Logging Waste Products
Started by Nate Surveyor, January 31, 2008, 12:08:25 PM
Nate Surveyor
I know that I probably am wrong, but it seems to me that the cut off tops of trees, that rot could be chipped, and made into stuff. Like pulp mills, and turpentine.
It seems to me, that to chop off all the tops, and limbs could be run through a hog, and used for something. Maybe pellet stoves, or fuel source for sawmills that generate power.
Is anybody harvesting the WHOLE tree, productively?
Thanks,
Nate
I know less than I used to.
Ed
In some places, on large scale operations, the whole tree is utilized.
I don't know if Deere is the only company making one of these.
http://www.deere.com/en_US/cfd/forestry/deere_forestry/harvesters/wheel/1490d_wheel_harvester_video.html
On a small scale I can't imagine it being profitable to use the whole tree. Accessability would be a major issue when dealing with a select hardwood harvest. The size of the tops (large) would also come into play as well as the distance the "product" would have to be hauled to the nearest facility that could burn it.
Most of the time there isn't much waste from a hardwood harvest, after the logger finishes and the firewood cutters get done only the smaller branches remain. After the branches decompose into the forest floor, nothing is wasted.
Ed
I belive whole tree use is most times considered biomass use of the scraps/leftovers.
In some situations that can be good, but the tops contain most of the needed nutrients for the forest floor to continue producing.
Onthesauk
Out here, at least on the State forest contracts, they require that all that be left on the ground.  Slows runoff and erosion.
Down closer to the cities, when they clear for development, they bring in tub grinders and haul it all to the pulp mill.
John Deere 3038E
Sukuki LT-F500
Don't attribute irritating behavior to malevolence when mere stupidity will suffice as an explanation.
Ron Wenrich
Another factor is that quite often the tops will allow seedlings to develop and keep deer away from them, at least in hardwoods.
For the most part, the economics gets a little tough for dragging tops long distances and then reducing them to chips.  Cost of a good chipping operation is in the millions.  Return on the biomass is about $25/ton delivered, and in some places even less.  Your logging costs just get too high for the return.
Woodhog
That Deere baler thing is pretty neat..
They appear to be picking up everything. In our Best Management Practices Manual they mention to leave woody debris in cutting operations.
Is this good practice to be picking up everything, if left natural  this stuff would rot up and do something some good in the grand scheme of things.
It doesnt seem to fit the natural cycle of things, I have noticed over the years when the natural cycle of things is changed too much  we usually end up with something messed up.
I did a tour of a logging job with the grandson 3rd grade class and they was taking the whole trees.They would cut out the logs and chip the rest.I don't think there is much money in biomas chips for the land owner.I would rather see it go for pulp.But chipping it I suppose is quicker.It looks real good when the lot is chipped.Looks like a park if that's the look you want.Some loogers don't want the expense of a chipper and trailers.Around here most loggers take pulp down to 4 inches.Taking the pulp out just really cleans up the tops.I know it's differant in some regions,but around here it looks bad to leave the tops.I would cross that logger off my list if it was done here in Maine.Just the way things have been done around here.
Rocky_Ranger
Ron, can I send you a couple pics for you to post?  I never tried to do them before.  We have/had a whole tree chipper working here in first thinnings (loblolly - 20 yes old) and it's amazing what that thing will do.  Folks are correct on the investment, but they were getting $55.00/ton delivered and chipping 22 tons/van load in 20 minutes.  Outstanding.  Problem is some dude in Canada bought the whole operation and they loaded it up one day and hauled it north......
With needles turning every three -four years we are not seeing a large amount of nutrients lost.  The skidders do turn some of the outcast bark and limbs back out into the plantations.  Very little goes back into the stand once the logs reach the landings.  Belsaws and Hydroaxes with pull through delimbers create a little more debris, but not much.  Most loads look like brush piles heading done the road.  Talk is $85.00/ton chips by early summer.......
RETIRED!
