25 inch band wheel for TH
Started by shannonmcelroy, October 20, 2016, 10:21:14 PM
shannonmcelroy
I have a 36THD25 with 25 inch band wheels, my old mill is 20 inch so I'm wondering what size belts would fit the 25 inch wheel without guessing, its 5/8 wide I'm sure. Thanks
36-25 HTD Timber Harvester, TK 1220 diesel hydraulic
york
Use a sharp chisel and cut belt,remove,then measure,you may come close...
Albert
Hewer of Wood
A Gates B-77 will fit with just a bit of slack. A B-76 will also fit but can be a real pain to get on. Tighter fit when it's on though.
1997 Timber Harvester 1967 Pettibone Super 8 and too much sawdust. Joshua 9:21
warren46
I use B-76 on my timberharvester.  I take the wheels off so it is easier to install the tight bands.  (I said "easier."  I did not say easy.)  it is a real pain to get the tight bands on the wheel but once on no chips can get behind the v-belt and they last a long time.
Warren
Warren E. Johnson
Timber Harvester 36HTE25, John Deere 300b backhoe/loader.
Kbeitz
When I worked at Grizzly tools I made a tire changer to put the
belts on. I use parts from a metel bender to fab it.
One week I needed to change 150 belts.
I was hopeing to find a picture of it.
All I can find is the handle of it sticking out from under
my work bench.
Love machine shop work
and Wood work shop work
And now a saw mill work
shannonmcelroy
thanks guys, the belts on it now are some type of hard Teflon plastic so they cant be measured accurately. ill get the 76 thanks again.
Dewey
I have used all kinds of belt brands and find NAPA The most consistant on size....  When your putting them on...the last little bit will be tuff...  It helps to put a little grease on the back side of the Belt to slide on easier.
Percy
My LT70 wheels arte a tad smaller. I use B72's. They are miserable till I set them on the dash of my pick up with the deforoster blowing hot air on them. They are easy when really warm,,,
dutchman
If you soak in warm to hot water they will
Stretch much easier.
