Safety Alert Sawing Power Poles
Started by Woodwalker, May 18, 2006, 11:05:21 PM
Woodwalker
There is a wood preservative treatment process that the company I work for has discontinued because of serious safety concerns. It may be common practice for other utilities employ the use of this product. I found no discussion of it on this forum and with some people sawing old poles I thought it might be of interest.
Methyl Isothiocyanate (MITC) or MITC-Fume is applied in a closed delivery system where a hole is drilled into an existing pole and a porous aluminum tube (approx. ½" X 6 ½") is inserted into the hole about ground level then sealed with a dowel. The poles are tagged with a rounded corner triangle emblem with "MITC-FUME" stamped on it. This substance is toxic and a severe irritant. It is also highly toxic to fish.
LINK
LINK
LINK
Watch for the tag, which should be about eye level and watch for flush cut dowels near the ground line.
Just cause your head's pointed, don't mean you are sharp.