Ron hit the nail on the head.   The economics don't work out.  The cost to produce the biomass exceeds the price the current mills can pay.  Sawmill residues such as sawdust and bark set the threshold price that biomass must compete with to be burned as fuel in a boiler.
I am not sure about the price threshold for cellulosic ethanol, but the technology has not been proven on a scale operation yet.
As to the John Deere biomass bailer....we used the bailer on our property in LA on a trial.  Did a pretty good job, but again, the delivered cost to the mill kills the deal.
Gary_C
There is a lot of change going on in this biomass business right now.
Here in Minnesota we have a large chipping operation that almost out bid a sawmill on a red oak timber sale. The chipping operation was going to chip whole trees to fill his contract for hardwood fuel chips for a St. Paul power plant. Even then the chipper operation made a deal after the sale to go in and chip all the tops after the logger gets his logs and whatever firewood he wants. I have no idea what they are getting paid for chips, but I've heard they were hauling 50 semi loads of chips per day to the power plant.
That power plant is switching away from coal as they expect new long term coal contracts to increase in price very soon.
Another demand for biomass is from the landscape mulch chippers. They have been getting paid to clear housing developments and got free biomass from all the trees they got paid to remove. Now that the housing markets are so bad, there are no new developments and they are scrambling to find sources for their biomass. They may even have to start buying their own timber sales.
Most of the large loggers are adding a chipper just for dealing with the tops. Some sales do allow for chipping the tops and if you are not able to utilize those tops you may get outbid by some logger that can.
Gary,
Down this way, a chipper costs $750,000.  Of course, that is a big production chipper capable of producing 20 tractor-trailer loads a day.  At that cost, a logger has to chip a whale of a lot of biomass.  Just the tops off the logging job are not nearly enough.
Like you say, if you are chipping guts-feathers-and-all for a power plant, that is a different story.  A logger can make production in that circumstance.  With the price of fuel (as I am sure you are painfully aware :)), the wood-equivalent-price is higher than people realize to replace oil with wood.  The problem is, the markets are rather local, so in many places, the market may not be there at all.
I am watching the whole biomass business very closely to see where the wind is blowing.  So far, a lot of talk and not much action in this part of the world.
pineywoods
Don't know about other areas, but here (north central louisiana) the chip trucks are running 24/7 and there's a bunch of them. The three large paper mills in this area are converting to biomass instead of natural gas. Most of the chips are from first thinning of plantation pine. but some from tops in regular logging operations. In most cases the loggers are contracting out the hauling. I just had a logger clean up 28 acres of small sweetgum and pin oak, leaving the pine and log sized hardwood. Plan to log the rest myself and then re-plant. Chips bring the land owner 50 cents a ton. Hardly worth the damage to the land, but I think it will pay off longterm.
Frickman
It is very difficult to make any money now logging higher value products like saw and veneer logs. I can't see how I could make money harvesting biomass.
If you're not broke down once in a while, you're not working hard enough
I'm not a hillbilly. I'm an "Appalachian American"
Retired  Conventional hand-felling logging operation with cable skidder and forwarder, Frick 01 handset sawmill
Pretend farmer when I have the time
fencerowphil (Phil L.)
The most recent ripple in the pond for extreme use of "everything but the squeal"
in my area of Georgia is the new ethanol plant being built by Range Fuels.  Ground is
broken and work is beginning near Soperton, GA.
The intention is to use pine to produce ethanol.  The process is supposedly proven,
but has never been used on the scale required for commercial success.  I think I
remember that it will need something around 100 chip loads a day to operate.  This
part of Georgia is really saturated with young pine.  It remains to be seen how the
process will actually perform and what effect it will have on our area.
One would assume that it will surely give new meaning to the term "clear cut."
It may even create a link to another term: "soil depletion."   Will the hunger of this
process create a little blip in the price of pine thinnings, tops, etc.? Maybe.  Will any
significant rise in price simply shut down the operation, making the ethanol too expensive
to produce?  Will the Middle East simply begin to lower oil prices to squelch U.S. efforts to
diversify in the area of energy?
