave a battery in it, and it still reads right along with any other one, of any type, I've ever checked it by.
