Needing some help with 648g111
Started by Cable, November 20, 2020, 03:37:41 PM
Cable
I m having issues with 648g111 skidder. Ran all day . [I have typed a profane word that is automatically changed by the forum censored words program I should know better] it off set 3days an would role over but would not start ran the rail , got fuel but will not start. Coded910,913 on monitor . We cleaned all grounds
Roger Greathouse, JR.
kiko
F910  dash monitor does not recognize the ecu.
F913 abnormal upload rate. Basically times out monitor searching for ecu.
First thing is to check the ecu fuse.  Then check for switched and unswitch voltage to ecu. The unswitched voltage comes directly off the battery.  So if batteries were recently replaced make sure  that small wire is hocked up. It could be the ecu. If you get to the point of replacing the ecu, do not install a used ecu. Doing so will create a security violation were the dash module recognize an incorrect ecu data tag and will lock the monitor permently after a few keys cycles. It will have to be replaced as well as the ecu at this point.
mike_belben
Way to kick a guy when hes down john deere.  Like you guys really need the money.
Praise The Lord
