Value add project
Started by Bruno of NH, April 14, 2020, 05:12:05 PM
doc henderson
Stan she is a lucky woman.  what type wood?  now she needs a matching potting bench!  oops I hope she does not read this... :) :) :) :)
stanwelch
Cherry.  And I'm saying nothing about a potting bench :o
Woodworker, Woodmizer LT15, Stihl 026, MS261CM and 460 chainsaws, John Deere 5410 Tractor 540 Loader,Forks & Grapple, Econoline 6 ton tilt bed trailer
TCove
Man, I'm glad I found this forum.
You guys are the best....
doc henderson
yes...yes we are!  :D  just kiddin and welcome to the forum @TCove
Cherry?  Stan, this planter box will end up in the Hall of Fame ;D.
stanwelch
LOL  :D :D  I had too much cherry in my wood stash and needed space to stack my quarter sawn sycamore. Now where am I going to put all of that WALNUT ? Maybe it is time to draw up plans for another barn?
She wants a new dining room table.  Hmmmm - sycamore top/ walnut base?  This quarantine HAS to end soon !!
K-Guy
Quote from: stanwelch on May 10, 2020, 05:23:01 AMAll you guys building raised bed planters inspired the build. Showed your designs to my wife she says "I want one too - make it 5' x 2' x 3' "  So I did -  just in time for Mother's Day
You left the door open and all the dirt fell out!! :D
Nyle Service Dept.
- D. Adams
Nebraska
I may or may not have with held pictures from this thread due to the fact I knew I couldn't probably get the cedar cut in time for Mother's Day. Saving  it for a Birthday soon. :)
Bruno of NH
Rain here this afternoon
2 ground beds and 4 3' high beds out the door before 10:00
Spent the afternoon building more and need to do it an other full day this week.
Sawing all day tomorrow.
stanwelch
K-guy. Now i see why nobody else has a door  say_what
Cjross73
Just wast to say thank you to Bruno for the idea, we've sold around 30-35 raised beds. The wife now sees the old WM might just be able to turn a little income
LT40, Stihl saw, Old green tractor
Bruno of NH
10 more beds out the door.
Building more today.
I have some ideas for some summer projects
Bruno, I just want to thank you for this topic. There is a value added here that some may not realize. For me, the value was working with Tammy to saw build, assemble, fill and plant a raised garden together. Yesterday we went and bought plants in faith that the cold is done. We found we had to many, so we went out and built another planter totally out of odds and ends.
Its warmer this morning, its raining, and creating our Bruno planters has added some Joy to a time we could use it.
Bruno of NH
I want to keep this post going.
I have some other summer projects I'm going to roll out if I have time.
I posted this so other members could try and see if it could work for them.
Very simple and a good money maker.
I owe this forum so much for the help and knowledge given to me.
Ed_K
 Don't use wet old boards to build with. Rita an I spent time building a Bruno planter, Put some planting fabric in the bottom and started filling with top soil got 8 or 10 shovel fulls in and the whole bottom fell out :o. I had screwed two 1x4s along the long sides and put in short boards to fill the bottom. Well 4 screws into the ends of the 1x4s of wet old wood don't hold to good >:( :(. Rita decided to use 2x4s with screws along the long sides to hold them and drop the short boards back in and I could shovel the dirt back in :D
Ed K
Stephen1
Quote from: Ed_K on May 15, 2020, 11:34:13 AM
Whoops! :D
I use holey pine so the moisture could leak out.
RichTired
On this version, I screwed a 1" x 1" strip along each long side and used some cedar pieces for the bottom. I also used galvanized bolts to put it together so it can be broken down if necessary, and added cross brackets to hold a lower shelf.
Wood-Mizer LT15GO, Kubota L2800, Husqvarna 268 & Stihl 241 C-M chainsaws, Logrite cant hook, Ford F-150 Fx4
Richard
Cjross73
A little different idea from the original,  might sell through the summer months.
12" square with 1 1/2 square legs. Sold the first 4 singles quick at $25 each. Maybe $90 for the corner set...
Bruno of NH
RichTired
Richard
Peter Drouin
It must be the thing this year. Everybodys making them, Look on Facebook or C.L
Must be 50 guys doing it around here.
 Ride it all you can guys.
Good luck.
A&P saw Mill LLC.
License NH softwood grader.
Bruno of NH
One ground bed kit and 6 3'high beds out the door before noon.
Took an order today for 6 beds 3'high for a restaurant in the state capitol of Concord 60 miles away.
One guy waiting on customers and building beds and 2 of us sawing white pine for mill orders today.
WV Sawmiller
   Well, I finally broke down and built one and dropped it off at a local plant seller on consignment. I'll also post a picture on my Craigslist ad and see if there is a market for them here.
Bruno of NH
Looks good Howard
Sold 6 today
Built 6 more and have 2 to build in the morning before sawing
