JD540b tranny diagram
Started by taurus, December 15, 2019, 05:14:32 PM
taurus
I am wondering if anyone has a link of where i could find a diagram or schematic of the outside of the powershift tranny in am 80s  jd540b cable skidder... 8fwd, 4 rvs.  I have a leak on the left side of tranny .. its a hard spot to see.. kinda in between the front rearend and the firewall.... in behind the body of machine... has anyone had a similar area leak? wondering how to go about the repair once i find it? pull rear end.. left cab?  dang this deeres are tight to get at stuff.
DennisK
See if there is a pan underneath pedals/ steering pedastal, there's a tee fitting for lube pressure. Pre 72 I can't remember if there's a tee, 73 on up, there should be 2 lube lines. (Standing on your head they might be visable), working from the right side of the operater station might help.
