Sugar shack build
Started by DeerMeadowFarm, February 05, 2018, 03:18:35 PM
Woodpecker52
Down in Mississippi we have sugar shacks but they are not used for boiling sap!
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
maple flats
For your check chains on the cupola doors you will be happier if you make them just long enough that they tilt out just past 90 degrees. That way they still close easily but they do not drip melting snow and rain inside. I actually have a stop on mine just using a knot in the rope I close the door with. I then have a cleat mounted vertically (a boat terminology and piece of hardware) on the wall. When I open the doors I position that knot on the on the low end of the cleat and wrap the rope 2-3x to hold it there. The doors stop slightly past level and all drips then fall to the roof.
All looks good!!
Yes,maple flats,good idea.
