Author Topic: Is such a thing a short climbing spikes(say, 1/4 or 1/2") that won't hurt tree?  (Read 431 times)
Offline Danausplexippus
Newbie question-Is there such a thing a short climbing spikes(say, 1/4 or 1/2") that won't hurt the tree?
David
Offline mike_belben
  • Pulp Friction
Lineman spikes sre used for poles or tightbark trees like beech.. With a pine gaff your feet wont even touch a beech and itll hurt your feet and legs and be very hard to pluck out.
But the short spur will still gouge up the tree.  Itll probably recover but there is a risk.
Psalm 37:16
Offline clearcut
Spikes are for removals.
Ropes / equipment for pruning.
Offline Andries
  • Making buildings out of big curvy logs
Short answer: nope.
X2 on clearcut's answer.
LT30G24, LT40G25
Ford 545 Series loaders
Stihl chainsaws
Offline Ianab
If your plan is lift pruning crop trees, then spurs aren't the solution.
Locally it's ladder and loppers / hand saw stuff. You can throw a safety chain around the top of the ladder, and even use strap on steps to reach higher. So while they may scuff up the bark, they don't penetrate it and damage the growing area underneath.
So with  a ~12 ft ladder, a strap on step above that, you are able to prune up over 20+ ft. Wrap your spare leg around the tree. Great way to keep fit.
Offline mike_belben
  • Pulp Friction
Bowhunters use the strap on ladders.. Here we call them climbing sticks.
Psalm 37:16
Thank you to all for your responses. Will be using ianab's technique-looks simple & good.
Offline Ron Scott
Climbing spikes are generally not permitted unless the tree is to be removed as previously stated. Climbing spikes damage the trees and leave entry points for insects and diseases such as the devastating oak wilt.
~Ron
Offline Tacotodd
  • To learn and help
Thatís also what a prusic is for. Even I can tie one of them, and I canít tie but about 4 knots and thatís the only tree knot that I know about!
Trying harder everyday.
Climbing spikes
Started by Firewoodking on Ask The Forester
Last post June 13, 2013, 08:56:35 AM
by clww
Neighbor Contracted Tree Service Climbed my Trees With Spikes
Started by tim1234 on Ask The Forester
Last post August 22, 2008, 10:20:37 PM
by treecyclers
Cutting roots--don't want to hurt tree
Started by esarratt on Urban and Community Forestry
Last post April 22, 2020, 09:00:47 AM
by Magicman
Tree Climbing
Started by lxskllr on Forestry and Logging
Last post August 27, 2018, 01:34:51 AM
by mike_belben
