Author Topic: Information on O28 stihl  (Read 3378 times)
Offline dave7191
« on: September 18, 2008, 05:53:49 PM »
 Anyone Know where there is a diagram of an O28 stihl  My oiler quite and I wanted to see how it is built  I haven't run fuel oil  through it yet  will tomorrow but if that doesn't  work will need to fix it
Offline Rocky_J
Re: Information on O28 stihl
« Reply #1 on: September 18, 2008, 06:35:45 PM »
I don't have a diagram or part number but the procedure to get to the oiler pump is about the same for most saws. Remove the sprocket and clutch, then it's right there and held in place with 2 (sometimes 3) screws. There's a rubber grommet type seal where it fits over the hole going to the oil tank and on that old of a saw there is probably a rubber tube running from the pump to where it runs out to the bar.
Having an air compressor is extremely handy since there will be lots of old oily crud to blow away (wear old clothes). I usually spin the clutch off with an impact wrench as well instead of messing around with pulling the spark plug and using a piston stop. Keep in mind that the clutch is left hand thread.
There are several things it could be, but the pumps themselves rarely go bad. The plastic drive gear or output hose are two of the common failures.
Offline joe_indi
  • The older I get the more I learn
« Reply #2 on: September 19, 2008, 05:57:34 AM »
Dave, I have created an album (028) in my  gallery showing the 028 oil pump, other parts and parts list with part numbers.
I don't know if this link works, but give it a try:
https://forestryforum.com/gallery/thumbnails.php?album=1999
If it doesn't work you can try and access the album " 028"
Hope this helps.
Joe
Offline dave7191
« Reply #3 on: September 19, 2008, 09:56:42 AM »
Thanks For the help that was what I needed
Offline dave7191
« Reply #4 on: September 21, 2008, 09:22:11 PM »
Looks Like I'm going to have to tear it apart washed it out good today and it still doesn't want to pump oil
Offline mike_van
« Reply #5 on: September 22, 2008, 05:44:18 AM »
Dave, inside the oil res. is a pickup tube with a screen in the end of it - check that too -
Offline dave7191
« Reply #6 on: October 01, 2008, 10:19:43 PM »
 Took the saw apart yesterday the oil pump drive gear was mess up clean the burs off of it and turned it over put it back together it seems to be working fine now will order a new one in the next few days Thanks again for the help
Dave
Offline beenthere
« Reply #7 on: October 01, 2008, 10:45:30 PM »
Punctuation does wonders for the english language... ;D ;D ;D
Offline woodmills1
  • the truth shall set you free
« Reply #8 on: October 05, 2008, 08:56:50 PM »
I really loved those 028's probably had 4 or 5 of them, but my MS 280 is the bomb.
Offline SawTroll
« Reply #9 on: October 08, 2008, 06:14:04 PM »
There are several different versions of the 028 out there - don't know if the oiler was the same on them all........... :-\
Information collector.
Offline wannabeonetoo
« Reply #10 on: October 08, 2008, 09:25:24 PM »
woodmills,what's the difference between 028 's and 280's ?what are the cc's ?
I have an 026 and it is a "killer saw". I also have an 044 and it's great too, but I tend to reach for the 026 more often than not.
     Steve
Offline woodmills1
« Reply #11 on: October 11, 2008, 07:37:52 PM »
not sure about engine size but the ms280 is much up dated more modern, lighter and faster with better air filter, carb and caps.
Stihl Information
Started by staggerweed on Chainsaws
Last post March 17, 2010, 07:50:44 PM
by SwampDonkey
Please help me buy a Stihl MS461...information request
Started by woodworker9 on Chainsaws
Last post July 14, 2017, 05:25:26 AM
by PNWRusty
just looking for information
Started by Randy1965 on Forestry and Logging
Last post November 28, 2012, 09:51:49 PM
by WDH
Looking for help and Information please!
Started by ocfwjdh on Firewood and Wood Heating
Last post December 10, 2014, 04:27:00 PM
by ocfwjdh
