Well after weeks of no work I finally may have a lot to cut thanks to my wife. So went to look at it last night, small in size only five acres but with some of the biggest and nicest timber I've seen in a log time. From what I gathered when walking the land it is a old growth forest that has never been logged. A mix of oak, maple white pine, yellow pine and a few others. Some of the oaks and maples are pretty big, two feet plus at DBH and straight and with minimal defects. I'm a little nervous about cutting these bigger trees because they have to be cut and bucked the right way to Maximize the profit. How do you decide what the logs should be bucked at? I don't want to cut a pallet log that should have been a prime log. I do have the sawlog bulletin and will probly sell the good grade logs to hull forest products but there are so many different categories of logs. I'm used to cutting firewood grade and white pine and pallet grade but not this nice of timber. Thier is also a neighbor that has even more land with the same untouched timber that wants thier timber cut. Feel free to give any tips or suggestions.
Can you get the logs tree length to the landing and let your buyer decide how to cut them?
Yes the farmer has a big field I can use as a landing.
Moosehunter has the best suggestion. Also unless they are paying top dollar for pallet you might as well keep and sell it as firewood.
Just a thought but around here when selling logs we can pull them out tree length and have potential buyers come in and bid on them. Like you said you don't wanna cut something 8ft for pallet would that should have been left 25ft for veneer.
Good advice from all, let the top bid buyer mark them off.
If your selling to Hull,call them and get a cut list.They'll have diferent cut lengths by species and how much trim.Not many mill buying pine right now,but hardwood is wide open.
Those are some very good tips guys I think it will be in my best interest to cut them as long as I can and skid them tree length to the field were I can have log buyers come in and bid on them. I may sell the hardwood to hull it will depend on who bids the highest. The local mill will buy the pine and softwood pulp.
Do you think that is the best way to cut and sell the logs? Also I'm thinking about working out a % split with the land owner. He basically told me he is not looking to get rich on it, would just like some compensation and a little firewood from it. The land is very flat very little underbrush and dry and it is a short skid to a open field I can use as a landing. In your opinion what would be a fare split keep in mined it is just me and one cable skidder.
I look up what the latest stumpage report from Umass has and pay the land owner that price.If I get some veneer I'll split it with them.My last 3 jobs were a 50/50 split tho.Are hardwood price going up any down you way?I'm suprised that y/birch is paying better than r/oak now.
I was thinking about starting with an offer of 30-70 split? If that didn't work I would go 40-60. Pricing around here are close to the same and holding steady but soft wood pulp has gone up a little. Tree length firewood is up as well. I think what I'll wind up doing is cutting and skidding tree length and calling the mills and let them make the decisions on how the logs should be bucked and let the highest bid win.
logman81
Your "thinking" is a bit puzzling to me. If you are talking about splitting the wood you log, how are you going to measure the wood and how do you plan to decide which wood is yours and which is not?
What I meant was splitting the profits from the sale of the logs with the landowner and give him his share of the fire wood that he wants.
Well I'm going to call the land owner tomorrow and throw my proposal at him and see what happens.
What if the landowner gets in touch with a forester? ;)
He won't he don't want to bother doing that for such s small sale.
If it's good cutting 50/50 would be the only way that I would let you do it on my land. If the trees are not that big,40/60 would be the lowest I would go.
Yeah, lay a few out and have the buyer mark them that should give you a good idea of how they want them.
Seems to me if the wood is that prime, a little research into specialty markets could really boost your bottom line. I would be looking at export markets as well as aviation type end users(propeller manufacturers) like sensenich, or even Kaman Aerospace there in Connecticut. They use quite a bit of high grade yellow birch and maybe hard maple for rotor blade spars, and other bits. It pays to do your research. Even if some markets don't take raw logs, if the wood is top grade and tight grained, you may make out way better working with another FF member to mill grade cants or spec'ed sizes of CVG boards. Might make the difference between 1600/mbf and 5000 or more.
I took a log bucking class one time and really helped out.big wood and your own job u want to cut for quality not quantity u will make more.u will also have lots of chunks left over on the landing that will need to be split into fire wood or pushed back into the woods so his field will be cleared and won't be unsightly job. Clean up is never fun.it's amazing less wood on the truck and more chunks on the ground means more money.good luck cuttn the big ones.
I have to agree with timberlinetree, my 1st few jobs I pulled tree length and had the buyer mark the cuts and the $ I got for the logs was 20% less than when I learned how to buck for grade. I dont no if it was because the buyer had to put work into the logs or because he knew i did not no what i was doing. It would be in your favor to learn log grades. If I was going to do a split 50/50 or what ever I would seal the deal with the land owner with him understanding you will bring buyers in to give bids while the trees are still standing to get the best offer for his timber. jmho.
I would pursue the markets and offer a 50/50 split as the last thing you want is a disgruntled land owner trashing your business cause he's not happy when said and done. I have done it both ways and also live in a small town and the unhappy ones still have some nice timber standing. Those were in my younger foolish days when it was all about the green back, now I am grateful to be just out there paying the bills. Good luck and I dream of these kind of jobs your about to embark on.
David
Why not cut it by the thousand? I'm not sure of the rates in your area but if the timber is that nice try for about $180 to $200 / M, maybe even more. That way you can not loose. Those trees may look good on the stump but what happens if they don't open up very good and you have to start cutting blocks off to get to good wood? Doing this on splits you could loose a lot of money in a hurry. Doing it by the M you can loose volume this way and some $$ but on splits and loosing grade you can loose $$$.
I see your point Bill m and it's a good one it makes better sence to do it that way.
Price report for my area is between 70-275mbf. White oak 40-100mbf.
