372xp problems
Started by seacraft18, May 27, 2011, 01:04:48 AM
seacraft18
I have a fairly new 372xp that has only cut approx 10 cords of firewood.
The saw has always run well with no issues.
The other day it stalled on me,  a few times between cuts.
Now, once I start  the saw, the only way I can keep it running is to run it almost full trottle.
any ideas.... I have not touched the H/L carb setting ever, is this a case where now that the saw is broken in, they need to be readjusted ?
I burn 50:1  and 93 octane.
any suggestions on troubleshooting this would be apprciated.
Still under warranty? Seems like I brought my back to the dealer after a month or so many hours to be checked out,re tuned. The low idle may need to turned up some.
shinnlinger
Did you store it with gas in it?  That can break down the diaphragm pretty quick.
Shinnlinger
Yoopersaw
The carb needs to be readjusted after 5 or 6 tanks of gas through it.  Low idle adjustment is off for sure.
Jaybolicious
I had similar problems with mine last week.  You didnt happen to see any roller bearings all over the ground did you?  The needlen roller bearings under the clutch drum may have gone on it.  It slides over the crankshaft.  There is a little c-clip that I lost too when the bearing went.  I concluded that I had tightened the chain WAY too tight.  I'll never do that again.  My saw is a 2000 and I bought it used, so it may have been on its way out anyway for all I know.  Hope you get her runnin again.
joe_indi
50:1 with RON93 should leave the spark plug fairly clean and dry.
Confirm this by inspecting the spark plug
If the plug is black and oily with 50:1 fuel, your saw could be running rich. But before adjusting the carb, you might try to find the reason.Simplest reason would be a wet or partially blocked fleece filter.
But if the spark plug is dry and light in color the reason could be different.
A partially blocked pick up body would be the simplest reason.
Joe
Jimm
When I had that problem it turned out to be the rubber hose from the tank to the carburator. I believe this is a common problem with Huskies.  good luck
seacraft18
thanks Guys.... I will check these things out
Ron Scott
It may just be time for its "break in" period tuneup.
~Ron
IndyIan
Maybe it doesn't need to be said, but I wouldn't run it at all, other than to diagnose what's wrong with it.
HiTech
    Could be the ethanol in the gas ate the carburetor up. There was a recall on some saws. I think the 357xp was one.
Yoopersaw
NCFarmboy
Quote from: Yoopersaw on June 30, 2011, 06:57:01 PM
What fixed it?
The 357/359 (also applies  to 340-353 series) has a service bulletin to replace plastic clamp on the intake tube with metal clamp and new partition.  Was not a recall.
Shep
Lots & Lots of Saws
KevinE
Quote from: Jimm on May 29, 2011, 10:18:41 PM
That's what I was thinking too! Unfortunately it happens to Stihls as well as Huskies  :(
SawTroll
Hardly common, specially not on a nearly new saw.
This sounds like a classic case of a too lean L setting, or a too slow idle (or both).
Quote from: Ron Scott on May 31, 2011, 07:42:40 PM
Yes!
Information collector.
ladylake
I'd really be checking that clamp on the booth, sounds like it could have come loose.   Steve