It does stand to reason that many more local small operations will have a closer
location to send byproduct chips, etc.   That means less fuel cost for the provider of the chips, hence
a better return.   It may not be enough to justify the full-blown efforts such as WDH is
talking about, unless someone would guarantee a sufficient supply for X number of months
at X number of dollars per ton.   In that game, of course, big equipment wins.  The little guy
with a few loads a week just has to take what the buyer will offer - an amount which will always
depend upon the rates of the big contractors in the game.
Phil L.
Bi-VacAtional:  Piano tuner and sawyer.  (Use one to take a vacation from the other.) Have two Stihl 090s, one Stihl 075, Echo CS8000, Echo 346,  two Homely-ite 27AVs, Peterson 10" Swingblade Winch Production Frame, 36" and 54"Alaskan mills, and a sore back.
timberjack240
not much goes to waste with us we are to take logs .. obvisously .. and the strater poles out of the tops for firewood so basically all thats left is the brush and some limbs that are really crooked .. the blocks that are left in the landing and some of the tops people cut up for firewood so therses not much left and wht is rots down in a few years and biulds up the gorund then at the mill all the "waste" is chipped and ground into mulch so basically there isnt much that goes to waste which is good cause i hate seein wood go to waste
Samuel
We are utilizing full tree as our operations are 100% portable chipping (see profile for pics).  The hog fuel produced from our ops is either spread back out into the cut block or if within 100 km of the mill, is hauled back for the boiler to run the pulp mill.
As far as going into a block and chipping tops only, does not result is great quality for pulp especially.  Hog fuel yes, but for highg quality pulp, we have to keep our bark content below 2%
____________________________________
Samuel B. ELKINS, RPFT (AB)
Senior Consultant (Owner)
Strategic HSE Systems Inc.
Web: HugeDomains.com - StrategicHseSystems.com is for sale (Strategic Hse Systems)
LinkedIn http://ca.linkedin.com/in/samuelelkins
Software Solutions-
DATS | Digital Action Tracking System by ASM
I'm pretty sure when Cfarm says he doesn't like tops left, it's those huge main limbs on hardwoods that stick up 20 feet in the air. As one logger said, if he can look 1/4 mile down his cut block and see tops 20 feet in the air, his crew is wasting wood. I like the fine tops, anything smaller than 4" to be left behind. It's gone in 10 years around here and if it's softwood tops there is a lot of good seed ready to come up next spring in those skid paths, providing it was a good seed year. Around here if you harvest and forward the wood, you get pretty much aspen only on the site. We get a lot better thinning sites on harvests that were skidded. The only exception are sites with established advanced regen you try to protect by forwarding and it takes a skilled operator to not destroy the regen because of all the extra handling and maneuvering and processing.
Yes,swampdonkey that's what I meant.Most loggers around here will work the wood down to 4 inches for  the pulp.Some will run over the tops to knock the branches down and knock every thing else down too.But some will saw the limbs off when they are done.I know time is money the way things are,even if the equipment is all paid off.It will rot very quickly if you get the brush on the ground.
okmulch
I run a whole tree grinding operation here in Oklahoma. However it is strictly Eastern Red Cedar. We run the whole thing needles, limbs and trunks for mulch. we do have to let the needles dry first so the mulch will not mold, but when we are done clearing land there is very little residual left mainly just dust that has blown while grinding.
Rotochopper b66 track, #2 Rotochopper b66 track, woodmizer lt40, CAT 277b, CAT 268b, CAT 287c, CAT 277c, CAT299d2, CAT299d3, CAT 299d3, Volvo 70e,volvo70f, volvo90f
Maineloggerkid
    Here in Maine, most logging operations up here in the northern part of the state do this.
JD 540D cable skidder, and 2 huskies- just right.
Loggers- Saving the world from the wrath of trees!
solodan
When the forest service perscribes it on a sale out here it is chipped at the landing, then the chips are trucked out. It is a money loser, cause a round trip to the mill could be 200 miles on mostly dirt roads. trucking far exceeds the value. :-\
sawguy21
BCFS insists on site cleanup due to fire hazard so waste is hauled to the mill for hog fuel, a money losing proposition. Slash used to be burnt on site during the winter but emission regulations have pretty well ended that practice.