Quote from: logman81 on August 09, 2013, 11:49:42 AM
Whst are these prices for? Cutting or logs or standing timber.
Those are prices of what standing timber is being bought for, but I just looked at the currant prices as of march and thier a little higher than that.
Logman,
Its August now. Things change day to day. That's a report from almost 5 months ago! Call your mills and log buyers!!! Don't worry if you aren't a big time producer. If quality is as good as you say, they will be giving you good prices. Quality product is in short demand. Get calling asap!
I have the latest sawlog bulletin with all the prices for logs
Logman81, if it were I, I'd be doing real good inspections of the maple. If it is curly, or birds-eye, I would be looking for specialty buyers, you could clean up on a couple good figured logs. If you don't know what to look for in the bark, a light scraping with a sharp hatchet into the bark a bit, but not all the way through, will give you a real good idea what lies underneath. T'would be well worth the look see. Good luck with it. Sounds like it will be some fun stuff!
If the wood is as good as you say, you shouldn't offer less that 50/50 and so much a ton on pulp. If you offer him 70/30 he might end the job before it begins. Also remember if you have all the mills bid, you might not get paid until you are completely finished, versus hauling it in when you get a load and getting a check every week.
Well put my offer in and will see what happens. I'll check on the maples if I get the job thanks.
Quote from: mad murdock on August 09, 2013, 06:26:09 PM
Usually you can see it in the bark, like a rumpled rug. I would guess somebody with experience could probably pick out a birdseye as well.
Around here unless there are massive quanities the logger never pays for pulp on the job. When you the logger remove the pulp you are doing a service for the landowner and not leaving a tangled mess which they should compensate you buy having and agreement that the pulp is yours. This is how I have worked it many times and the little extra for the pulp is fuel and maintanence money. Good Luck. And yes by the thousand is workable as someone else said, cause until you buck them up its a bit of a crapshoot. Especially on the big ones unless its a no brainer.
David
(https://forestryforum.com/gallery/albums/userpics/29166/014.jpg)
Quote from: mesquite buckeye on August 09, 2013, 07:44:54 PM
Having bought and sold many many many MBF's of both eye and curl logs I will say that there is no "usually" about anything related to specialty logs. Sometimes you can see it through the bark, many times you can't. Sometimes you can see it in the root flare, sometimes you can't. Sometimes you can see it if a little bark is bumped, sometimes you can't. Often times a log will have good eye/curl just at the surface below the bark and nothing deeper in the log. Sometimes a log will have nothing at the surface but nice eye/curl farther in. Many times there will be some "butt curl/eye" at the butt end of the butt log and nothing up higher.
If you dump a tree and on the end of a log notice lines radiating from the center of the log then there is a decent chance it has good eye, you can also spot curl in the end of a log as well. If you notice either of them then get your buyer to look at then ASAP because this time of year we like them fresh.
Sounds like somebody like chevy, no? Those are all good points. Then there are the logs with no surface indications that are fantastic inside. So it goes. My experience, though, is if it shows in the bark, more often than not it is there inside. Usually you have to pay before you mill the log, so there is a lot of guessing and ESP involved, for sure. ;D 8)
What do you think about if I came across some nice grained wood that I could have a portable sawmill come and saw some for mantels?
The trick is knowing what the best use is before you open the log. Then after it is open how to get the most value out of it. Could be mantles, slabs, lumber, veneer, gunstock blanks, table leg blanks, bookmatched table top, live edge, milled edge, etc, etc. I think the hardest thing about milling is to get really good at deciding the best use. Experience does help, but so does flexibility, openness to new ideas, log ESP and who knows what else. It is an art. :-\
I have done that go to the landing and look for the spokes on the end of the maple logs and found some, had one logger had cut and split a cord of wood , he stopped in to say hi and I saw his wood :o :o It was all birds eye :D
now he calls me when he thinks he has some
I got the job! Now to go over the fine details and line up buyers for all the wood. Got a buyer for the firewood, I prolly have most trucked to my yard for my own firewood sales later on. I think for the saw logs I'll contact a few mills and have them give me the best price for them standing before I cut them. I do have a little concern on what and what not to cut. I know that the main objective of the land owner is to cut most of the bigger trees to open up the canopy for the smaller tree to grow. I think a type of selective cut is in order.
I'm thinking it would be in both our best interest to get a consulting forester to give a evaluation and a plan of action.
Good idea. You don't want to get a rep as a high grader. ;D 8) 8) 8)
That's exactly why I'm going to use a forester. I've done selective jobs before but the timber was marked by a forester.
Everything is all set moving skidded there on Wednesday
Congrats!!! 8)
Thank you looking forward to getting back to work. I've been driving the wife nuts! I'll post pics once I get going.
Had a god first day at the new wood lot. Cut some tree length to open up a skid trail.
YeeHaw! Sounds like the beginning of a great adventure!
Here are a couple pics for ya! :)(https://forestryforum.com/gallery/albums/userpics/23822/image%7E13.jpg)
(https://forestryforum.com/gallery/albums/userpics/23822/image%7E11.jpg)
(https://forestryforum.com/gallery/albums/userpics/23822/image%7E12.jpg)
Looks like nice ground to log!
Yup and the wood isn't to bad either.
Things are going good, no break downs and good ground. Got a load of pole firewood out, looks like I may be selling the hardwood grade logs to hull after all as the other mill never called back. One of the foresters is coming Monday to look at what I got. Also really hoping to get to cut on the adjacent property's as the wood is better and bigger but I'll have to go talk to them.
Looks like some nice timber! Keep the pics coming :)
I keep forgetting to take some more pics but yes I will post more.
