Author Topic: Sawmill Shed  (Read 1030 times)
Offline Jstier
Sawmill Shed
« on: January 27, 2020, 10:16:53 AM »
Hey everyone! Thanks to all who helped me get my mill up and running. Had a belt twisting issue. Looks like my mill was sent with the wrong size belt  ::) I've since cut up about 3 11ft ash logs and pretty happy with the mill.
I am now looking at building a home for my mill. I've looked at this forum and lots of pictures online. Curious what you guys have and what works the best. I'd like to have a shed big enough for couple stacks  of wood inside and maybe a lean to outside for my mill? B&B siding. Thanks in advance!
Offline btulloh
Re: Sawmill Shed
« Reply #1 on: January 27, 2020, 10:32:08 AM »
I’d go with something 40’ x 150’ and the add on as needed.  :D
Offline GAB
Re: Sawmill Shed
« Reply #2 on: January 27, 2020, 11:11:55 AM »
Also build the ends such that they can easily removed for adding on later.
ie don't pour concrete you'd have to remove to expand.
GAB
Offline Woodpecker52
Re: Sawmill Shed
« Reply #3 on: January 27, 2020, 06:06:04 PM »
First off you need to go to the box store and order your lumber..... er,  or order one of them prefab metal sided ……..er  Oh heck just get you a piece of paper and draw off what you want, figure what sizes lengths pitch, and saw your wood, now that's a better idea.  I just built a shed over mine with an enclosed end for the head rig and it is attached to my metal working shop.  The mill doesn't get rained on that's all mine needs.  I wonder what % of mills are just covered with a tarp and left to weather.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Offline Frontier_Paul
Re: Sawmill Shed
« Reply #4 on: January 28, 2020, 03:50:06 PM »
<br
This is my little set up that works OK for me. Load from the side and out feed from the end then pick up with tractor forks. Trust me you will want to get your OS out of the weather or she will be a getting that surface rust on the tracks pretty quick. Good luck with what ever you do, let us see your final project.
Offline Jstier
Re: Sawmill Shed
« Reply #5 on: January 28, 2020, 05:12:07 PM »
I like that ! Any reason you put a floor down instead of gravel or just dirt. Yeah this crappy wet Indiana winter isn’t the best for it for sure.
Online Don P
    • Calculator Index
Re: Sawmill Shed
« Reply #6 on: January 29, 2020, 05:55:39 AM »
Do remember that when many rafters bear on a beam of considerable span that it takes a healthy beam to support them, especially if snow is involved. The roof landing on the mill does more damage quicker than rust will and is poor advertisement. When the span of a beam doubles does the beam need to be twice as strong?, the span doubled and the load doubled, it needs to 4 times as strong :P.
The future is a foreign country, they will do things differently there - Simon Winchester
Re: Sawmill Shed
« Reply #7 on: January 29, 2020, 08:07:50 AM »
It was more of a way to keep things level and easier to clean up the sawdust for me and all the lumber was free as i milled it all. The top header beam is solid 6'' thick and with all the snow we get here in South Carolina :) i feel pretty safe. Everybody has to do what best suits them and work with what they have. That is what makes AMERICA Great!
Offline Jstier
Re: Sawmill Shed
« Reply #8 on: January 29, 2020, 08:22:45 AM »
Yeah would be nice for the sawdust ! I can't tell from the pic but did you get the 7ft extension on your mill?
And how has the frontier been working so far? Norwood support has been A+ with any issues so far.
Re: Sawmill Shed
« Reply #9 on: January 29, 2020, 03:24:54 PM »
I did get the extension, needed for 16' material. I have had good success but like everything you live and learn. I had an issue at first with blades coming off but after getting a feel for things on the blade tension and speed of cut it all came together. I mostly cut southern yellow pines that drip out tree sap like crazy it seems and oak trees. Just a hobby for me and my own use. Support has been great and have had phone conversations with Trevor at Norwood several times on advice. Good luck and reach out anytime. PB
