mandrel tachometer
Started by lyle niemi, April 23, 2012, 08:29:28 PM
lyle niemi
I had robbed this off the old combine also. It was used for the cylinder speed but should work good for the saw speed also..its worth a try
Woodchuck53
And a DanG idea. I got lots of combine parts.
Case 1030 w/ Ford FEL, NH 3930 w/Ford FEL, Ford 801 backhoe/loader, TMC 4000# forklift, Stihl 090G-60" bar, 039AV, and 038, Corley 52" circle saw, 15" AMT planer Corley edger, F-350 1 ton, Ford 8000, 20' deck for loader and hauling, F-800 40' bucket truck, C60 Chevy 6 yd. dump truck.
snowshoveler
That is a DanG idea...be pretty nice to tell at a glance what the mandrel is turning.
You can keep track if the shaft slows when you are in heavy cuts.
Chris
International T5 dozer
JD M tractor
MF skidloader
Jonsered chainmill
Vintage Belsaw
lyle niemi
Quote from: snowshoveler on April 23, 2012, 08:58:52 PM
Chris
I was just playing with it and it doesnt even need power to make it work. it must create its own power when it turns to send a signal to the tach. The mandrel shaft looks pretty close to the little pulley on the combine. It might be bang on for being accurrate. I will let you know when I get to that part of the project 8)
lyle niemi
Even tho the weather was not very nice, it was cloudy with a cold strong wind and still lots of mud, I had to do something. I installed the mandrel tach drive and the instument cluster. I used a heavy O ring as a belt. Betcha wondering how I got that O ring around all those pulleys with out unbolting anything???? Well I remembered that I have an O ring repair kit, I just measured out the O ring material and glued it, I first tested out the glued Oring and you can stretch that out a mile before it will let loose. It should work good 8)
snowshoveler
Nice setup. I was wondering how it would work.
Now with the pictures and explanation I know.
Chris
JD M tractor
MF skidloader
Jonsered chainmill
Vintage Belsaw
reride82
Great idea Lyle, I'll have to check and see if there is anything like that on either of the scrap combines I have at my disposal.
Levi
'Do it once, do it right'
'First we shape our buildings, then our buildings shape us'
Living life on the Continental Divide in Montana
I do not need a mandrel tachometer, but I am interested in that O Ring Repair Kit.   ;)
lyle niemi
I fired up the mill and tried out the tach, I compared it to a hand held one and its dang near bang on! At 2100 the mandrel is running a little over 600.
Majicman, I looked at the O ring kit but could not find a label on it. Not even sure how it got in my shop.
Majic,national "O" rings makes a kit coils of "O" ring stock cutter cleaner and adhesive.I have found them best on static sealing duties.Have in a pinch used crazy glue,but I won't sware to that. Frank C.
ALWOL
   That looks like it will work really well, and be a big help to you in your sawmilling.
   John Henry Foster, the hydraulic supply house, will also have those o-ring repair kits.
   Alan
There's a big difference between staying busy and making money.
eastberkshirecustoms
McMaster-Carr also carries the splicing kits: http://www.mcmaster.com/#o-rings/=ha3won
They do come in handy when you need an odd or custom size, or as Lyle has shown- when you need a small belt ;D
dave9252
Quote from: lyle niemi on April 26, 2012, 08:14:47 PM
If its the 1 i left there for you a while back, no-one needs to know where it came from.. lol
Or should i just say 'perks of the job'..........