Samuel
Quote from: Samuel on February 03, 2008, 08:55:35 PM
UPDATE:
Just an update on in-bush full tree portable chipping, the calculations have been completed from a study we completed last winter, and we can indicate now that we are recognizing nearly a 20% fiber gain from chipping rather than our previous tree length operations.  We are also recognizing ecological benefits to the small debris (unprocessed hog) we leave behind in our cutblocks (scattered throughout at spacing predetermined by Provincial policy) through wildlife use (i.e. nesting for birds, toads, etc).  We have also noted a 1-3 meter increase in height of the poplar saplings within a 5-10 meter radius of these piles.
Software Solutions-
Must be some fast working microbes producing some nitrogen eh? The chipped waste wouldn't be available to plants, but possibly there is some release through rainfall. Kind of like a compost tea or something. You will notice some black tea like effluent from softwood debris in pools of water, sometimes with an oily slick. This is just through many observations I've had over the years around harvest operations. I'm sure somebody has a big tech report written up and sitting on a shelf about it.  ;D
It could also be attributed to the retention of water by the piles, like mulching a garden.
Yes, never thought of that Tom.
jeremyperkins41
Quote from: Frickman on February 01, 2008, 03:48:38 PM
You better take the logs and cut the tops to sell also as firewood wit heating cost going up. ;D
zackman1801
awhile back i took a trip to bethel maine with my forestry class to a job Chadborn (spelling?) tree farms was doing, they were using a harvester and feller buncher to harvest trees. the buncher was going through and taking out all the small useless stuff so the harvester could get to the better stuff. then they had 2 grapple skidders going in and taking the small stuff, and the tops the harvesters left behind and taking it to the landing to a big chipper with its own loader attached and chipping it right into a big rig on the landing. Then as the harvester harvested logs a forwarder would go through and take out the good logs. they also had hired a local logger to go in and take out the large pines that the harvester could not take down (harvester could only handle up to 20" logs i think the supervisor said)  he would just for the most part take the trees out full length and buck in the landing and only leave the branches in the woods.
Although there are consequences to taking all of the branches and leaves out of the forest, they provide vital nutrients to the other trees in the area as they decompose so if you take everything out there is less nutrients in the area for the trees you left over. thats one of the reasons that the maine forest service started cracking down on big clearcuts in northern maine. companies were just going in and taking out 200-300acres of woods at a time and leaving nothing there, it was destroying the soil so that trees wouldn't even sprout up again.
"Improvise, Adapt, OVERCOME!"
Husky 365sp 20" bar
zackman,
200 and 300 acre clear cuts may not be as bad as some people say.  It really depends on the lay of the land and species of the trees that are expected to replace what was taken.  That is why a Forester should be used to plan a harvest and not leave it to someone who only cares how much fiber they can remove.  If a Forester specifies a clear cut, there is a reason.  It is a valid and common management practice and may lead to betterment of the forest in the long run.
There are too many knee jerk assumptions made by folks who declare a management practice invalid without understanding the whole ecological story.  The media is bad about it because logging makes good pictures and articles if devastation is the subject.  It's easy to cry wolf when the immediate aesthetics aren't understood by the general population.
Some "Real" Foresters will be along after awhile and make good explanations.  Don't be afraid to ask them questions.  :)
zackman1801
im not saying that its bad to clear cut in all situations as i understand that forests from time to time need to be completely restarted to make them grow better.  They now require here in maine buffer strips of a certain amount of acres on clear cuts to make sure the soil dosent get too eroded. here in maine thats been a big fuss, if someone drives by a landing and sees mud dribbling into the road they would most likely call a state inspector of some sort who would come down and give you a fine. there are alot of people out there who dont like what we do and will do anything to stop us.
Husky 365sp 20" bar
jeremyperkins41,welcome to the forum.You will like it here.
