Firewood Conveyors- Who is giving the most bang for the buck currently?
Started by labradorguy, July 14, 2015, 09:20:21 AM
labradorguy
In the market for a 35' (give or take) firewood conveyor. I wanted something to pile off of a processor and then also be able to turn around and load dump trailers with, as in use a Cat/grapple to pick off of a pile, then drop into a hopper and out to a waiting trailer. I've looked at a couple from large firewood outfits, but they seemed a bit Mickey Mouse for the $$$. Just wondering if something better is out there that I have not come across yet. Thanks! :)
OH logger
john
Gary_C
Quote from: labradorguy on July 14, 2015, 09:20:21 AM
Kind of hard to answer when we don't know what you have come across yet.
labradorguy
Mostly loading pull behind dump trailers, 7' to clear give or take.
hedgerow
I have a old gravel conveyor I would have to double check but I think it is forty foot. Has a gas engine running a pump then hyd drive motor and hyd lift for height adjustment. I picked it up on craigs list for a $1,000 and it works great for firewood. I changed sprocket size on the drive to slow it down some.
labradorguy
That sounds like the ticket there! 1000 bucks, can't beat it.
hedgerow
 I had found two within towing distance 500 miles or less one was in tulsa OK and the other was in Wichita KS the one in Ks had a aluminum side rails and the belt seem a little better so that was the one I towed home. I have used it for couple of years saves the back. We used to use a old ear corn elevator. It didn't seem to like firewood. We broke the chain a lot and it would get jammed up with wood splitter trash.
OH logger
I seem to have had better luck with bale/ear elevators than most but I have to ask if your Mahindra wont load the dump trailer or hows come your wantin to do it with a conveyor?
john
labradorguy
It will load it, so will the Cat. I need to conveyor to pile it high under a big pole barn I have. 35' will probably be the minimum to get the best use of the space, 50' would be better but $$$. The tractor or Cat is loading the log deck, it gets split, and then need the conveyor will pile it up right off the splitter. I'm looking at building a tumbler to throw into the circuit too. Store the wood where it's dry, pull off the pile with the Cat, drop it into the hopper, up the conveyor, through the tumbler to get rid of the loosened up bark and debris, then out the chute and into the dump. Too complicated for firewood maybe, but there is a lot of efficiency to be had if I can get everything firing on all eight. I'm open to better thoughts if someone has them. I'm looking at changing my delivery system too. Stacking three cords and then unstacking two of them and dumping the third is for the birds, especially when you are doing it every day. I've really been looking hard at those 1/4 cord bags or figuring out how to load two thrown cords. I have a divider but sometimes it jams up after a dump and it's a PITA to work loose. lol
hedgerow
Do a conveyor search on a craigs list there is one on there in your area.
sam-tip
Yep keep doing daily search on craigslist.   I found a Rapat 70' belt conveyor on Craigslist last fall with 12 hp honda.  Seed company was getting rid of it.  $2000  My biggest problem was with bad gas in the fuel tank.  I did slow it down by changing both gear boxes to 2:1 ratio from 1:1.  Was rated for 2500 bushels per hour. Now it is a nice and slow.
Then I also found by word of mouth a Kewanee elevator that I put a 1.5 hp electric motor on. $200   It jams if the pieces are just the correct length.  But nothing breaks with the electric motor.  Tried gas motor but it broke the chain.  To much power.
https://youtu.be/oZcq0X3IKtI
https://youtu.be/ePd2ZXnC1Ho
Central Boiler E3200 WiFi
Many many ported chainsaws. 201 to 3120
TM log splitter pro30 6 way head
D&L 1020 swing blade sawmill for slabbing
Timberking 1220
OH logger
cool videos! can you guys come here and make wood like that!? that was neat to watch especially cause it says it was for charity. nice job. and I agree with you on putting the electric motor on the bale elevator and doin away with the gas motor. that's the key
john
sam-tip
I did price new firewood conveyors but $8k was to much for just a 30 ft conveyor.  After using the 70' Rapat  the 30 would have been to small.  I drove by a tree service that does firewood yesterday and they had a guy on top the pile pushing the splits down because they only used a 30 ft conveyor.
Timberking 1220
labradorguy
Quote from: hedgerow on July 15, 2015, 04:23:22 PM
I'm not finding it, but I will keep searching for it, maybe I am looking in the wrong area. Thanks
sam-tip
Timberking 1220
hedgerow
Quote from: labradorguy on July 16, 2015, 12:25:08 PM
I just looked there is 40 conveyor on craigs list lake of the Ozarks mo. $2000.00. Just bring up Lake of the Ozarks craigs list and put conveyor in the search several will come up.
labradorguy
