What is it?sawmill mod
Started by PAmizerman, February 01, 2018, 07:27:00 PM
PAmizerman
I made this yesterday when I had to replace a third hose on my lt40 super with stationary command control. Let's see if you guys can figure this mod out.
Hydraulics everywhere
Woodmizer edger 15hp electric
Traverse 6035 telehandler
Case 95xt skidloader
http://byrnemillwork.com/
WM bms250 sharpener
WM bmt250 setter
Chuck White
justallan1
I'm guessing a stop of some sort or possibly a go/no-go gauge for different ops.
PAmizerman
Here's a couple clues.
It swivels. And is now attached to the mill permanently, unless I get a big mobile job.
I will no longer be beating my legs up.
WM bms250 sharpener
WM bmt250 setter
paul case
pc
Slingshot
PAmizerman
Well I guess Paul's close enough. Because the hitch is hidden now, in the back corner of my shed.
I have been turning down mobile jobs for 2 years now since I have enough to keep me busy without them. When I replace hoses I take the hitch off the mill tape the new hose to a stick and fish it through. Since my mill is a remote the command control and cat track are attached with the same bolts that hold the hitch on. It takes a six armed man to get everything lined back up and bolted on. So I pulled the hitch and made this filler so I could tighten the bolts down without bending the tongue. And I made it so all I have to do next time is loosen the bolts and it will swivel down out of the way. I know it's not a rocket science mod.  But figured I'd throw it out there.
WM bms250 sharpener
WM bmt250 setter
