'Nother Hoss for da Farm
Started by Magicman, September 17, 2019, 08:15:19 AM
The only tractor that I have had was a 1974 year 1530 (45hp) John Deere.  No FEL so there have been many time that I have been handicapped especially after I lost my neighbor with whom I swapped equipment when needed.
Yesterday Marty and I made an 873 mile (19 hours) trip and brought home a 2005 Kubota (54hp) M4900.  I will unload this "Big Orange" today and get a bit of feel for her.
Now I gotta find a set of pallet forks the will fit a Bushhog M346 FEL.   Also gotta install the canopy on the ROPS.
Crusarius
That looks nice. I wish I had gotten an M series, but I couldn't turn down the price I paid for the L2800.
btulloh
Nice lookin' iron MM. woodmizer orange too.
I'll be curious to see if you can find forks to fit a 4-in-1. I had to make some.
EDIT:  I see it's not a 4-in-1.  Finding forks should be no problem.
HM126
Southside
pineywoods
Congrats MM, with a few additions, that will probably be all the tractor you will ever need. Mine's an M4700 2 wheel drive with pallet forks and homemade logging winch. It has been rock solid, needing only 1 tire and a battery. OK, I have busted some of my home-made add-ons :(
Lynn,
   Good looking addition to the Orange family there in Mississippi. I hope you and Marty enjoy it and get many years of use and enjoyment out of it. Getting a set of forks should be real easy. Sounds like a bit of a road trip to get it. How did you find out about it so far away? Be careful and stay safe.
Resonator
Nice tractor there Mr. MM.  thumbs-up
I've been well pleased with my Kubota, big enough to load logs, yet small enough to zig - zag through the woods. I would think 2005 should be pre regen or DEF. Does it have stick-shift or Auto-Magic? move_it ;D
Nebraska
I bet after a while it becomes one of your best purchases ever. Id be lost without mine.  Congrats on the new iron.
Bruno of NH
Nice tractor
Did it come from N.Y. by chance?
Actually it came from Texas with the aid of web searches.  :P  That plus I found a set of forks this morning.  They are from my local Kubota dealer who is also a Bushhog dealer.  :)
Bruno of NH
Nice find on the tractor and forks
Andries
You'll be happy with that tractor - great choice.
It came with a bucket, and you've already found the forks. I'll bet dollars to doughnuts that you'll be looking for a set of grapples before too long.  Which makes a quick attach adapter one of the best ever inventions for the front end loader.
It allows you to turn a tool change into a painless flip of two levers.
Then comes the quick hitch for the 3pt. hitch at the back, a fire extinguisher, cast weights for the rear rims, chainsaw mount, tool box, . . . the addiction continues! 😆
Keep us posted as you " pimp up the 'Bota"
LT40G25
Ford 545D loader
Stihl chainsaws
btulloh
I might start a poll on quick hitch for the 3pt. From what I've seen, 95% of them ever sold have been sitting in a corner after a week or two use.
Quick attach is a different story. Pretty much a must-have. Wish I had one, but nothing to fit my loader.   >:( >:( :-\
HM126
Bandmill Bandit
Modify loader to fit the quick attach. I've done a few to the Bob_Tack type with excellent results.
goose63
My quick hitch for the 3 point never comes off I use all the time wood chipper tiller snow blower bush hog
goose
thank you to all the vets
btulloh
You are a member of the five percenters!   :D :D
HM126
LeeB
Good on you Lynn. You will really enjoy the forks. I have two sets and a two tine hay spike for my tractor. The hay spike gets more work than the bucket or forks. I use them like forks and they are great for scooping under a log.
Buck
Respect is earned. Honesty is appreciated. Trust is gained. Loyalty is returned.
Live....like someone left the gate open
I've had a Category 2 Quick Hitch on the John Deere since 1995, and it very seldom is ever removed.  My plans are to move it to the "Big O",as in "Big Orange" and install Pat's Quick Attaches to the JD.  I suspect that time may find QA's to both tractors.
Southside
Quote from: btulloh on September 17, 2019, 06:16:35 PMQuick attach is a different story. Pretty much a must-have. Wish I had one, but nothing to fit my loader.
There is a shop in Richmond that will make them for anything - among other places they advertise on CL in the heavy equipment section, they fabricate lots of skid steer attachments.
btulloh
Good info. I'll check them out and get a quote. Thanks.
HM126
pineywoods
MM when you see the need for aux hydraulic outlets, I can show you how to add them without breaking the bank. I added 2 more on mine to run a logging winch and hydraulic top link..
Thanks.  For now she is sleeping alone 'cause I have got to catch up on my sawing after getting out of the "sand box".  ;D
terrifictimbersllc