Zackman, I don't pretend to be all that well informed about forestry in the state of Maine. But most of the dark clouds I've been reading about have been caused by aesthetics of the view scape around townships and the fact that some private land has been bought up to simply cut the guts out of it and do nothing further with it like silviculture to nurture along the new forest. Yes, I'm sure there are troubles with erosion because some people can't seem to stay out of soft ground around water where some of the biggest spruce grow and improperly built roads lead to a lot of runoff and erosion. There is also problems with high grading. It happens here in NB as well and on 99% of woodlots there is no real plan or a forester involved so it's free-for-all for loggers. Most of the time if a forester gets involved he has to be the logger to in order to get the work and do the best he can. This is often a catch 22,. Who is he working for?. In addition, some lots are not even properly marked between adjacent owners, a whole set of other troubles.
As far as not being able to grow new trees from a freshly clearcut lot with all the fibre and debris removed, that isn't so. It takes many rotations of whole tree removal on most soils and fewer on some of course. Our soils are not like the tropics. With the media and highly paid movie celebrities with good looks and misinformation, people think what applies to Brazil forest applies to Acadian forest. Maybe if your lucky (some don't feel so lucky), you opened the site up to brachen that return N-P-K to the soil, maybe a few alders and hazel shrubs. But, then maybe hydrology is impacted, not necessarily so much by erosion but temperature increases, which effects streams and water table levels. Maybe more severe flooding and faster fluctuations in stream flow volume. Sometimes a site will become wetter after a clearcut, sometimes much drier.
They chipped forest here on crown land with the whole tree method in the 1980's. Everything but the leaves and roots left the sites. It was mostly discontinued because of equipment costs and because they, for the most part, changed their mentality about converting hardwood forest into spruce plantations. It still continues on a small portion of private and some free hold. Although, tolerant hardwood (beech, sugar maple, yellow birch) conversion is not supported by the government tree planting program on private lands. The thing about those types of harvests where everything is removed it opens the land up to pioneer species which are often not as desirable as the mature trees that were removed. Although, aspen is worth about as much as spruce right now and has decent markets up this way. Often the hardwood sites will be initially taken over by aspen, birch and pin cherry and many lesser shrub species like mountain maple, striped maple, beaked hazel, elder, raspberry, and blueberry and of course hardwood stump suckering. Great for the little critters and small birds though. Sometimes a hardwood site will be reclaimed by fir if the machinery doesn't destroy it. And hopefully that fir isn't 50 years old and 3 feet tall.  ::)  Most mature softwood sites on well drained sites will convert to aspen here as well, left to break up, softwood returns and favors fir with white pine and spruce scattered. Cedar sites often will return to cedar with some fir and spruce scattered after invasion by willow and balsam poplar, sometimes tamarack the first 80 years. Sometimes the biggest detriment to cedar regeneration is beaver flooding on those low sites. We had 25 acres destroyed by beavers after a harvest. Well, I guess you could say we created habitat for beavers and they really didn't destroy anything.  ::)
I looked at aerial application of fertilizers on forests and most of the nitrogen was lost in a short while by rain into nearby streams and the effects of increased growth were only temporary, lasting up to 3-4 years. Only the dominants benefited immediately, while co-dominants delayed their growth response and suppressed trees where further suppressed. The effects of thinning on increased growth rate lasted 25 years in comparison.
I guess I've gone all over the page with my post here. Let's just say clear cutting and biomass removal has it's place when properly implemented and should be limited to certain sites. It gives more $$ returns per harvest, but yields less volume per time horizon. Less volume because you have to start over, while with a selection method you still have mature trees growing volume and immature ones becoming merchantable because of growing space. Gives you more entries over the time horizon, typically 80 years. Add all the volume from those multiple entries and you have more total volume. It's not because of soil depletion, although I'm sure there is some impact. Multiple entries can have it's side effects to, such as increased soil compaction which also effects soil fertility.
jeremyperkins41
Quote from: thecfarm on June 15, 2008, 04:13:52 AM
Thank you I like it already.
